Sending Temperature Sensor Data to Azure Database
10,773
14
8
This project uses a Raspberry Pi B+ attached to 2 temperature sensors and sends data to an Azure data source that can be used to create charts.
A bunch of my code for accessing the temperature sensors came from the Adafruit tutorial Adafruit's Raspberry Pi Lesson 11. DS18B20 Temperature Sensing
Step 1: Build the Sensor Device
This project uses 2 DS18B20 1-wire temperature sensors. The sensors can be connected in parallel with only one 4.7K resistor.
The red wire is connected to the 3.3v pin, the blue wire is connected to ground, and the green wire is connected to pin#4 for data. The 4.7K resistor goes from data to 3.3V
Step 2: Read the Sensor
The Python program prints out the temperature in degrees C every 5 seconds
import os
import glob
import time
import thread
import socket
from datetime import datetime
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
base_dir = '/sys/bus/w1/devices/'
device1_file = glob.glob(base_dir + '28*')[0] + '/w1_slave'
device2_file = glob.glob(base_dir + '28*')[1] + '/w1_slave'
def read_temp_raw(dfile):
    f = open(dfile, 'r')
    lines = f.readlines()
    f.close()
    return lines
def read_temp(dfile):
    lines = read_temp_raw(dfile)
    while lines[0].strip()[-3:] != 'YES':
        time.sleep(0.2)
    equals_pos = lines[1].find('t=')
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = float(temp_string) / 1000.0
        return temp_c
host = socket.gethostname()
while True:
    try:
	temp1 = read_temp(device1_file)
	temp2 = read_temp(device2_file)
        body = '{ \"DeviceId\": \"' + host + '\" '
	now = datetime.now()
	body += ', \"rowid\": ' + now.strftime('%Y%m%d%H%M%S')
        body += ', \"Time\": \"' + now.strftime('%Y/%m/%d %H:%M:%S') + '\"'
	body += ', \"Temp1\":' + str(temp1)
        body += ', \"Temp2\":' + str(temp2) + '}'
	print body
        time.sleep(5)
    except Exception as e:
        print "Exception - ", repr(e)
The program starts by running the 'modprobe' commands, they are needed to start the interface for reading the one wire protocol sensors.
The next three lines, identify the file where the messages can be read. The function read_temp_raw reads the raw data from the interface. The read_temp function parses the data and returns the temperature value.
The main loop of the program reads the temperature and prints it out every 5 seconds.
You can start an editor window and enter the code by typing
nano sender.py
Once you've entered the code you can run the code using
sudo python sender.py
Step 3: Configure Azure Event Hub
Log into your Azure management portal and create a Service Bus Name Space.
Click the Plus to create a new Service Bus name space. Give the Name Space a name then click the check mark to create.
Within the Service Bus Name Space just created, create an Event Hub. Click the Plus, then Choose Quick Create and give the Event Hub and name then click Create.
In the Event Hub page, click on the configuration tab. Create a policy called Receive Rule with permissions to Manage, Send and Listen. Then policy name and key will be needed later on.
Step 4: Configure the Azure Database
I use an Azure SQL database table here, but you can use other types or data sources like: table store, blob storage, or export directly to PowerBI.
Using SQL Server Management Studio, or some other database management tool to connect to the database and create a table. You can use the following script:
CREATE TABLE [dbo].[SensorDemo1](
	[rowid] [int] NOT NULL,
	[DeviceId] [nchar](30) NULL,
	[Time] [datetime] NULL,
	[Temp1] [float] NULL,
	[Temp2] [float] NULL,
PRIMARY KEY CLUSTERED
	[rowid] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON)
GO
Step 5: Configure the Azure Stream Analytics Job
Click New to create a new Stream Analytics job, Give it a name and also specify the New Storage Account name, then click Create.
Open the Stream Analytics Job in the Azure Protal (https://portal.azure.com)
Then add and configure an Input. You'll need to specify the Service Bus Name Space, Event hub name. Also enter the policy and key we specified in the previous step. The Event serialization format should be JSON and Encoding should be UTF-8.
Step 6: Send Sensor Data to Azure
Install libraries for Azure API
Install the Azure API and other prerequisite libraries by executing the following commands within a terminal window on your Pi.
$ sudo apt-get install gcc cmake uuid-dev libssl-dev
$ wget sourceware.org:/pub/libffi/libffi-3.2.1.tar.gz
$ tar -zvxf libffi-3.2.1.tar.gz
$ cd libffi-3.2.1/
$ ./configure
$ sudo make install
$ sudo ldconfig
$ cd ~
$ sudo apt-get install python-pip
$ sudo pip install requests[security]
$ sudo pip install certifi urllib3[secure] pyopenssl ndg-httpsclient pyasn1 azure
$ sudo apt-get install python-openssl
Call the Azure API from Python code
This code has been edited to import the Azure library and a call to the sbs.send_event at the end of each loop.
import os
import glob
import time
import thread
import socket
from azure.servicebus import ServiceBusService
device1_folder = glob.glob(base_dir + '28*')[0]
device2_folder = glob.glob(base_dir + '28*')[1]
device1_file = device1_folder + '/w1_slave'
device2_file = device2_folder + '/w1_slave'
name_space = 'sensordemo-ns'
key_name = 'RootManageSharedAccessKey'
key_value = 'nmoamu9fHRphGQodT/J7SBXfmLGYfVsrUDIZXxm+hMc='
f.close()
return lines
time.sleep(0.2)
return temp_c
while True:
try:
body = '{\"DeviceId\": \"' + host + '\" '
body += ', \"rowid\":' + now.strftime('%Y%m%d%H%M%S')
body += ', \"Time\":\"' + now.strftime('%Y/%m/%d %H:%M:%S') + '\"'
print body
sbs = ServiceBusService(service_namespace=name_space,shared_access_key_name=key_name, shared_access_key_value=key_value)
hubStatus = sbs.send_event('sensordemohub',body)
print "Send Status:", repr(hubStatus)
time.sleep(5)
repr(e)
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    8 Discussions
    AkashT15
    2 years ago
    Can you describe your step-4 again and little more clear please?
    crazy22
    3 years ago
    i have one more doubt .
    host = socket.gethostname().......
    body = '{\"DeviceId\": \"' + host + '\"..
    I did not get above two lines in the code. what it does actually?
    do i need to add this line in the code if i am using dht11 sensor.???
    how do i change?
    cgainecrazy22
    Reply 3 years ago
    There is a feature in Azure to validate the JSON string. Copy the output from 'print body' into a text file and have Azure validate the syntax is correct.
    cgainecrazy22
    Reply 3 years ago
    I added these to lines in order to distinguish between sensor information coming from different devices. If your only using sensors from a single Pi than there is no need for these 2 lines.
    You would also need to remove the + and , from the following line, and ensure you have a valid JSON string.
    Also, remove any reference to DeviceId from the EventHub configuration.
    crazy22
    3 years ago
    if you can help me with dht11 sensor.....it would be really helpful
    crazy22
    3 years ago
    hello cigaine
    Thank you for reply
    database part is solved.
    I have one doubt regarding sensor .....i am using dht11 temperature humidity sensor.
    so what kind of changes i should make in code to connect it to azure database.
    I got an index error in the code that given in step 2.
    please help with dht11 sensor and code
    crazy22
    3 years ago
    hello
    I did not get your step no.4. can you please tell me how did you make your azure sql database???
    Please reply as soon as possible
    cgainecrazy22
    Reply 3 years ago
    You'll need to go through the process of creating an SQL database in Azure if you don't already have one. Just click the + link and the Azure wizard will guide you through it. Once the SQL database in provisioned look for the connection string in the properties of the database. Use that connection string to add the SQL database to your Management Studio. Then use the script in step 4 to create the table to store your data. I hope this helps.
