Rustic House Lamp Using Cardboard Box
818
20
8
About: Hello ! I'm Creative D2H, You can see in my posts how to make beautiful things, to create houses of history, fairy houses, recycling ideas, decorations, crafts,and paint. They use very cheap materials and al...
This tutorial show you how to made a Rustic House using Cardboard Box and a Paper Clay. It’s fun to make and you can use it as an awesome decoration.
What you need :
  • Cardboard Box,
  • DAS modelling material 1kg - http://amzn.to/2r5FEHY
  • Cardboard 80x50cm,
  • Transparent Plastic Film 25x25cm,
  • Aluminium foil
  • Hot Glue,
  • Hot Glue gun,
  • Acrylic Paint,
  • pop stick,
  • Scissors,
  • Cutter knife,
  • Clay sculpture tools
Supplies:
Step 1: Making Doors and Windows
I began by tracing the doors and windows in all three sides of the house. After, I cut through the shapes drawn using a cutter. To build the glass, I used transparent plastic film: I cut the right shapes and stuck them in the inside of each window using hot glue.
Step 2: Building the Basic Shape and the Garden
To form the garden, I cut the cardboard into two oval pieces of diameters 40cm and 46cm. I stick them with the piece of cardboard already prepared to form the house. Then, still using cardboard, I build the roof of the house and roof over doors and windows. To make the rounded shape of roofs, I cut light parallel lines using the cutter to have the accordion shape. I glued there l using of hot glue.
Using mainly wooden pop-sticks, I built the various poles of the house. in total, we have 5 poles. Each pole is composed of 4 pop-stick. See the video tutorial attached for more details and construction steps....
Step 3: Cover With Paper Clay
After, I cover all the cardboard with paper clay. I used "DAS modelling material" but you can any paper clay or even a homemade paper clay. I don't use natural air dry clay, it will shrink and that will result in a lot of cracks around your jar. So paper clay is the best to use in this type of craft.
Step 4: Building the Tree
To build the tree, I start by covering three steel wire with the aluminum foil. After, I braid these three pieces to form the trunk of the tree and these branches.
I cover the whole tree in paper clay and with the carving tool I form the grooves of the tree. Using the steel wool, I make the texture.
Step 5: Build the Wood Garden Fence
To build the garden fence, I use pop-stick pieces 5cm in length. I start by gluing the poles using hot glue.
After, I connect them with also pop-stick of suitable lengths. I made two rows, you can do only one row.
Step 6: Paint
I used acrylic paint for painting. You can also use watercolors and watercolor crayons. It's up to you. In the end you can seal the paint using some matte spray varnish. I placed some battery LED lights into the house. I recommend you use soft lights that will gently illuminate your windows so it looks like a real house.
Step 7: Finish
Finally, I ended up with a wonderful house as shown in the attached photos :)
Step 8: Watch
In order to not miss any details and to follow all the real chain of the instructable, enjoy to watch the video tutorial attached.
I hope you like my instructable. See you!
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    8 Discussions
    AzureOzma
    8 weeks ago
    What a great idea! Love how you've put it together. Would have never guessed it was made from cardboard!
    ESSOMAR
    2 months ago
    Awesome ! Creative instructable ! Voted :)
