Scissor Lamp Ikea Hack
19,028
345
15
I really love scissor lamps, because they give a room an aura of quirkiness, a bit like it was the workshop/lair of a mad scientist. Also they are very functional, because they make it easy to direct light to the spot where you need it, without lighting up the whole room. This is especially helpful if you like reading at night.
Although I live in germany, where the designers of the Bauhaus came up with a lot of classic scissor lamps in the 1920s and 1930s, I could never afford one, because they are quite expensive.
Then I stumbled upon a really cheap pantograph mirror called "fräck" (no relation to the oil-drilling-procedure) in an ikea store. I imedeatly had the idea to turn it into a lamp. There are already two very nice instructables using the scissor arm from the "fräck" ikea mirror (1 / 2).
I hope you will like my Instructables and I´m looking forward to your feedback or questions!
Step 1: Tools and Materials
Materials needed:
- scissor arm from an Ikea "Fräck" Mirror (costs $4.99 / €2,59)
- classic clamp-on lamp with a ball joint
- metal ball with a blind hole thread size M6 (available in online lampsupply stores. If you´re not sure about the thread-size, take the scissorarm to a hardwarestore and try out different standard nuts to find ot the right size)
- two 6 mm wall plugs ( ≈ 1/4 inch)
- two small screws (fitting the wall plugs)
Tools needed:
- drill
- 6 mm drill bit
- screwdriver
- one piece of paper
- adhesive tape
- pencil
As soon as you have all the tools and materials at hand, you won´t need longer than one hour for this project.
Step 2: Modify Lamp and Scissorarm
Unscrew the clamp-on lamp from its ball joint and screw the metal ball onto the thread of the scissor arm.
Step 3: Prepare for Drilling
Mark the positions of the drillholes for the scissor arm. To prevent a mess, use the paper and adhesive tape to fold a little pouch for catching the bore dust. Stick this pouch right under the spot where you want to drill.
Step 4: Drill and Install the Scissorarm
Drill the holes, insert the wall plugs and screw the scissor arm to the wall.
Step 5: Attach the Lamp
Attach the lamp to the scissor arm, lead the cable through the end of the scissor arm that is closest to the wall and plug it in. In addition, you can fix the cables to the scissorarm with zip ties if you like.
Step 6: Enjoy!
I added a second identical lamp on the other side of my desk. The lamps can be adjusted precisely to the position and and angle needed. Because of this, I don´t need any big lamps that consume a lot of energy (save the planet y´all!).
Most important: The shadow-free desktop is helping me to keep focused for longer during nightlong reading sessions, especially in winter :)
I´m happy two answer any questions you might have.
If you like my Instructable, you can vote for it in the Make It Glow Contest!
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
15 Discussions
dr_peruBartholomewH
Reply 3 years ago on Introduction
Thanks for the comment :)
I think they are already cconsidering this. But not too long ago, Ikea also considered sueing a popular ikea-hacks website. Also, selling kits for hacking would stop it from being a hack. If you can buy a kit, it is just consuming and not doing anything new on your own - where would be the fun and creativity in that?
TechDante
4 years ago
Could I just flip the rod over and attach the lamp to the ball on the other end and use a rounded nut to capture rod on the scissor arm
dr_peruTechDante
Reply 4 years ago on Introduction
At first I tried it this way, but the ball on the other end of the rod is too small for the lamps I used, even when the parts that should take grip on the ball are bent together a bit more. Thats why I bought the screw-on-balls.
If you cannot find those balls, you will probably find another fine solution - theres always several different ways to tackle a problem ;)
dr_peruduncan_a
Basically all classic clamp-on lampswith those typical big and curved wire clamps that ar fixrd to the lamp with a kind of ball joint will work.
I found mine for a very reasonable price on "ebay kleinanzeigen" ( That´s a site run by the german branch of ebay, on which private sellers can offer items for free. It´s kind of like craigslist, but only for selling stuff).
You should not use a lamp that is too heavy though, because it might put too much stress on the scissor arm and bend down all the time.
duncan_adr_peru
Difficult items to find where I am - I'll spend a bit of time on eBay or Amazon...
Thanks
sursula
great stuff as always, dr. peru! with these lamps installed our home is even nicer than before!
chefmichel
Very cool idea, well done !
Now looking for an hack-idea to use the mirror.
seamster
Very clever idea!
These are pretty cool looking, plus they keep the top of your desk/work space clear... no lamp bases in the way. Nice!
