Salvaging Liquid Crystal Displays (LCDs)
496,379
2,607
320
About: I am a photographer, a tinker, an electronics technology engineer, and author; I write short stories and poetry for the love of writing. I started writing poetry in high school over thirty years ago where I ...
Almost all electronics have some sort of human interface, from blinking lights and beeping speakers to seven segment alphanumeric and Liquid Crystal Displays. This Instructable is about salvaging and testing Liquid Crystal Displays, and a couple tricks I know to make salvaging them more successful.
I salvage; components can get expensive, LCDs can run $10.00 and up even SCRs and mosfets can cost over $100.00 so I salvage everything of reusable value as well as recyclable. Scrap metals like copper, gold, silver, and aluminum can bring you money as well.
Liquid Crystal Displays can be found on CD players, Phones, and printers just to mention a few. In this Instructable I will be dissembling an HP combination printer, scanner, fax machine.
Supplies:
Step 1: Tools & Supplies
Assorted Phillips Screwdrivers
Assorted Torx Screwdrivers
Assorted Pliers
Side Cutters
Spring Loaded Tweezers
Large Soldering Iron
Small Soldering Iron
Utility Knife
Dremel Set
Arduino UNO Kit
Wires
Solder
Goop Glue
Step 2: Disassembling a HP Psc 750xi
Printers & scanners are simple to dissemble, just remove the screws and take out the parts most of the screws are under the lid, on the back, and on the bottom of the printer & scanner.
Even when the screws are removed the plastic housing panels are clipped together with tabs holding them in place. Work your way around the individual panels to find the tabs and unclip them. Plastic is recyclable and some plastic recyclers pay for the plastic so don’t just throw the plastic in the garbage.
The control module of the printer scanner contains the control buttons and the Liquid Crystal Display. It dissembles by removing the five screws on the back.
I sort the parts into two groups Electronics to be stripped for parts and gold, and mechanics like guides, gears, and stepper motors.
Remember metal is recyclable and almost all recyclers pay for scrap metal so if you don’t keep it sell it.
Although the LCD module looks different than the other TN STN FSTN LCD modules in this Instructable it is connected the same way when testing.
Step 3: Chip on Glass Liquid Crystal Displays (COG LCD)
Chip on Glass (COG) LCDs have the driver IC on the glass near the input pins or ribbon connector (The rectangle on the glass near the pins & ribbon) and they come in serial data input as well as parallel data input like TN, STN, and FSTN modules. Many of the serial data input COG LCDs have the same number of pins as the parallel data input LCDs, so with COG LCDs the datasheets are more important as the inputs purpose is not easy to see when you are just looking at the LCD.
As well as the attached datasheet here is some pin outs for COG displays, many of the data sheets have the Display in the part number such as, S161COG, 16x1 COG display, S162COG, 16x2 COG display, and 64128L 128x64 graphic LCD display.
The contrast circuit for COG LCDs is the same as the contrast circuit as TN, STN, FSTN module.
Pins Right to Left
8 Pin 16x2 Character COG LCD
PIN SYMBOL FUNCTION
1 VOUT DC/DC Converter Out
2 VC Capacitor Positive (-) side
3 VCC Capacitor Negative (+) side
4 VDD Power Supply for Logic
5 VSS 0 Volts Ground
6 SDA Serial Data Input
7 SCL Serial Clock
8 RST Reset Signal L = Active
PIN SYMBOL FUNCTION
1 RST Reset Signal L = Active
2 SCL Serial Clock
3 SDA Serial Data Input
4 VSS 0 Volts Ground
5 VDD Power Supply for Logic
6 VOUT DC/DC Converter Out
7 VC Capacitor Positive (-) side
8 VCC Capacitor Negative (+) side
Displaytech 14 Pin 16X2 Character COG LCD
Pins Left to Right
PIN SYMBOL FUNCTION
1 VSS 0 Volts Ground
2 VO Contrast Adjustment
3 VDD +3 or +5 Volts Power Supply
4 RS Register Select Signal L = Instruction H = Data
5 R/W Read/Write Select Signal L = Write H = Read
6 E Enable Signal
7 DB0 Data Bus
8 DB1 Data Bus
9 DB2 Data Bus
10 DB3 Data Bus
11 DB4 Data Bus
12 DB5 Data Bus
13 DB6 Data Bus
14 DB7 Data Bus
Step 4: Salvaging COG LCDs
This printer display is parallel data input to the circuit board and parallel data input to the COG LCD, I know this by reverse engineering the circuit board and checking the components datasheets.
I like to get my datasheets from these two web sites:
http://www.maxim4u.com/
http://www.alldatasheet.com/
You can just pull the LCD however finding just the right ribbon socket can be hard, so the only part I need from the circuit board to use this COG LCD else where is the ribbon socket. (Inside the yellow rectangle) I do this by placing my large soldering iron on the back of the circuit board and when the solder melts I lift off the socket.
Step 5: TN STN and FSTN Liquid Crystal Display Modules (LCD Modules)
TN STN and FSTN LCD Modules vary in appearance but most have similar pin outs, these pin outs should operate most TN STN and FSTN LCD modules.
10, 12, 14, and 16 Pin
8x1, 8x2, 10x1, 10x4, 16X1, 16X2, 16x4, 20x2, 20x4, 24x2, 40x2 LCD
PIN      SYMBOL      FUNCTION
2             VDD         +3 or +5 Volts Power Supply
3              VO           Contrast Adjustment
6               E             Enable Signal
7             DB0          Data Bus
8             DB1          Data Bus
9             DB2          Data Bus
10           DB3          Data Bus
11           DB4          Data Bus
12           DB5          Data Bus
13           DB6          Data Bus
14           DB7          Data Bus
15          A/Vee        Backlight Anode +4.2 Volts
16             K             Backlight Cathode Power Ground
Step 6: Testing 16X2 TN, STN, FSTN 16 Pin LCD Modules
I use Arduino to test the modules and check the functions to make sure they work properly, this is the hookup and code for the 16x2, 16 pin LCD.
You can copy and paste the code below into sketch:
  LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display.  The LiquidCrystal library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
  The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
void loop() {
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
Step 7: Code for the 16x1 LCD
Using Arduino to test the 16x1 modules and check the functions; I found that the 16x2 code needed to be modified because the IC looked at the 16x1 LCD as two lines and all you see is the first eight segments of the display.
This is the code for the 16x1 14 and 16 pin LCD.
Demonstrates the use a 16x1 LCD display; the LiquidCrystal library works with all LCD displays that are compatible with the Hitachi HD44780 driver. There are many of them out there, and you can usually tell them by the 16-pin interface however these are 16x1 LCD, 14 pin interface.
This sketch prints "Hello World!" to the 16x1 LCD.
void setup() {
  lcd.begin(8, 2);     //is 16x1, adressed as 8x2
  lcd.setCursor(0,1);  //init right hand side
  lcd.home();          //back to start
  lcd.clear();
  lcd.print("hello wo");  //print left side
  lcd.setCursor(0,1);     //go to right
  lcd.print("rld!");      //print right side
  //blinking cursor
  lcd.cursor();
  lcd.blink();
void loop() {
Step 8: Testing 16X1 TN, STN, FSTN 14 Pin LCD Modules
Using Arduino to test the 16x1 modules and check the functions I used this hookup and code for the 16x1 14 pin LCD.
void setup() {
  lcd.clear();
  //blinking cursor
  lcd.cursor();
  lcd.blink();
void loop() {
Step 9: Testing 16X1 TN, STN, FSTN 10 Pin LCD Modules
Using Arduino to test the 16x1 10 pin modules again I found a few differences; the same code used for the 16x1 14 pin is used for the 10 pin LCD, this is the hookup and code for the 16x1 10 pin LCD.
void setup() {
  lcd.clear();
  //blinking cursor
  lcd.cursor();
  lcd.blink();
void loop() {
Step 10: Salvaging Other LCDs
This graphic LCD has everything needed to reuse it in a project.
It just unplugged from the rest of the electronics.
The driver is on the circuit board.
And the hookup is function labeled.
However not all LCDs are this easy to salvage.
Step 11: Salvaging a Compact Disk Player LCD Display
This circuit board came from a compact disk player; I start by tracing out the circuitry and looking up the LCD driver IC. The IC is a PT6533 general purpose LCD driver this part is important and it makes salvaging the LCD easier, other than the backlight LEDs the driver and the LCD are separate from the push button switches. Now I know what I need to cut away from the circuit board to salvage the LCD.
Step 12: Preparing the Circuit Board
Now that I know what I want from the circuit board, I start by desoldering all the unwanted components and removing the components. I desolder by melting the soldered joint with my 35 watt soldering iron and taping the edge of the circuit board on my work bench, casting off the molten solder.
Next I mark the conductors I want by color code and remove all the unwanted circuitry by scraping the conductors with a utility knife.
White for data input
Yellow for clock
Blue for clear enable
Black for ground 0 volts
Red for 5 volts the LED backlight
Orange for 3.3 volts IC power
Step 13: Cutting Out the LCD
Be careful during this part; safety glasses and heavy leather gloves, while I was shaping this circuit board the dremel jumped and hit my hand cutting my thumb through the leather gloves causing me to get three stiches. It would have been worse had I not been wearing the gloves.
After removing the unwanted circuitry I cut the circuit board to the shape I want with my dremel leaving a tab for mounting the LCD.
Step 14: Adding the Wiring Harness
I start by selecting a six wire; wiring harness with wires color coded the same as I marked the conductors.
Yellow for clock
I scrape clean the ends of the conductors and solder the white wire to the white conductor and so on until all six wires are soldered to the circuit board.
Although the wires are soldered in place with movement they can break free from the circuit board. To prevent this I glue the wires in place with Goop glue and wait 24 hours before testing.
Step 15: Testing the New LCD
Many of the members at Instructables and our visitors use Arduino and Raspberry Pi for their projects. I connected the new LCD to my Arduino UNO, the LED backlights work but I am still working on the Arduino code to run serial input LCDs.
Hardware Hacking
Finalist in the
Hardware Hacking
20 People Made This Project!
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
320 Discussions
VSS2ceo
Question 11 days ago
I keep trying to download pdf. and every time I click download a window opens telling me to verify my email. I do and then the same thing happens when I try to download again. Can anyone help me out of this loop? Please, I'm getting dizzy! :-)
1 answer
Josehf MurchisonVSS2ceo
Answer 9 days ago
Are you a pro member?
You need to be a pro member to download PDFs.
bodi069
3 months ago
Dear Josehf
Thank you very much for your interesting and usefull manual!
I have 2 displays (pictures attached) with diefferent number of of pins. Both of them have a blue background light with 3 Volts (2 x AAA).
1st Display have 14 PINs and is a 2 x 16 (one can see the spaces). On the back is writtern "ASI-G-162DS-GF-EWSR/W *W 7061" - picture 1 & 2 ("DISPLAY_A1.jpg" and "DISPLAY_A2.jpg")
2nd Display have 9 PINs and is a 2 x 8 (I see that spaces in the display). There are some writings on it but no one made sense to me ... . Pictures 3 & 4 ("DISPLAY_B1.jpg" and "DISPLAY_B2.jpg")
I am very happy about every hint for a pinout ...
Cheers
Chris
Josehf Murchisonbodi069
Reply 3 months ago
The first displays part number is PC1602 you will see it on the top left of the first pic
Go to this web sight:
Enter PC1602 in the part number and click on search.
Download PC1602-J that is your 14 pin.
The second display look for letters followed by the numbers 0802 or 802 that should be your part number.
JonathanP51
3 months ago on Introduction
Hi Josehf, thanks for the awesome information, I'm trying to use a 16 x 2 lcd salvaged from a alarm keypad, it has 15 pins and what seems to be a separate backlight, any ideas for pinout and what voltage the backlight could be,
Thanks again
Josehf MurchisonJonathanP51
Reply 3 months ago
The back light should be no more than 3 volts 10 mA.
Most COG LCDs are 3 to 5 volts, start at 3 volts and Pin 1 is to the right.
1 VSS
2 VDD
3 VO
4 RESET
5 RS
6 R/W
7 E
8 to 15 DB0 to DB7
TimothyP3
3 years ago
I have a chip on glass display that is from a Brother 560 fax the manual is here : https://www.manualowl.com/m/Brother%20International/FAX-560/Manual/272893 . the display is on the control board connector P3 the part numbers will not cross so no data sheet. The display has 6 pins two are for power and one for contrast the other pins are labeled but blurred. one appears to be data, one clock but the third looks to be STO or STQ. would you take a look at the manual and see if you can figure out the pins? Tim wa0psq@hotmail.com
IntegratedETimothyP3
Reply 3 years ago
Hello
I have the same 6-pin LCD coming from a fax machine with L303646 marking and I guess it's something like ST7032 or PCF2119x chip on glass controller. But the only problem I have is for the pinout... It came with a little PCB with the following markings: CMKM-P3X B53K463-1 and this PCB has two connectors labeled SEN1 and SEN2, maybe connected to optical sensors. On the LCD i've identified power lines, 2 connected to GND and 1 connected to VCC. The three other line are obviously SDA, SCL and contrast, but these lines are connected to an unknown IC labaled PNL7 LG2563 0039 M59 and I didn't found any info on it, I think it's a proprietary MCU or I/O expander.
tony-arduinoIntegratedE
Reply 7 months ago
Probably a bit late to be helpful for you, but maybe someone else will find this thread ... The LCD has a 3 wire SPI interface 1-DATA, 2-CLK, 3-STB, 4-GND, 5-+5V, 6-GND. So the third pin, STB, is basically a device select signal. Pin 4 (or 6) may also be a signal line, but is grounded on that board. There's a little more info, including an initialisation sequence at http://projects.scorchingbay.nz/dokuwiki/electronic/lcd/b53K4631. The CoG controller is basically a serial SPI version of an hd44780 type chip. (SEN1 and SEN2 are for mechanical paper-out etc switches, PNL7 is a custom programmed IC, basically throw away the B53K463-1 PCB but unsolder the flex cable socket first!)
Josehf MurchisonIntegratedE
Reply 3 years ago
Sorry for taking so long to reply, I was helping a friend with his job last night and was sleeping.
The LCD is a BTHQ21605V
you can get the datsheet here:
You will find many custom ICs marked LGXXXX just have a custom prefix, all you need to do is figure out the right prefix. You can find the prefixes in this Instructable in the IC color codes.
https://www.instructables.com/id/From-Resistors-to-...
You might like this site for datasheets also.
You might like this one for SMD parts.
http://www.s-manuals.com/smd
With many SMD ICs marked MM74LS04 are SN74LS04 and the pin outs are the same.
You should check out my Instructables on reverse engineering.
IntegratedEJosehf Murchison
Reply 3 years ago
Thank you for your reply
But my LCD is in the upper right corner of the first photo, the small LCD with a flat flex
IntegratedEIntegratedE
Reply 3 years ago
But maybe it's the same controller with the same pinout on the 6 pin connector.
Sorry if I don't speak english very well, I'm french!
Reply 3 years ago
My mother was French Canadian, I have a great poem of what she would say when she got mad half English half French.
Yes it is the same pin out and controller of the LCD in the upper right corner of the photo in step 3. and second from the top right in the intro. It is the only 6 pin COG LCD in my Instructable.
Reply 3 years ago
Josehf MurchisonTimothyP3
Reply 3 years ago
I can't read the manual at all.
My guess is it is reset, different LCD makers use different terms for reset and contrast. Batron uses POR for reset.
VLCD LCD driver voltage
VSS Ground (0V)
VDD Power supply for logic.
SDA I2C serial data input/output
RS External power –on reset input. Active High or Low depending on maker.
SCL I2C serial clock input
TimothyP3Josehf Murchison
Reply 3 years ago
Thanks I try that I will use an arduino uno's sda and scl pins and try the reset set to high if that doesn't work I'll pull the reset down to low. thanks for the help. the display is just the correct size for a project I'm doing.
Reply 3 years ago
VSS Ground (0V)
dancopy
2 years ago
I have a TFT color LCD which was removed from the control panel of an HP Photosmart C4280 printer model; I would be using it with Arduino but do not know their pinouts and therefore do not know how to use it to Arduino. If anyone knows I would greatly appreciate it!
sinamirusdancopy
Reply 11 months ago
hello, I recovered the same card with the 2 screens and I would like to use them with arduino. if you have a track or a beginning of work on this project I would like to have notions on what you did (documentation, image, video ... etc)
also, here is my email in case you can not display here video or other things. I thank you in advance for your help.
cordially
