Secret Flash Drive Inside an USB Cable
20,244
282
38
How do you hide something that you use frequently? I mean, if you hide a flash drive by burying it in your backyard, surely none will find it, but it's also difficult for you to use it!
I thing that the best hiding place is where none will find what you hide, but you can access it easily.
So I came up with this idea: let's hide a flash drive inside an USB cabe. I would never find an USB hidden this way! Until now. But it would be difficult anyway.
Let's start!
Supplies:
Step 1: Choosing the Cable and the Drive
You have to find a not-so-used USB cable. This is very important because otherwise your secret flash drive can be found by accident!
For example, I can't even remember what was used for the cable you can see in the pictures. I found it in a forgotten-box and I'm pretty sure none is gonna use it.
The flash drive has to be little enough to fit inside the USB connector. I had this very tiny HP 4GB flash drive that is perfect for this project.
Step 2: Disassembling the Flash Drive
That's easier to do than to say, at least in my case.
Anyway, do it with patience, since if you break it, there's no way back. Try not to scratch the electrical contacts (or at least not too much).
Step 3: Disassembling the Connector
This is a little more tricky. As a method, after a couple of hours of philosophical reflection, I choose the so called "brute force" method.
  1. Use a flat screw driver to detach the white part (with contacts) from the metal part
  2. With the same method, detach the metal part from the plastic body of the connector
  3. With the pliers, remove the metal part
  4. With the same precision tool (big pliers) remove the white part from inside the connector. This wasn't easy for me and the plastic thing didn't came out as a single piece.
Step 4: Preparing the Connector
Once you removed all the parts, you will notice that the flash drive still doesn't fit inside the connector.
So for making more room, I used a rotary tool whit a drill bit. Be careful not to pass through the plastic!
You can test if you reached the correct depth by simply putting the drive inside the connector.
Step 5: Mounting and Final Touches
Now simply put the metal part back inside the connector and glue it with some superglue. Then, mount the flash drive inside of it and you are done!
Now, if you don't want to take any risks, you can also encrypt the flash drive. So, even if someone accidentally finds it, he wont be able to read it's content.
I think this method is perfect for your office or workplace!
Hope you enjoy
Hiding Places Contest
Runner Up in the
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    38 Discussions
    LegoSurvivor
    1 year ago
    now i will try and tug on the end of ALLLLLL the chargers i see.
    sebeTNT
    2 years ago
    Awesome
    NespLabMike Fury 2
    Reply 3 years ago
    Thank you very much! It's a little time since I made it, and I often can't recognise the modded cable between the normal ones!
    bound4allzorzo
    Reply 4 years ago
    No it's not a copy. The other one used a pen. I like this one better because I don't have a "spare" pen laying around.
    manuelmascbound4all
    Reply 4 years ago
    He also used a "spare" pen... What do you mean?
    manuelmasczorzo
    Reply 4 years ago
    I think that this could happen! I don't think that he copied me! We just had the same idea :D
    NespLabzorzo
    Reply 4 years ago on Introduction
    I know of that Instructable, but I didn't copy it...
    Look at the image below, I uploaded the photos to my computer 3 days before he published his one! I think it's only a coincidence...
    NespLable-Sid
    I'm sorry, it's only my second instructable... I think I should check if someone made something similar before I publish!
    I think I'll put your and the other guy's instructable link at the end of mine, i didn't want to copy anyone!
    bound4allNespLab
    Reply 4 years ago
    No worries. It's not even the same Instructible as the other one. You shouldn't feel compelled to add his link because you used a cord with 2 USB ends, and he used a pen. I'm going with yours because it's what I'd be using for materials. You did a good job!
    manuelmascNespLab
    Reply 4 years ago
    Hi MatiasM2! I am the other guy that published almost the same ible the day before you!
    First of all great idea!! :P ahahaha and second don't worry! I know that you didn't copy me or the other guy! If you want to add our links I'm personally ok with it! ;) have a good luck with the contest!
