Self-watering Container Garden
189,982
752
40
I made a completely portable garden that is self-watering. Each container has a water reservoir in the bottom that keeps the soil moist, and there's also a hole so excess water will drain out.
Tidy Cat kitty litter container (38 lb size)
4" perforated corrugated drainage pipe
1-1/2" PVC pipe
Potting soil
Step 1: Create a Water Reservoir
Cut a piece of 4" perforated corrugated drainage tile to length to fit the length of the container.
Cut a square notch in one end to fit the 1-1/2" PVC pipe
Step 2: Drill Overflow Hole
Drill a hole through the side, 4" from the bottom.
Step 3: Cut the Fill Tube
Cut the 1-1/2" PVC to length
Step 4: Assembly Time
Put the parts together as shown, add dirt, start planting!
Step 5: Watering
Add water via the fill tube until water flows out the overflow hole.
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    40 Discussions
    merrittgene
    4 years ago on Introduction
    At the end of last season, I dumped all of my containers in the driveway, pulled out all the root mass, mixed in a bag of compost, and put all the dirt back in the containers, and put the lids on.
    While I had everything torn apart, I redid some of the buckets to match these instructions, since I had changed the design a couple times (size of reservoir, location of holes, location of fill tube, etc.)
    All of my containers are dry and ready for planting, as soon as it's warm enough. I might even take them to the garage and get them going early. :-)
    mmitchell89merrittgene
    Reply 4 years ago
    Now that they've had some time to grow, how do you find it compares with your previous setup?
    barmstr
    3 years ago on Introduction
    Put a porous sleeve over the black water pipe so the dirt will not fill the storage pipe. Also, mix 1/3 compost, 1/3 vermiculite and 1/3 peat moss (Mel's mix). This is a great soil combination for the vegetables. Look into Square Foot Gardening for soil mixture and plant spacing.
    merrittgenebarmstr
    Reply 5 days ago
    Yes, I read Square Foot Gardening years ago, but I didn't follow it exactly. In the Fall, I dumped out all the containers, picked out the roots/plant matter, then reassembled the containers. I added a bag of manure to the existing soil mixture, mixed it thoroughly, and refilled the containers.
    merrittgenemerrittgene
    Reply 5 days ago
    Oh, and I've never had a significant amount of soil enter the corrugated pipe, so the porous sock has not been necessary.
    sandre106
    3 years ago
    I'm an IL Master Gardener & use cheap 18 gallon tubs from Walmart as well as kitty litter buckets like this. You must use the white PVC pipe as that does not leach toxic chemicals & is designed for water system use in a home. Cut the bottom of the PVC at an angle so the water flows easily into your reservoir. The drainage tile is already perforated so water will flow out slowly. Best to cover it with cheesecloth or some other cloth to keep the dirt out. I fill the PVC pipe until it stays full for a while. But you must drill a drainage hole in the side of the tub just above the height of the reservoir. If water starts coming out the drainage hole you know your reservoir is full. Try filling daily or every other day until you get to know how often it will need filling as that will depend on weather and heat. You can grow just about anything in these tubs - I've grown tomatoes and beans with a trellis or cage. Melons also do well when supported with old pantyhose. Herbs do very well - I had one bin last summer with various herbs on my back porch right outside the kitchen door so it was handy to cut a few for cooking. A few starter potatoes will also work well, but start them low and add soil as the plants grow. The diaper pellets are a great idea to hold moisture into the growing soil and they are much cheaper than a bag or box of pearlite. One big box of disposable diapers will give you enough pellets for a lot of tubs. Happy Gardening!
    merrittgenesandre106
    Reply 5 days ago
    Thanks for the feedback.
    I dump out and rebuild every bucket every fall, and keeping soil out of the corrugated pipe has never been an issue. The pipe doesn't fill with mud. I suppose the black pipe might not be as healthy as the white pipe, but it is designed to be in the soil for decades without breaking down, so I doubt it's leaching much. Plus, any leaching would have to pass through the soil, and roots, and plant before reaching the fruit or vegetable.
    JustinY15
    1 year ago
    Whats the difference between watering your plants every day or two and watering your reservoir every day or two? If the soil does not touch the water how does it get moist all the way through? Are you not concerned about root rot, and plants going fungal which can severely diminish crop outcome if not kill the plant? Isn't a plant in a pot already a portable garden? Cool idea, I just don't see the point. Maybe I missed something. I'm not an officially titled "Master Gardener" but I am a professional nursery worker.
    merrittgeneJustinY15
    Reply 5 days ago
    I add water to the reservoir which is in contact with the soil, so the wet soil at the bottom wicks water up to the unwatered soil at the top. The roots grow down to the bottom of the container, but the entire container does not fill with water (due to the overflow hole), so most of the plant does not have wet soil all the time.
    I made this when I didn't have an in-ground option, and the boxes are portable. I also like that the water stays with the plant and doesn't flow away to the entire lawn so it's water-efficient. And, the height of the box keeps (most) of the rodents away.
    JustinY15JustinY15
    Reply 1 year ago
    Best way I've ever grown tomatoes is a 5 gallon bucket with a few holes drilled in the bottom. Soak it real good every two days and they love it.
    NancyK63
    1 year ago
    Will this work for growing strawberry plants?
    merrittgeneNancyK63
    Reply 5 days ago
    I think it would, although I don't know if these tall containers are the correct depth for strawberries.
    The idea I want to try is to use house rain gutter to plant the berries, with the gutters mounted high on a trellis, so you could walk under it and pick the berries from the vines hanging down.
    SonnyR1
    9 months ago
    Use a small bamboo or wood stick to float in the pvc watering tube. The hole in the side will allow insects in mosquitos to breed here in sw fl. Good job!
    merrittgeneSonnyR1
    Reply 5 days ago
    I like the bamboo float idea. We have mosquitos here, but I haven't noticed an issue with creating a breeding space for them. I added the hole to prevent the entire container from filling during the rain.
    Someone else's design used hose sections to link all the containers together, so water added in one container would fill all the other containers.
    Matermark
    Question 5 days ago
    Is the corrigated pipe the only thing that holds water? How does that work if it has holes? I've seen EarthBoxes but they have a barrier like a perforated piece or something to separate the water reservoir from the soil. Are you packing your soil/soilless mix all the way around the corrugated pipe and doesn't the water leave the corrugated pipe virtually as quickly as you pour it down the pvc pipe?
    1 answer
    merrittgeneMatermark
    Reply 5 days ago
    The corrugated pipe has holes in the sides, so the water flows out to the soil on the sides, which then wicks the water up to the roots. The pipe creates a cavity to hold ~2 liters of water, and the hole in the side keeps the entire box from overflowing in the rain.
    Ward_Nox
    3 years ago
    i thought you went suposed to use PVC for watering pipes cause it leaches toxins?
    One more idea might be to fill around the drain pipe with some light weight lava rock to increase the opportunity for soil O2, better drainage and a little more water space. You could also increase soil O2 by occasionally watering overhead which serves to flush and pull in O2.
    I did a similar project last year with home depot buckets and some others we scrounged up (We use $4/40lb bags wood stove pellets for litter now- can not beat that). My tomatoes were awesome, but I added a fair amount of Lime (Calcium) to my pots. Even then, the one I skimped on developed blossom end rot. How did your's fare? I will be trying your drain pipe idea in the reservoir as my system was difficult to construct and used twice as many buckets. Have a stash of cheap felt (2 yards!) which wicks water like crazy and because it is poly will not rot, so I may try that this year. Also, BTW, I made cover up for my ugly orange buckets out of old blue jeans (+/- turning them into skirts). Hokey, but cute. Looking for a new idea this year- maybe burlap or painter's canvas. Thanks for the ideas!
