Powerful Shocking Device
16,624
29
48
this tutorial show you how make a powerful Leyden Jar which take the static electricity of your computer screen or tv and tranform it into a powerful shocking device.It s cool just to watch.
-plastic container
- 2 copper wire 8 inch long
- 3 foil of aluminum
-plastic lid
-round nut
-scotch tape
Supplies:
Step 1: Inside Part
Cut a rectangular piece of foil large enough to line the cannister.place inside the cannister.Try and keep edges of foil smooth and straight, or they will "leak" charge. Make a bottom too.On this bottom, stick a 8 inch wire.put this bottom into the canister.
Step 2: Outside Part
Now cover the outside of the cannister.Again, avoid rough edges, and make sure the foil doesn't get in the way of the lid.Cut a second piece of wire about 4-5cm long and strip both ends.
Tape one end to the foil on the outside, so that the other end can be easily curved around to meet the other wire .
Step 3: Interceptor
now take a few cue tips (static interceptor) and place in a star shape.Make sure it touch the wire !
And place a round nut just on top.(Make sure it touch the wire too)
Step 4: How It Works
Let your leyden jart beside your screen for 5 -10 minutes The electrical static charge will be transfered, positive and negative charges accumulate from the two metal coatings respectively, but they are unable to discharge due to the glass between them. The result is that the charges will hold each other in equilibrium until a discharge path is provided. Leyden jars were first used to store electricity in experiments, and later as a condenser in early wireless equipment.
have fun but be careful it' s not a toy .
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    48 Discussions
    turner22
    11 years ago on Introduction
    I might make one with like a film can or something. would it work? This is a really cool design.
    It would PHYSICALLY work, but I do not believe you would see the discharge, as you need the size of the can to absorb the energy
    actually, I made a jar from a film can, and I definetly saw the discharge. it was smaller, but you could definetly see it. also, I was gathering electricity from a tv that I got from my grandma, so it's static is huge. it was jumping between the walls of the jar because it gathered so much.
    rocketman221turner22
    use a plastic peanut butter jar those work good, but be careful they can store a lot of power
    freeza36
    7 years ago on Introduction
    so the qtips gather static electricity? I made kitemans Leydon jar, but the only way to charge it was to rub it against the tv screen.
    I connected mine to the outside towards the bottom, just make sure youfan out the wire a little it seemed to work better that way.
    jjohnson0038
    9 years ago on Introduction
    This was a great project I used a peanut butter jar. Can I tape down theq-tips to keep them from falling off or will that interfere withabsorbing the static? I placed it in front of an old tv and it tookawhile before gaining any charge. I'm going to try an old monitor I havethis weekend. Thanks
    bjornacorn
    Mine is not working. Do you have a trouble shooting or some thing. I need help. Awesome instructable by the way.
    if you put al foil on the tv screen it will charge easier no running around trying to gather all the static.
    kizzy_dude
    Does it have to be a lugnut or can you juse use a regular nut, like the normal hexagon shaped nuts? Or could you just loop the wire on the end...
    geoslim13
    i am making one for my school science fair and i was wondering if i can just put a screw in the cap and connect the wire to it
