SOLAR POWERED ARDUINO WEATHER STATION
351,400
1,087
174
About: I am an Electrical Engineer. I love to harvest Solar Energy and make things by recycling old stuff. I believe, IF YOU TRY YOU MIGHT, IF YOU DON'T YOU WON'T. www.opengreenenergy.com
[ Play Video ]
In country like India most of the people are dependent on agriculture.For effective planning in agriculture weather forecast is of utmost importance.So farmers are always interested in the Weather Forecasts.As farmers stay in remote areas, they have to wait for the news updates in TV, Radio or News Papers.Unfortunately this weather information is not the accurate data of their local environment rather it gives data of nearest weather forecasting station.
Being a son of a farmer, I decided to monitor the local weather and inform to my father earlier.So that he can take early decision for his farm.
You can find all of my projects on : https://www.opengreenenergy.com/
My weather stations typically consist of two major parts:
1. The sensors that sit outside and measure temperature,humidity, rainfall, and barometric pressure.This data is send wirelessly through a RF transmitter module to the display unit.I named the entire module as Transmitter module.(Tx).
2. The display unit that lives inside in a convenient place so any one can read the external temperature,humidity etc. It equipped with a RF receiver to receive data from transmitter module.I named it as Receiver module (Rx).
Both the module are run by the arduino micro controllers.
As the transmitter module is deployed in the field,we have to deal with the power management.It is impractical to run a long cable to provide power to the sensor’s location.This leaves relatively few practical options.
1. Connecting directly an Arduino board to a battery. Though it sounds good and obviously it would work, but your battery would be depleted in a matter of days because some components like voltage regulators,power led and USB interfacing chip in the arduino board are always drawing power.
But now a days high capacity battery packs are readily available in the market.Solar panels are getting more efficient and cheaper. Adding a boost converter in the circuits extract every last drops of juice out of battery.
2. Putting the arduino to “sleep mode" to consume even less power.
You can see it in the step-11 and 12.
In this guide I will teach a new skills on how you can make a solar powered battery pack for your arduino and how arduino power consumption can be optimize by putting it in to sleep mode.
By using the above technique you can run your sensor related or any other stand alone arduino project for a long time.
Step 1: PARTS AND TOOLS REQUIRED :
PARTS :
1.Arduino Uno (Amazon / eBay)
2.Arduino Nano ( Amazon / eBay)
3. DHT11 (Amazon / eBay)
4.RF transmitter-Receiver pair (Amazon / eBay)
5.20x4 LCD display (Amazon / eBay)
6.LCD I2C module (Amazon / eBay)
7. 3.7 V Li Ion Battery /2 AA Ni Mh rechargable Battery (Amazon / eBay)
8.Boost Converter (Amazon / eBay)
9.Li Ion Battery charging board (Amazon / eBay)
10. Battery Holder (Amazon / eBay)
11.Solar Panel (Amazon / eBay)
12.Resistor 10K ( Amazon )
13.Diode -IN4007 ( Amazon )
14.Jumper wires/Wires ( Amazon )
15.Bread Board ( Amazon )
16.22 AWG solid core wire ( for making antenna) ( Amazon )
17.Scotch mounting pad and tap ( Amazon )
TOOLS :
1.Soldering Iron and solder ( Amazon )
2.Glue gun ( Amazon )
3.Hobby Knife ( Amazon )
4.Drill ( Amazon )
5.Wire cutter/Stripper ( Amazon )
Step 2: SOLAR POWER
Why Solar Power ?
The main draw back of battery operated device is that it will depleted after a certain time.This draw back can be eliminated by using a natural resources like solar,wind or hydro energy.The most obvious free source of energy to recharge the battery is solar energy. It is a relatively simple, cheap and requires very less skill .
Among the rechargeable battery nickle metal hydride (NiMH) and Li Ion battery are widely used for battery operated device.
Facts on Battery Charging :
The thumb rule for charging Ni Mh batteries is 1/10th (commonly known as C/10). To charge the battery pack at 1/10th its rated current requires 16 hours of charge time( You can see the picture).The solar panel receives optimal sunlight for only four hours per day, from 10 a.m. to 2 p.m. Thus, a totally ideal system would require four days to fully charge the battery pack.
What is C/10 ?
For example we have a 2xAA–sized 1300mAh battery pack that is rated at 1.2 volts per cell. With cells in series, our pack outputs 2.4 volts and 1300mAh.
Here capacity C =1300mAh
C/10 means 1300/10 =130mAh
So to charge the above battery pack we need a higher voltage ( 2.4 to 3 V) with a maximum current of 130mAh.
As per C/10 rule it requires 16 hours to fully charge the battery pack.
You must be ask,what will happen if we increase the current (>130mAh) ?No doubt your battery will charge faster.But the life of the battery will be reduce.So my advice is to keep the current bellow the C/10 value.
Step 3: How to Choose the Right Solar Panel
The main source for powering the sensor module is solar panel.So it must be able to provide current for powering the arduino as well as current to charge the battery pack during the day.As per my experience it is the most challenging part for a novice user.
Don't worry these are the following tricks which can help you to buy a right solar panel.
1. Voltage : Choose 1.5 times the battery pack voltage
2.Current : Current taken by the Arduino + current for charging (should be
Example :
A battery pack is made of 2 AA Ni Mh battery.
Battery voltage = 1.2 x 2= 2.4V
So required voltage for solar panel =2.4 x 1.5 = 3.6V
By taking some margin we can choose a 4V solar panel for it.
The sensor module along with arduino taking 100mAh current.
Battery capacity is 1300mAh
C/10 = 130mAh
Solar panel have to provide current 100mAh for arduino along with a current not more than 130mAh.
Lets take 100 mAh for charging the battery
Total current required = 100+100=200mAh
From the above calculation it is clear that we need a solar panel of 4V and 200mAh.
The following table shows the solar system configuration relationship between storage batteries and mini solar panels.
Battery ---->Solar Panel
1.2V ------> 2V ~ 2.5V
2.4V ------> 3.5V ~ 4V
3.6V ------> 5V ~ 6V
6V ------> 7.5V ~ 9V
12V ------>15V ~ 18V
Note : It is not the strict rule for choosing the exact rating solar panel,rather it is approximate rating .I write as per my experience.
Step 4: Ni Mh Battery Charger :
To power a arduino we need 5v.There are two options
1. Use a 4 AA battery pack :
Total voltage =1.2V x4=4.8V (nominal ) but when it is fully charge,voltage is more than 5V.
This is not efficient.
2.Use 2 AA battery pack :
Total voltage =1.2Vx2 =2.4 V
In this case we have to raise the voltage level to 5V by using a voltage booster circuit.
I recommend to use this pack.It is reliable and efficient.
Charging Circuit :
Standard sized nickle metal hydride (NiMH) cells need simple charge circuit.
You only need a solar panel, diode, the batteries, and a battery case and wires.
4 AA battery pack
Solder the positive terminal of the solar panel to the positive terminal of diode.
Solder the negative terminal of diode to the positive terminal of battery pack.
solder the negative terminal of the solar panel to the negative terminal of the battery pack.
See the above picture for soldering.
2 AA battery pack
As the battery pack voltage is not sufficient in this case, we have to use a booster circuit to make 5V for arduino.
Step 5: Boost Converter
A boost converter is a DC-to-DC power converter (like a step up transformer in AC) with an output voltage greater than its input voltage.
Boost converter used in this project have following specification :
>>Input voltage: 0.9V-5V DC
>>Transfer efficiency:96%(max)
>>With USB port
>>With working indicator light
>>with one AA battery power supply output current can up to 200~300mA,
>>two AA batteries to the output current of 500~600mA
You can buy it from eBay
Adafruit have also designed a boost converter known as Minityboost for USB charging.You can also use it.
In our case the input to the boost converter is 2.4V and out put is 5V which is sufficient to power a arduino.
Solder the '+' terminal of boost converter to the battery positive terminal.
Solder the '-' terminal of the boost converter to the battery negative terminal.
Step 6: Li Ion Battery Charger
Among the all charger what I have discussed earlier ,I like it most.This is the most powerful and efficient battery pack.The interesting thing is that you can use this for charging any usb powered gadget like smart phone,tablet,MP3 etc.
If you look at the Periodic Table, you will find that Lithium is on the far left in the first column, where all the most reactive elements live.
Caution :
You must take certain precautions when dealing with Lithium Ion Batteries. In order to maintain a very precise voltage when charging. The 3.7V batteries we're using in this guide need to have a charging voltage of 4.2V.A volt high or a volt low can mean an out of control chemical reaction which can lead to danger.
Don't worry a suitable Li Ion battery charge controller will solve the above problem.
Lithium Battery Charging Board used in this project have following specification :
>> Current- 1A adjustable.
>> Charge precision- 1.5%.
>> Input voltage- 4.5V-5.5V.
>> Full charge voltage- 4.2V.
>> Led indicator- red is charging blue is full charged.
>>Input interface- mini USB.
>> Work temperature- -10℃ to +85℃.
Circuit Connection :
Solder the Input positive terminal of boost converter(red wire) and battery holder positive terminal(red wire) to the charging board's BAT + .
Solder the Input negative terminal of boost converter(black wire) and battery holder negative terminal(black wire) to the charging board's BAT-.
The boost converter output is a USB terminal. For powering a bread board circuit we need two wires for connection.So we have to modify something according our requirement.
The usb have four terminals (5V,D-,D+and GND).
Solder the red and black wire to the + and - respectively as shown in the back side of the boost converter.
Note : The boost converter do not have any marking.So use my picture during soldering.
Step 7: TRANSMITTER
The transmitter module contain the DHT11 sensor which is a relatively cheap sensor for measuring temperature and humidity of the environment.It is good for 20-80% humidity readings with 5% accuracy and for 0-50°C temperature readings with ±2°C accuracy.
I ordered the Barometric Pressure Sensor( BMP085) and rain fall sensor from eBay to forecast more weather data.For the time being I am happy with only temperature and humidity.
The weather data is measured by DHT11 ,processed by a Arduino nano/bread board arduino and transmit it wirelessly through a RF transmitter.
DHT11 Connection :
DHT11 sensor have 4 pins : 1->Vcc ,2->Data ,3->NC ,4 ->GND
DHT11 -->ARDUINO
Vcc-->5V
Data-->D8
NC --> No connection
GND-->GND
Connect a 10K resistor between VCC and Data pin of DHT11
RF Transmitter Connection :
The RF transmitter has 3 pins ( VCC,Data and GND).
RF Transmitter -->ARDUINO
VCC --> 5V
Data-->D11
GND-->GND
Note : Add a antenna in the RF transmitter to increase the range.click here
After connecting every thing, upload the Tx_code attached bellow
Step 8: MAKE a ENCLOSURE FOR Tx MODULE
I used a plastic box for transmitter module enclosure.
Make a hole in the top side of the plastic box for inserting wire from the solar panel.
Make small holes in the side wall (opposite face) for ingress of fresh air ( to measure the accurate data ).see the pics.
Place the charging circuit (made earlier) inside the box.
Take out the wires from li ion battery charger (IN+ and IN-)
Solder the positive terminal of solar panel to the positive terminal of diode and negative terminal of the diode to the red wire from the the charger.
Solder the black wire to the solar panel negative terminal.
For mounting the solar panel and battery holder I used skotch mounting pad.The mini bread board have inbuilt pad to stick.
Use tap to stick the wire firmly.
Connect the 5V (+) and GND (-) terminals of boost converter to the bread board red rail(+) and blue rail (-) respectively.
To test it expose to sunlight ,you will see red led in all (arduino,boost converter,charging) the boards will glow.
Step 9: RECEIVER
The receiver module receive the weather data by a RF receiver and it is processed by Arduino UNO .The processed data is displayed through a 20x4 char LCD display.You can also choose a 16x2 LCD also.The main reason for using a 20x4 char LCD is display is that I can display large number of weather parameters.
I add a I2C module to the LCD for reducing the number of connection with arduino (requires only 4 wires).
If you don't have a I2C module go to my tutorial on LCD tutorial for connection and example code.
LCD connection :
The I2C LCD have only 4 pins (GND,VCC,SDA,SCL)
LCD-->ARDUINO
GND-->GND
VCC-->5V
SDA-->A4
SCL-->A5
RF receiver Connection:
The RF receiver has 3 pins ( VCC,Data and GND).
RF Receiver -->ARDUINO
VCC --> 5V
Data-->D11
GND-->GND
Note : Add a antenna in the RF receiver to increase the range.click here
After connecting every thing upload the Rx_code attached bellow
Step 10: MAKE a ENCLOSURE FOR Rx MODULE
The receiver enclosure is card board box.
Mark the outline of lcd by using a pencil or marker.
Cut the marking portion by using a hobby knife.
Insert the lcd in to the cutting portion of the box.
Hard gue on the back side of the lcd to hold it firmly
Place the bread board receiver module prepared in the previous step.
I use a 12V dc adapter for powering the arduino uno.Make a hole in the back side of the card board box for inserting the dc adapter cable.
Step 11: POWER OPTIMIZATION BY USING SLEEP MODE
The weather data does not change frequently.So we can take reading at an interval of 5mins.As we are taking readings at regular intervals, it is a fantastic way to save lots of power. A system with appropriate sleep schedules can run for several months on just two AA batteries.We are so lucky that Arduino has several sleep modes that can be used to reduce power consumption.
This is most useful for any sensor networks.You can use this tricks in any of your stand alone sensor project.
After searching through the internet for using the sleep modes, I found a simple but powerful library by
Rocket Scream has a Lightweight Low Power library supports all AVR power down modes. Each mode has an associated library method that lets you control sleep duration using the watchdog timer.For a novice programmer like me it is very simple and easy to use.
How to use LowPower Library :
1. Download the library from GitHub
2.Extract the zip file to the arduino library in your computer.
3.Import the library in your code.
4.Write the following one line code for power saving.
"LowPower.powerDown(SLEEP_1S, ADC_OFF, BOD_OFF) ; "
You can also pass different arguments to shut off individual peripherals. For different argument and sleep time refer the table provided by Lightweight Low Power Arduino Library.
example code :
#include "LowPower.h"
void setup()
// No setup is required for this library
void loop()
// Sleep for 8 s with ADC module and BOD module off
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
// Do something here
// Example: read sensor, log data, transmit data
Lets use it in the blink code of arduino IDE example
Apply "LowPower library" in Blink code
#include "LowPower.h" // import the lowpoer library
int led = 13;
void setup()
pinMode(led, OUTPUT);
void loop()
digitalWrite(led, HIGH);
LowPower.powerDown(SLEEP_1S, ADC_OFF, BOD_OFF); // instead of delay(1000) ;
digitalWrite(led, LOW);
Before using the Lowpower library current taken by arduino
51.7mA when led is ON
47mA when led is OFF
After using the Lowpower library current taken by arduino
34.93mA when led is ON
31.73mA when led is OFF
Are you happy to reduce 32.43 % power ?? Hey there is still room to reduce the power consumption.
Your arduino board have different power sucking components like power led,voltage regulator and USB interface chip which takes most of the power even when it is idle.For other alternatives see the next step.
Step 12: Alternatives for Power Saving
>> The simplest method to reduce the power consumption is by passing the voltage regulator in the Arduino board.
Buy a separate boost regulator circuit and connect its output to the 5 volt pin on the Arduino board, which bypasses the 5 volt regulator on board.This procedure is used in our project.
>> using a "bare bones" board instead of arduino board.
>> Disable the unnecessary led
>> If you do not need time accuracy, then use the Atmega 328 internal 8MHz crystal instead of a external 16Mhz crystal.
>> Operate Atmega 328 at 3.3V instead of 5V
>>Turn off sensor as soon as possible
To know more details on arduino power saving techniques click here
The maximum power saving is done by using a Bare bones board.By using a bare bone board the power consumption can be reduced to micro amps level during sleep period.You can see the above figure.
You can easily make this on a bread board by following the links bellow :
1.Arduino on a Breadboard
2.Arduino to a Microcontroller on a Breadboard
Make bare bone pcb board by following the links bellow :
Single Sided Really Bare Bones Board Arduino in EAGLE
I will highly recommend for the bare bone board for any battery driven projects ( like sensors).
Step 13: Battery Life Estimation
The battery life can be calculated by determining the average current for the circuit.
Use the following general equation to calculate average current.
Iavg = (Ton*Ion + Tsleep*Isleep ) / (Ton +Tsleep)
Ton (arduino is active ) = 250 ms =0.25s and Ion = 16mA
Tsleep = 5min =300s and Isleep = 200 uA (approx)
It is very difficult measure the current during the sleep period .Some time I got zero reading.
Iavg = 0.205 mA
Operating Voltage =5 V
Pavg=VxIavg =5x.205=1.026 mW
Li Ion battery capacity =3000 mAh
Battery voltage =3.7V
Power =3.7x3000=11100 mWh
Battery life = 11100/1.026 =10,818.7 hours = 15 months approximately
From the above calculation it is clear that theoretically by using a fully charged 3000 mAh Li Ion battery we can run the arduino for 15 months.In practical due to battery self discharge this figure may be different.
As the system is equipped with solar charging system ,we can run for few years without any interruption.
I hope you enjoyed by reading my tutorial.Please comments if any mistake found.
This project is entered in 3 competitions,please vote for me.
Thank you so much.
3 People Made This Project!
  • Warm and Fuzzy Contest
  • Comfort Food Challenge
  • Safe and Secure Challenge
174 Discussions
CaprofH
Question 6 months ago
can you help me for project arduino uno+vibration sensor (sw420)+ask 433 MHz+ lcd.? please.!
frava92
Question 8 months ago on Introduction
Hi. I was wondering (and it's probably a stupid question but...) if the systems would work even though there is no sun (a very cloudy day or during the night).
Thanks
Zygmunt docent
8 months ago
Hello
I made this project on the BME280
sensor.
Temperature and humidity are working
properly.
However, the pressure
reading on the LCD is bad.
I spent a few days
trying to solve the pressure problem, but it's still bad.
I can not deal with it.
I will add that I am
weak in computer science and programming.
Please help.
If you can, I would ask for the
transmitter and receiver program code for the BME280 sensor
Regards
Zygmunt
SimonQ1
1 year ago
Thank you so much! Its very useful! Keep it up!
JakubC28
1 year ago
Hi guys I ve got a problem it says this what I can do?
In file included from C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:22:
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:35: error: expected class-name before '{' token
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:38: error: 'sensors_event_t' has not been declared
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:39: error: 'sensor_t' has not been declared
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:47: error: expected class-name before '{' token
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:50: error: 'sensors_event_t' has not been declared
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:51: error: 'sensor_t' has not been declared
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:73: error: 'sensor_t' has not been declared
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\/DHT_U.h:74: error: 'sensor_t' has not been declared
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:35: error: variable or field 'setName' declared void
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:35: error: 'sensor_t' was not declared in this scope
C:\Users\uzivatel\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:35: error: 'sensor' was not declared in this scope
HeinrichW4
1 year ago
Hello!
I have something similiar in mind where a sensor detects if there is wind and sends it back to your smartphone so that you can prevent damage to your sunshade.
Do you think the solar panel can sustain an arduino with wifi shield?
schoenes_berlinHeinrichW4
Reply 1 year ago
check out the new Arduino MKRFOX1200. Probably Sigfox is available in your region.
MarvinS41
1 year ago
when using nimh's.. how do I connect users? Parallel?
MuhammedS31
1 year ago
Hello sir. Can i use 1s 3.7v li-po instead of 18650 li-ion?
MarcinK84
1 year ago
Hello,
thanks for the work.
Could you please precise how many Wats photovoltaic cell is most suitable for this project?
Many thanks.
VictorG111
2 years ago
I have a problem!!!
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
sketch_sep15a:39: error: 'POSITIVE' was not declared in this scope
sketch_sep15a.ino: In function 'void setup()':
sketch_sep15a:49: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
C:\Users\ADMIN\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76: note: candidates are: void LiquidCrystal_I2C::begin()
sketch_sep15a:61: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
I need a help!!!
solar767Tstef
Reply 1 year ago
I have same problem too(sorry, I can't speak English well)
exit status 1
I just followed the system you gave.
Setup librarys...
but... Why did I get error?
barengaguensolar767
Reply 1 year ago
reeplace this code line by LiquidCrystal_I2C lcd(0x27, 20, 4);
robotjam
1 year ago
Hello, I am new to these Arduino things and I think this instructable is perfect to help me learn. First thank you for posting this. I am fully following your instructions letter for letter. I do have a question (besides the fact that I am having some problems with the sketches). My question is about the accuracy of the completed solar powered transmitter. Where is it placed outdoors, in the sun or in the shade? My concern is the whole transmitter circuit is enclosed in a plastic box, wouldn't there be excessive heat build up? Would this project be accurate if I placed the box in the shade and ran a power wire to the solar panel located somewhere close but in the sunlight?
Again thank you for this great instructable.
tomas.stiborsky
2 years ago
Hello, Can i have some practical electronics question ? Can you explain me why you use Diode -IN4007 in this circuit ? Is it mandatory ?
Tsteftomas.stiborsky
Reply 1 year ago
Yes, it essentially makes a one-way connection between the solar panel and the battery. Current can flow from the solar panel to the battery but cannot flow from the battery to the solar panel.
Kalamar102tomas.stiborsky
Reply 2 years ago
Hi. This diode is necessary to place, because if it is not placed and there is a shadow on the panel, this consumes energy. That is, if there is a stain on the panel, that part of the panel will consume energy. With the diode we get that it can not consume.
maniolx
1 year ago
Hello . I did this project, but I used DHT22 and much more accurately measured. Tell me what it is "HI" on the display, because the project has no other sensor than DHT and it shows some strange values.
nikil14
2 years ago
I liked your project, you can also upload to a cloud server and monitor wirelessly by using iot application platform such as thingspeak.com
