Santa's Elves Yard Display
197,413
310
60
After years of Christmas plywood cutout characters, we decided to follow the 3D trend and build some happy elves for our yard this year.
The elves are wooden skeletons with newspaper pressed and taped all around to form the shapes.  Two coats of paper mache, bits of clay added, gesso, paint, and waterproofing and they are ready for display!
Step 1: Materials and Tools
The basic materials are:
2x2, 1x2, 2x4 lumber
dowels
newspaper
masking tape
posterboard
brown paper bags
paper mache - we use PlayBOX wheat paste 3lbs
paper clay - Creative Paper Clay Co.
gesso - Liquidtex surface prep
wrapping paper
decoupage - Mod Podge
Drylok Extreme Masonary Waterproofer paint without sand (UPDATED 12/2013)
Acrylic paints
Krylon acrylic crystal clear satin spray paint for waterproofing
Basic tools:
Craftsman jigsaw with foot switch
drill with large bits
paintbrushes
medium fine sandpaper
hot glue gun
For the animated elf spinning package:
gear motor - Solarbotics GM21 $20
1/2" PVC pipe
Copper pipe
2 scavenged scooter bearings
5/16" plain steel rod
5/16" ID steel coupler
14ga steel sheet 9"x9"
Styrofoam brick
2 AA batteries and holder
hot glue and gun
misc washers, allen set screws, hookup wire
Step 2: Skeleton
Build a skeletal structure for your happy little elf out of 2x2 and 1x2 pine.  The feet are 2x4 pine for weight and stability.  The joints are pinned with dowels and wood glue.
The arms and legs are 7/8" hardwood dowels.  They are pinned and wrapped with paper mache strips of grocery bags.
Step 3: Filling the Frame
Lots of newspaper and masking tape!
Shape the body, head, arms, hands, and feet by crumpling up newspaper and taping it to the skeleton. You can round out things with more tape.  More tape is always the answer!
Add elements like hats and collars with heavy posterboard paper. Check eye positions with colored paper cutouts.
Make it pretty firm so it will keep it's shape when paper mache'ing in the next step.
Step 4: Paper Mache
Tear brown supermarket paper bags into strips. Do not cut them, you need the feathered edges from tearing. Bigger strips for the body and smaller for around fingers and ears.
Mix up batch of wheat paste per the instructions on the package. You can cover it and store it between sessions.
Dip the strips in the paper mache mix to coat both sides and lay down in random directions. Cover the entire elf.
Let dry then do a second complete coat of paper mache on the elf.
Use paper clay on the face, especially to pop out the eyes. On the hands to smooth them, and on the big buttons to give them dimension. Sand the paper clay lightly for a nice finish.
Step 5: Gesso and Paint
To smooth the elf, apply 2-3 coats of gesso then paint it with waterproof basement paint (UPDATED 12/2013). The basement paint has really held up on other outdoor projects.
Use the small containers of acrylic paints common in craft stores or larger bottles from big box stores.
The present was made by just taking a cardboard box and taping it closed, paper mache, then decoupage Christmas wrapping paper to the box with Mod Podge. You can make a bow out of posterboard.  The bow was paper mache'd and painted.
Step 6: Animated Spinning Present
A spinning present on one of the elves finger was done with a small mail-order motor, batteries and some mechanical parts.
I bought a gear-drive motor from Solarbotics, 360:1 gear reduction that seemed
to spin at a nice rate with 2 AA batteries.
The motor fit nicely in some spare PVC pipe.  I hated to load the motor with the weight of the present, even though it would be made out of styrofoam, so I scavenged two bearings from a defunct scooter that were the same outside diameter as the PVC and slipped them all in a piece of copper pipe with some spacers.
To join the motor to the present, I drilled a 5/16" piece of plain steel and tapped a set screw to hold it to the motor shaft.  Then I brazed a collar on the shaft and brazed that to a piece of sheet metal that was lightened with holes.
Two halves of styrofoam were hot glued around the sheet metal and wrapping paper was decoupaged around the styrofoam.
The whole assembly fit into the elf's finger nicely, the hand was made to be removable.
I added a piece of a ping pong ball to round out the fingertip and shield the motor assembly.
Step 7: Protective Finish
To make this even more waterproof, we sprayed the elves with a couple coats of Krylon indoor/outdoor clear satin acrylic spray paint.  Be sure to paint outdoors on a drop cloth with several light coats. Paint the presents too.
Water poured on the elf beaded up nicely so the are ready for our outdoor display. They have lasted 3 seasons now but we cover them in heavy rain (UPDATED 12/2013).
Krylon Holiday Decorations Contest
First Prize in the
5 People Made This Project!
  • Warm and Fuzzy Contest
  • Organization Contest
  • Paper Contest
    Paper Contest
60 Discussions
veronika1972
3 years ago
I love these elves and trying to make them,having an issue with the hands can you give me some directions..Thank u so much
blipvertveronika1972
Reply 3 years ago
Hi- I just roll a tube of newspaper for each finger and sandwich it between two scrunched up flattened balls of newspaper. Then tape everything to hold it in place so the fingers look nice. A flattened bunch of newspaper for the cuff is taped to it and the wrist dowel is pushed through. Page 3 photos 3 and 4 can be enlarged by clicking on them to see a closeup. Enjoy!
KaitlinE3blipvert
Reply 2 months ago
Could you maybe blow up some rubber gloves a bit and paper matches them then pull the glove out and add to the frame and secure?
blipvertAngelaM234
Reply 3 months ago
That turned out great. What fun to see it. I am glad you sent us a picture.
StephanieP153
Question 5 months ago on Step 2
Does anyone have the length dimensions for legs arms and torso?
gkwylie
These are awesome! Do you happen to have plans for the skeletons for each elf? Thanks!!
Dclow
Question 1 year ago
Sorry to ask a few more..did you put the gesso on before the paper clay? Thanks again!
Dclow
Question 1 year ago on Introduction
Hello! These are remarkable elves! Did you put the buttons, clothing, hat etc. On and then paper mache over these? Thanks!
1 answer
blipvertDclow
Answer 1 year ago
I am glad you like them. The buttons and most of the clothes are just painted. The hats and collars are cardboard that I paper mached.
blipvert
2 years ago
Side views requested by user:
Kieran 4330
2 years ago
Hello i am wanting to make this will it be able to sappor hairy rain
Nanasworld
2 years ago
I just found this website, new to it. I just typed in paper mache and when I saw these, I just laughed. I love whimsical, the more whimsical the better and these are just fantastic!!! I have never paper mached before and I think I would love it, so going to start small and move up!
SusanH75
3 years ago
Totally amazing. Wow
shew1
3 years ago
these are just beautiful but will they withstand our cold wet Oregon weather?
blipvertshew1
Reply 3 years ago
I undercoated them with masonary sealer paint which makes them hold up pretty good in the weather. Some people say marine varnish works well. We live in California so they have never been tested in really cold rainy weather.
