Setting Soft Limits for Your Industrial CNC Router
47,097
85
6
When you're getting started, in order to make sure that your Industrial CNC Router doesn't run into the side of the table, it can be a good idea to set up limits in your Mach 3 software for safety. In this post, I'll you how to set your soft-limits, which means that the software will stop the table automatically before this occurs.
*Please make sure that your motors are properly tuned before setting the limits or they won't work properly.
Step 1:
1) The first step is to go to CONFIG/PORTS and PINS/INPUT SIGNALS. Make sure that all of your limit switches are disabled. (a red X for each row) See attached picture.
If you're using your Homing Switches, you can ignore that, and simply "Reference All Home" so that your "Machine Coordinates" Home is set automatically at Zero.
Step 2:
2)Jog your Router to its home position. (We'll call the end of the table with the inverter and cabinet the front) Jog your spindle as far as it will go to the left, front (stop at the edge of the table)and all the way up on the Z axis.
Step 3:
3)Select the button beneath the DRO's (Digital Read Out) marked MACHINE COORDINATES
A red border should appear around the button (see picture below)
Step 4:
4)Select the Vertical REF ALL HOME button to the left of the DRO. This should set all axes to 0. (see picture)
Step 5:
5)Go to Config/Homing Limits. Enter in the cutting area dimensions for your Router.
Make sure to use Zero as one dimension and the width/length as the other. Note that the Z axis is set opposite from the others. See picture.
Step 6:
6) Select the SOFT LIMITS button to the right of the MACHINE COORDINATES button. It should now be bordered in green.
Step 7:
7)Select MACHINE COORDINATES button again, so that the red border goes away, leaving the SOFT LIMITS button on (Green)
Your soft limits are now operational.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    6 Discussions
    marc erasmus
    1 year ago
    Nice one, thanks for taking the time to make the tutorial. big thumbs up
    ronald44181000
    2 years ago
    I must have asked this question a couple of hundred times over the past 3 months on so many forums that I've lost count. Finally, everything has been answered. Maybe now I can actually cut something on my CNC Router.
    hotaml
    3 years ago
    10q
    MichaelR69
    3 years ago on Introduction
    I have done everything as shown, but my DRO will not set home at zero(s). If I turn off the machine coordinates, then I can zero, but it goes right back to diff. readings for each axis.
    PålK
    4 years ago on Introduction
    Thank you for sharing. This was very helpful!
    djgriff0001
    5 years ago
    Nice post. i'll have to try and configure my software tomight. you don't by any chance know how to set up mach3 for an uneven work surface?
