Rubik's Cube Mosaic
11,411
162
22
A while ago, I saw mosaics created of Rubik's cubes on the internet and as a cube-enthusiast I wished I could make/have one myself. However, there were two obvious problems:
1. You need a lot of cubes, which means it's going to be very expensive.
2. It's going to be very large and you have to find a place for it.
But there was a solution to both of these problems: Ordering 3cm x 3cm x 3cm (1.2" x 1.2" x 1.2") cubes in bulk. I got 600 cubes for about $100 (including shipping) from china. It's still a lot of money but doable.
I was kind of in a rush so the documentation is not as good as I wished but I thought the result was shareworthy.
Step 1: Planning
Before you start, you should consider:
  • how much detail the image should have,
  • how large the image is supposed/allowed to be.
  • what your budget is.
Detail: Each cube gives you 9 pixels, so my 600 cubes would give me 5400 pixels, which would be enough for a 90*60 image.
You also have to consider that you only have 6 colors so you have both a very low resolution and a very limited palette.
There are tutorials for converting your own photos to suitable images on the internet. I used the GIMP tutorial on http://www.youcandothecube.com but ended up using their example for 400 cubes (pdf) for two reasons:
  • I was in a hurry because it was a Christmas present for my girlfriend.
  • I wanted to use a photo from our trip to the US and would have ended up at pictures of the bridge anyway.
I think another good motive would be images from vintage video games because they are pixelized anyway!
Size: If you buy the 3cm x 3cm x 3cm cubes, resolution translates directly to size so that part is pretty easy. You probably won't have the problem that the whole thing is to small.
Budget: Look around for deals from wholesale sites. 600 cubes was actually the smallest amount I could get for
When ordering keep in mind that if you pay cheap, you get cheap. I got very low quality cubes (many many just disintegrated in my hands) and I think I lost about 30 cubes that way. However, about 10% of the cubes were quite high quality (definitely from another production) so you might also get lucky. I would recommend to buy at least 10% more than you need.
Step 2: Planning Contd
Now you have to decide how you will get the cubes on the wall. My main concerns were:
  • I didn't want to glue them because I wanted to keep the option to change the picture
  • I didn't want to use a frame because I wanted the sides to be visible
  • I didn't want to have glass in front of it because I wanted to keep the texture
My solution was to tie them down using nylon string while supporting them with an angle bar from underneath
The materials I used were:
  • Cubes (obviously)
  • A board of the right size
  • Nylon string (I used 0.15mm width). If you do it like I did, you need about 5 * (cube width) = 15cm per cube plus overhead (I think 20cm per cube should be plenty)
  • angle bar + glue
  • Wire to hang it on the wall (you should probably also support it from underneath because of the weight)
The are very few tools required:
  • electric drill
  • needle and scissors for the nylon string
Step 3: "Solving" the Cubes
Now it's time to make the actual image. This is going to take some time. It is easier to do than a normal cube because you only need one side but the low quality of the cubes made it a lot harder to turn the cubes. I think, it took me a little less than a minute per cube. Of course there are parts of the picture that are a lot easier and sometimes you don't have to turn the cubes at all.
Step 4: Assembly
Drill the holes and attach the angle bar. You want the nylon string to go through the grooves so drill the holes as indicated in the picture.
"Sew" the cubes on. Be especially careful with the edges. A lot of the times, my wire would become very loose because it slipped deeper inside the grooves. I did 5 cubes at a time and used adhesive tape to hold the string down on the back side.
Attach something to hang the mosaic on the wall. I used wire that I put through the holes before I sewed on the cubes.
This step took me almost as long as solving the cubes (that string is practically invisible in bad lightening). If you choose another method like gluing them down or building a frame with glass front this will be much faster.
Step 5: Done!
Now the only thing left is to put it up on the wall. This thing is going to be heavy! Mine is 60cm x 60cm and weighs about 6kg (24" x 24" and 13lb).
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    22 Discussions
    Mega_Spell
    2 years ago
    can you give me a link to where you got your cubes i want to try this for myself . the one i found was for 5 dollars and it was just one...
    AllisterG1Mega_Spell
    Reply 1 year ago
    15 cents a cube (2 inch per side). I used Alibaba:
    https://www.alibaba.com/product-detail/OEM-Ultra-Smooth-Twisty-Puzzles-educational_60626486833.html
    ThomasJ136AllisterG1
    Reply 1 year ago
    Hey, thanks as well. The link you gave is dead now, but there appears to be another ad by the same company.
    https://www.alibaba.com/product-detail/OEM-Ultra-Smooth-Twisty-Puzzles-educational_60697157919.html
    I'm looking at making an order, and just want to know what was your experience with the cubes you ordered? Overall, were they decent enough quality, or not?
    Thanks again!
    TheGreatCK
    2 years ago
    THIS IS GREAT!
    How the hell did you make a mosiac with SO MANY cubes????
    It must have taken over a year!
    Well, at least She was really pleased right?
    Anyway THIS IS AMAZING!
    arcadeprecinct
    3 years ago
    They were $114.00 + customs for 600 cubes. I haven't found a deal like that since though. I was able to sell 50 of the surplus to a second hand toy store. I would have liked to sell more but there weren't enough high quality cubes.
    elleorsillo
    4 years ago
    What a simple thing :)
    nodcah
    4 years ago on Introduction
    This is really cool! Using the small cubes is a clever idea =D
    Greetings... I am currently Going to start making these wall art with Rubik's Cubes to... I have an image planned out and it is 25 Cubes high and 18 across... so fairly large... I had two questions for you... on what site did u order ur cubes from for that cheep and also if I wanted to Glue them together because im not planning on changing the picture what glue would you recommend?
    Tux102
    4 years ago
    Where did you get the cubes from? I realize you said from China but was there a specific link or website you used.
    Ot actually was not as much work as I had feared. Attaching the cubes took longer than expected but solving them was faster. Also I used the template image which saved time. The worst part was waiting for the cubes (delivery took about 2 months)
    zaid.bro
    4 years ago
    cool awsome...and unique
    MrBeta
    4 years ago
    Nevermind! I just reread it and found the weight!
    MrBeta
    4 years ago
    This is very cool. How much does the entire piece weigh?
    NathanSellers
    4 years ago
    wow! This is really impressive! At first I thought this was just stickers, but when I saw that you actually had to arrange each cube I was floored! Very well done. Thanks for sharing such a cool project.
    arcadeprecinctrklotz1
    Reply 4 years ago on Introduction
    The cubes were about $100 (+ tax if it applies for your country). But keep in mind that I only used 400 cubes and have at least 150 left. I'll probably try to sell some of them to bring my cost down. The rest of the materials cost about $5 (I already had the board)
    Jeph Diel
    4 years ago
    This is amazing!
