Sailboat Living (+short Term Rental)
About: Building design/consulting in SE Minnesota. Resource based problem solver... in other words, I always take a minute to peek in construction dumpsters :) ---the way some have to workout everyday... i have to...
A boat anywhere is incredible!
Having it as a floating Tiny Home (and a place to rent out) adds a whole other dimension!!
In 2014, I converted a boat that had sat for 10 years in Madison in Wisconsin into a tiny home along the Chicago Riverfront. The boat paid for itself and the mooring in only a couple of months on airbnb (a 2016 ordinance makes boats illegal to airbnb in chicago :)
Here's how I transitioned my boat into a home.
Step 1: The Boat
The boat had spent 30+ years on the water in Madison Wisconsin. I named the boat Monona for the lake where it was kept before it landed in storage for 10 years.
The trimaran is a 1978 Tristar 25. A 25 ft boat with a 13' beam. Incrediblely it only has an 18" draft. An Ed Horstman Design, a book of plans are available on amazon to build your own!
I was the third owner and loved that two boat builders had owned the boat before me. Even still I had a series of project to make the boat sea worthy. Including patching wholes in both the pontoons. --the boat is a trimaran with a main hull and two side pontoons.
Step 2: Interior Refresh
Interior and cockpit both needed a lot of attention.
Here is my process for the refresh:
  1. Sailing Equipment - move to the three main drawer or milk crates and offload
  2. Cushions/Fabric - wash all materials. bleach all foam. allow to sun for 2+ days.
  3. Wood Boards (flooring/drawers/bed surfaces) - remove/wash/paint
  4. Deep Clean - all interior surfaces with a soapy water or bleach solution
  5. Paint - interior wood that is already white
  6. Epoxy - use a West Systems 207 Epoxy to coat/protect all exposed wood. The 207 protects against UV damage and lasts more than one season.
  7. Sink/Stove/Cooler - clean everything thoroughly. For the stove I cleaned all components in white gas and found new gaskets in the drawer.
  8. Electrical - disconnected panel and installed a new battery with 15 watt solar panel. (mine was from harbor freight. this 20 watt model with controller looks like what I would purchase today)
  9. Lighting - interior lights were in standard outlets with 12v bulbs. A separate string light system rain between one of the deck supports.
  10. Head - cleaned up the existing portable toilet, looked like this model. I thought I'd need to replace but it worked fine. Their was also solution already aboard.
Step 3: Bedroom
The interior provided for two twin beds. One could easily be used as a storage/living area as you'll see in the next step.
Step 4: Living Space
It is comfortable to stand for a person up to 5' 10" in the boat. The windows ring the interior and makes for a very comfortable space. Both beds can be folded back to make a very open living room.
Step 5: Galley
The entrance from the cockpit drops you right into the galley. Some of the earlier photos showed the details of the stove and the sink at each side.
Step 6: Detailed Shots
For hosting I would prepare a few items for guests. you can see how I provided one sink basin of essentials and a welcome basket. The guestbook received over 80 write-up that first summer.
Step 7: Living on the Water
Living on the water is something I miss. If you have the chance or can pull together a Tiny Home of your own in a marina I highly recommend it!
Certainly a bit of effort if you are like me and don't want to pay a premium.
Hope you find this post useful and that it's easier for you to get on the water!
Thanks, Jeff
Considering Airbnb? Here's my referral code, www.airbnb.com/c/jeffp440
----as of Sept 2018 you receive $40 off and I receive a credit of $20. Cheers!!
Message direct if you have any questions about the process of cities legislating against airbnb. I found it frustrating to get good information but learned about the process in Chicago.
Are you following me on Instructables?
Join 190+ members by clicking the button on my profile page!
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
