SHELF TO GO
33,546
321
11
About: If you like simple solutions then here you can find some of my crazy ideas.
This shelf is easy to make und very light
and foldable!
Step 1: Tools
All you need is a
Cordless drill
a 4 mm drill bit
a countersink
(screws)
Step 2: Wood
5 boards, 3-layer pine wood, 3/4" thick
4 bars
2 diagonal bars
and a 4mm pine plywood back, this is optional and not necessary
2 wooden dowels
Step 3: Cut or Buy the Wood
if you have a table saw or a track saw, you can saw the wood by your own
but you can also buy the cut wood at your wood store
Step 4: Drill Holes in the Bars
drill 5 holes in each of the 4 bars
be sure all of them have the same distance from the edge
drill also two holes in the diagonal bars
a small one on the upper end and bigger one on the lower end for the wooden dowel
if you have no drill press, a hand drill is also good enough
after drilling countersink the holes
Step 5: Drill Holes in the Boards
drill small pilot holes in every corner of the boards
this little jig on the picture makes it a little bit easier
Step 6: Assembling
screw all the bars on the boards
Step 7: Add a Backboard
if you want you can add a backboard, but this is not necessary
If you want you can also paint your shelf
Step 8: The Diagonal Bars
screw one diagonal bar on the back bar
make sure, the shelf is at the right angle
then mark the position of the lower hole of the diagonal bar on the front bar
drill here a hole for the wooden dowel
glue a wooden dowel in this hole
it should fit in the hole of the diagonal bar
Step 9: The Result
Instead of thousand words, please watch the video
If you use a mobile device, use this link .
If you like it, I am glad if you vote for it in the "DORM HACKS CONTEST 2016"
If you want to see more of my work, subscribe to my Youtube channel
Dorm Hacks Contest 2016
Second Prize in the
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    11 Discussions
    ScarlettD
    2 years ago
    I love this project, it's perfect for college students. Do you remember the dimensions you used so I can use it as reference? or is there a "right size" for the diagonal bars?
    StephanP1ScarlettD
    Reply 2 years ago
    Thank you, I am glad you like it. The dimensions are not important. Make it so big or so small you want. There exist no right size for the diagonal bars. I used two pieces of scrap wood.
    Dawsie
    2 years ago
    thanks for the great idea ? I have been looking for a way to take shelves to the market to hold my goodies on and this idea is the best one ever ?
    I will be making some of these so I can take with me and place my jewellery and bits and bobs on them.
    Thank you ? I loved the idea so much I have voted for you all the best I hope that you win
    Kind Regards Dawsie
    miller92586
    2 years ago
    A wonderful video, Thank You sooo much- I have been looking for a folding shelf for my work. You have made my day- I will surely make this. Again Thanks
    StephanP1miller92586
    Reply 2 years ago
    You are welcome. Thank you for your nice comment.
    dlindstrom
    2 years ago
    These are cool folding shelves. I think I would like to space
    the shelves apart the same width so they would fold flat and use a cable
    or chain as the diagonal support. This is indeed a very good idea.. Thank You.
    murielleparrain
    2 years ago
    it seems very easy to do.....but I m not a professionnel, but with this vidéo, that will Hell me à lot..
    Thank you
