Secret "Jurassic Park" Stash
12,257
164
16
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with.
I remember seeing Jurassic Park for the first time as a kid and thinking, I’ve gotta get my hands on one of those secret shaving cream cans. Fast-forward 25 years and although I still don’t have one, I did manage to make my very own secret can with hidden compartment.
It doesn’t have any place to store dinosaur embryos and it’s not made from a can of shaving cream, but it will fool anyone into thinking it's an ordinary can of WD40. I used a WD40 can for a couple of reasons. First – the brand of shaving cream used in the movie isn’t available in Australia, and second – I wanted to use a can that was ubiquitous in any garage or home. You could use any type of can you want though – just make sure it’s made from tin as it’s more durable.
This is a relatively simple hack and works amazingly. Anyone who picked-up the can wouldn’t be able to tell that the bottom can be removed.
Let’s get on with it then.
Step 1: Parts and Tools
Parts:
You will be able to find all of the parts in any hardware store
1. 50mm PVC Connector
2. 50mm PVC Adapter
3. 40mm PVC tub
4. 40mm Cap
5. 40mm Coupling
6. Can of WD40
Tools:
1. Epoxy glue
2. Dremel (or something similar) with a cutting wheel. At a pinch you could use an angle grinder
3. Sander. I have a belt sander and it was very handy. You could do the sanding by hand if you wanted to or use files
Step 2: Empty the Can
The first thing that you will need to do is to empty the can
Steps:
1. Come up with a way to hold the lid down on the can. I used a clamp to hold it down
2. Try and keep the can up straight when emptying it out
3. Make sure that the can is completely empty before the next step. You really don’t want any pressure left in the can when you cut into it.
Step 3: Cut the Base Off the Can
Next, it’s time to remove the bottom of the can. I have seen people use can openers for this but I found a small cutting wheel on a dremel does the job well.
Steps:
1. Place the can somewhere where you can rotate it easily. I opened up the vice a little, placed a rag against the teeth and put the can on top of this.
2. With a dermal which has a cutting wheel, carefully cut around the bottom of the can. Try to make the cut as straight as possible. Don’t worry though if it is a bit wobbly, you can sand it down later to fix it up.
3. Remove the base and make sure you don’t cut yourself on the can!
Step 4: Sand the End of the Can
Steps:
1. If you have a belt sander then this will be a lot easier. Place the can onto the sander and start to even out the cut that you made.
2. Keep turning the can, making sure that you sand evenly.
3. When it is straight, grab some 400 to 600 grit sandpaper and sand the edges to make sure it isn’t sharp.
Step 5: Sand the Base
Next thing to do is to sand the base of the can. You want to remove any pieces of the can around the edge.
1. With a bent sander (or file or just sandpaper) carefully remove the small pieces of metal around the base by slowly rotating at an angle on a belt sander
2. Keep checking your work and remove as much as possible of the cut metal. You want to have no can showing out of the top of the base.
3. Don’t worry if the inside of the bottom of the can gets roughed up a little. This is actually a good thing when it comes time to gluing
Step 6: Modding the PVC Connector and Adaptor
Modding the adapter and connector is pretty simple, you will just be trimming them down
Steps:
1. Place the adapter into a vice with the female screw section facing inwards.
2. With a dremel, remove the coupling section (the part that doesn’t have thread inside)
3. Sand down and remove any burrs
4. Do the exact same for the Connector
5. For the adapter to fit inside the can, you will also need to remove the small plastic gussets running along the outside. Just sand these off until the adapter fits snuggly inside the can
Step 7: Gluing the Adapter
Time to glue the PVC couplings to the can.
Steps:
1. Screw the connector and adapter together.
2. Next, add some epoxy glue around the adapter and push it into the bottom of the can. The reason why you need to screw the connector to the adapter is to work out how far inside the can the adapter has to be glued. When the base of the can is glued to the connector, it needs to sit flush with the can so it’s important to make sure the adapter is glued in the right spot.
3. Un-screw the connector 1 to 2 turns. Place the base of the can on a flat surface and push the can onto it so they sit flush. The adapter will slide up inside the can and be in the right place for when the glue dies.
4. Leave to dry.
Step 8: Gluing the Connector
Once the glue is dried on the adapter, you next need to glue the connector to the base of the can.
Steps:
1. First thing to do is to add some epoxy around the bottom rim of the connector.
2. Next, screw the connector into the adapter inside the can. Remember how you loosened the can 1 or 2 turns, do this again.
3. Place the bottom of the can on a flat area and place the connector (which is inside the can) on top of it. You may have to adjust the connector until the bottom of the can is sitting flush
4. Leave to dry for a good hour or so.
5. Test to make sure that the bottom screws into the can and everything is working as it should. You may have to add some more epoxy around the connector and bottom of the can.
If you want you can just leave it as is and your done. I wanted to add a small tube inside mine to secure the goods inside.
Step 9: Adding a Tube to the Inside
Steps:
1. Cut the 40mm coupling in half and sand flat the cut edge
2. Cut a piece of 40 PVC tube so it will fit inside the can and glue the 40mm coupling to one end
3. Next, you need to glue the tube to the bottom of the secret can. Add some epoxy to the bottom section of the tube (the bit with the coupling attached) and glue in the middle of the base of the can
4. Once dried, add a 40mm cap as a lid to the top of the tube
5. Screw the base into the can.
Done!
Creative Misuse Contest
Runner Up in the
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    16 Discussions
    Raynoodles
    8 months ago
    I love how there is a tongue in cheek joke on the WD-40 can.
    "There is always ANOTHER use."
    attosa
    8 months ago
    Haaa, really cool. I saw similar in a spy shop and it was expensive!
    krmsillegal.
    Tip 8 months ago
    Remind me a lot of these things i had before anyway what you forgot guys no mater wich cans you gonna use, you need to think about the weight and how to disguise it, so weight your soda cans first then do a hidden compartment with some liquid in it or sand as let say you soda cans will still be close or your WD-40.
    Who keep an empty can ?
    Nice one anyway.
    RobR2krmsillegal.
    Reply 8 months ago
    I really don't know anyone that has less then 100 spray cans in their garage. The chance of someone breaking into my house, going out to the garage, walking past $30k in tools to start shaking my spray cans is slim to none!
    "Who keeps an empty can?" I probably have 20 right now, every time I go to use starting fluid or black spray paint they are always empty!
    ivak245
    9 months ago
    Good ideas there! Just be careful using a dremel with a cutting wheel- sparks + Air + flammable WD40= bang! After it is empty, to relieve the pressure, you can puncture the can somewhere inconspicuous, like the bottom, with a nail, etc. And don't do it to a spray paint can- I had my workplace broken into once, and all they took was the shelf of spray paint, so they could tag the railway station next-door!
    inchman
    9 months ago
    Great 'ible. I am wondering out loud if it would be possilble to have a small tire pressure value on the inside of the compartment so you could put some slight preseure into the top of the can with some oil and keosene so that it would still spray if pressed. Of course you would need to make it airtight and you would lose some of the storage space, but the fact that the shaving cream can in the movie still worked was the coolest part of it.
    It would increase the complexity of this build an order of magidute, but that is what 'cool points' are for.
    Either way, this is a great way to create the hidden storage can. Thanks for sharing!
    woodface7
    9 months ago
    Since the idea is to protect your 'stash', I would use the crummiest, roughed-up, paint-splattered old can. You avoid wasting lovely WD40 and even lovelier cash. And avoid the risk of a thief who thinks 'Hey - I could really use a can of WD40!...'
    Also, glueing an appropriately sized disc of wood or expanded foam to the base would make a push-fit version in a fraction the time at nil cost. Nice project though - I love to see plumbing fittings used in unexpected ways.
    photony
    9 months ago
    I would use one of those "safety" can openers that travel around the rim...VOILA! No sanding needed, and right to gluing!
    ThatsG
    9 months ago
    really great instructable but just an observation. i think its kind of wasteful to just empty the wd-40 into an old bucket. maybe use the spray up first or spray it into something clean so it can be reused.
    jseager64
    9 months ago
    The spray can w/ ball inside is a great idea. But if I weren't uning a spray can of paint I would line the inside with some thick cloth, an old washcolth perhaps. That way if your stash is a dozen or so Gold Debloons one wouldn't hear metal on metal when picked up. Just a thought after reading this.
    seamster
    9 months ago
    Nicely done. I've made a couple of similar cans, but just with press-fit bottoms. I quite like the way you made the screw-on bottom. Good stuff! : )
    5
    Yonatan24
    9 months ago
    Pro-tip: Cut open a spray paint can instead of WD-40, you'll get a free steel ball that was inside to help mix the paint :)
