Secret Candlestick Switch
48,417
874
4
About: My name is Jason Poel Smith. In my free time, I am an Inventor, Maker, Hacker, Tinker, and all around Mad Genius
No feature in a home captures the imagination like a secret compartment or secret passage. But no secret compartment is complete without a secret way to open it. So today, I am going to share with you several ways that you can use a simple hanging candlestick to access the hidden secrets in your house.
Step 1: Decide on a Kind of Secret Compartment
There are a lot of different kinds of secret compartments that you could implement. You can find a a number of great examples on the Instructables collection: Secret Doors, Drawers & Compartments. You can use a regular door and disguise it to look like something else. You can make a whole bookshelf that rotates. You can create false walls. The possibilities are endless so use your imagination.
Pictures above are from:
Stryker @ https://www.instructables.com/id/The-Mysterious-Bookcase/
The Goose @ https://www.instructables.com/id/BOOKCASE-DOOR-THAT-REPLACES-YOUR-DOOR/
flaming_pele! @ https://www.instructables.com/id/Making-a-Motorized-Secret-Entrance/
Step 2: Select a Latch to Keep the Compartment Closed
Most secret compartments are held closed with some kind of latch. A door latch works well for this kind of application because it is fairly sturdy and reasonably easy to install. I recommend using a simple latch without any locks like the kind used for closets because they are a little easier to work with. So that will be the primary latch that we use in this project. But you can also use other kinds of latches such as cabinet latches, window latches or even fence latches. However if you use one of these, then you may need to modify you construction methods a little.
Step 3: Use a Candlestick As a Door Knob
The simplest way to activate a door latch with a candle stick is to just replace one of the door knobs with the candlestick. To do this, you will probably need to either modify or replace the spindle (the bar that connects the two door knobs to the latch). You will also need to make some kind of bracket to connect the spindle to the candlestick.
Most door knob spindles will be too long to mount the candlestick flush against the wall. So you can either cut it shorter, or you can just replace it. For prototyping, I replaced the spindle with a 1/4 inch square wooden dowel. However, I highly recommend using steel  in your finished product. Turning a door knob involves a lot of torque, and a wooden dowel will wear out quickly.
To attach the spindle to the candlestick, I made a small bracket out of a scrap piece of sheet metal. I traced the spindle onto the center of the metal. Then I cut an X across across opposite corners of the square. Then I bent the sides down to create a square opening that the dowel could be pressed through. You will probably also need to add a screw and washer to the back side to help keep the candlestick mounted to the dowel.
Once you have your new spindle mounted to the candlestick, you can insert it through the latch and into the other door knob. You can then use the candlestick to open the latch just like a regular door knob. You can easily mount the latch and candlestick in a standard door that is covered or disguised (although you may wish to mount them higher on the door to be at a more reasonable height for a candlestick). Alternatively, you can mount the latch and candlestick to the wall next to the door and place the strike plate on the door. It should work the same. You will just need to have a separate handle so that you be able to pull the door open.
Step 4: Use a Candlestick to Activate a Door Latch at a Distance With Cables
It is not always convenient to mount a candlestick on or immediately next to your secret door. If this is the case, you can connect the candlestick to the latch with cables. To do this, you will need some steel wire and a pair of brackets to attach the wire to the spindles.
You can make these brackets the same way that you did for connecting the spindle to the candlestick. Cut an X in a piece of sheet metal, bend the tabs out slightly and press the spindle through the center. Then drill a small hole in the metal that is a little bit larger than the wire. This is where we will attach the wire to the bracket. Orient the brackets so that when the candlestick bracket is turned clockwise, the wire will turn the second bracket clockwise as well (see the picture above). Feed the wires through the holes and bend them down into a hook so that they will not come loose when they are pulled on by the brackets.
After mounting the candlestick onto the second spindle bar, you should be able to activate the latch. Just turn the candlestick. This turns the spindle, which turns the brackets, which pulls on the cable, which turns the first bracket, which turns the first spindles which finally activates the latch. A simple setup like this will let you position the candlestick a short distance away from the latch and still be able to activate it mechanically. However, this process is greatly complicated if you need to run the cable through studs. So choose your locations carefully.
Step 5: Use a Candlestick to Activate an Electrical Switch
You can also use a candlestick to activate an electrical circuit. All you have to do is mount an electrical switch to the wall behind the candlestick. You can then wire the switch up to a motor that will open your secret compartment. You can even make the motor turn in both directions by using one DPDT switch or two SPDT switches.
To activate the switches, I made another bracket for the candlestick. This one just had a flat piece that was bent out and fit between the buttons. When the candle stick was turned one direction, it would press the first switch. When it was turned the other direction, it would press the second switch.
To help avoid shorting the wires on the metal candlestick, I applied a piece of masking tape over the switches and wires. Then I cut a slit in the tape so that the bracket could still press the two buttons.
Lastly, I ran the wires from the switches to the power supply and to the motor. This setup will let you activate a wide variety of circuits by slightly turning the candlestick. It can be something small like a car door lock motor or something large like a garage door opener. Use your imagination and have fun.
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    4 Discussions
