Survival Trekking Stick+Knife+Spear+Bow+Fishing Rod & Compass
37,038
518
39
About: I like DIY things, whatever new I think , I always try to make it.But I always publish here which is original. Mainly I do aluminium casting,surfing, kayaking,fishing, wood turning and basic Arduino stuff. I...
Introduction:
My elder brother and his friends do lot of trekking tours, almost at every weekend they plan to explore new places. Mostly they plan to visit forts because they all are devotees of “Shree Chatrapati Shivaji Maharaj” who have built more than 250 forts (over the mountains) in our region.
They generally carry fruits and ready to eat food. Essential items they carry are knife, lighter that’s all. But to climb mountain (almost every fort is located at mountain) everyone needs a strong bamboo stick.
Bamboo stick have two uses 1)to assist climbing 2) For protection from wild animals (mostly monkeys). Once my brother’s friend was attacked by a monkey and that friend don’t have stick and his knife was in his bag pack. So from that incident I was thinking about making a folding “all in one” bamboo stick which will carry all essentials things. I design a basic version first and then modify it as per need. I made this stick in two parts so we can easily carry in our bag also try to keep total weight is about 200 Grams. Once stick assembles then it can convert into spear, bow and a fishing rod. It has knife very handy and a compass to check direction whenever you want.
Step 1: ​Material Required
As usual i am using material which is easily available. these are not detail pictures, but you will see all in next steps.
1. 3/4 “ PVC pipe - 32” long
2. ½”PVC pipe- 08” long,
3. Bamboo (for making strips)- 32” long
4. Epoxy glue (I used Bondtite)
5. Angle grinder- (Optional)
6. ½” dia compass
7. Fishing thread
8. Wooden coupling(details given below)
9. Old hacksaw blade or good knife
10. Some rubber bands, cloth pins, paper clips
Step 2: ​Making Knife:
I am not a professional knife maker but believe that we can easily convert any metal piece to knife. Here I made knife from old hacksaw blade. This blade is 1/16” thick and 1.5” wide. First I cut it along length and give knife shape with angle grinder. I kept hacksaw blade teethes as it is, they don’t have any use but just add nice look to knife. Then sharp it with angle grinder and then add a bamboo handle (1” dia).
Hacksaw blades are extremely hard due to its carbon content. They are not ideal for survival knife as they are brittle. But if we keep its length short (I kept here around 7”) then they don’t break easily if fall on hard surface.
Step 3: ​Making Stick
For stick we can use bamboo itself but I want to add a bow function to “trekking stick” so I decide to make stick from composite material. Inner core is a made from stiff PVC tube (1” OD) and outer cover is from bamboo strips. My brothers height is 5’8” so I select stick size 3’2”(find out with trial and error, it’s a minimum length require to walk comfortably for 5’8” high person).
For making bamboo strips, cut bamboo in half and continue cutting till you get ¼” wide strips. Clean all buds and inner useless core. Now with help of epoxy resin stick all bamboo strips around PVC pipe. I have used O4 full length main strips and then short strips to cover PVC pipe.
Due to its composite design I have lot of free space for storage and its weight also reduced. I believe Its strength also enhanced compare to normal bamboo stick.
Step 4: ​Knife Installation
Knife will assemble in top portion. So any time we can use it as it is always present in hand. For spear arrangement I have to make strong coupling arrangement so I make a small threaded piece which will bond at handle’s end. I also installed a small compass in threaded end.Knife installation
Step 5: Making Folding Stick
Detachable is proper word but anyway I will use “folding” word. To make it separable we need to cut our stick in half (at 21”).
I have designed two joining processes
1. A threaded coupling
2. Hollow sleeve coupling
I have tried both, but for now I will show you “metal threaded coupling” and in my next version I will update it to “hollow sleeve”.
You can see pictures of metal coupling, it is two part coupling, each part accommodate “stick’s” one end. Coupling is made from MS piece of 50 mm dia. Threads are M16. Its weight is 130 grams.
Step 6: ​Making Spear Attachment.
We have already installed knife at top, to attach knife handle to stick we already provided ½” NPT threaded piece to handle. So I installed threaded nut at bottom of stick.
To make spear just remove knife and attach at bottom of stick with thread.
Step 7: ​Making Bow and Fishing Rod
Its only contraption bow, but still we can make use of it. i attached two wire loops at each end,I kept some measured thread in stick and also did thread installation arrangement to stick by providing hooks. Just added small loops at each end which will hold thread. There is some space for arrows if you want to keep them. And with same thread and some extra thread we can make a fishing rod.
Keep lures, baits at storage space.
Step 8: Conclusion
My main aim was keeping project size (length and weight) minimum as possible. I measure weight and its come 210 grams, and it requires storage space of 16” length and 2.5” dia.
This is very basic idea, and there is more to do with it.
Thanks for reading, please feel free to comment if you have any suggestions.
And if you feel my work deserve your vote then please vote for this.
#Happy making.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    39 Discussions
    RichM5
    3 years ago
    As a hobby hiker, I have some vaguely similar items, and some suggestions. While a makeshift spear is a really nice tool, and excellent for defense against small and medium animal threats, it also makes this a overt weapon. For use in the US, where animal threats are usually smaller, I'd suggest keeping your knife separate, and instead drilling out the bottom of a solid hardwood staff and adding a weight. While this is less desirable for walking purposes, it adds a lot of energy to the end of the staff when swung. I have fended off feral dogs with one of these. Mine are weighted with lead, and then capped with a small steel pipe and end cap, but this is not environmentally sound. If I were doing it again, I'd probably use pre-made tungsten weights, and fill any gaps in the end with epoxy to make it fill the way lead did.
    bhavik zureRichM5
    Reply 3 years ago
    Thanks for your comment and suggestions.
    I made it for my brother, his requirement was a folding stick with knife. He also asked to keep weight low so I tried to keep it around 200 grams. everything else I added is due to space was available for it.
    beneris1
    3 years ago
    It might help to add a small compartment for fishing line, hooks, matches and wrap some paracord on it
    bhavik zurebeneris1
    Reply 3 years ago
    ya, it have lot of space to store lines,hooks etc, I want to add some paracord at handle but i was out of it.
    4WantofaNail
    3 years ago
    Does the bow actually fire? looking at it i can't imaging it would. but given that im not inclined to build on I'll just have to take your word. Great craftsmanship regardless. cheers
    bhavik zure4WantofaNail
    Reply 3 years ago
    Thanks for appreciation,
    Its a contraption bow arrow, not full functional . but still can shoot from 20 feet. I recorded video with trying every function, soon i will post.
    and for full functional bow, we need to couple two sticks with hollow sleeve coupling, this coupling is a 1/2" PVC pipe that join two sticks, and act as spring when use as bow.
    paul the maker
    3 years ago
    COOL IDEA BUT I DO NOT THINK MT SCOUT TROOP WILL LET ME USE IT.I LOVE IT
    bhavik zurepaul the maker
    Reply 3 years ago
    Thank you for your comment, might be they will not allow you with knife, to hide knife you can easily installed a number coded lock, Currently i am working on that and will post soon. but before building something like this you must check your federal laws.
