Setting Up an 800X480 5inch HDMI LCD for Raspberry Pi
12,715
75
10
About: I make things, sometimes they brake
When using the 800X480 5inch HDMI LCD for the first time with the Raspberry Pi the display does not cover the entire 5 inch display. This tutorial will show you how to get rid of the black border on the display .
I will show 2 ways :One editing a file by sticking the micro SD card onto your laptop, the second how to change the file via the Pi's Terminal.
Questions,Concerns, Compliments or Comments all welcome :
@NemesisContrer8
Step 1: Accessing the Config File From Your Laptop
  1. Place your micro SD card into it's adapter and stick it in your laptop
  2. Click on the boot image that appears on your desktop
  3. Click on the file named Config.txt
Step 2: Accessing the Config File From Your Laptop (continued)
  1. Find the comment that says #Uncomment to force a specific HDMI Mode
  2. Add the following lines bellow the comment :
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt=800 480 60 6 0 0 0
3. Press Control+S to save the file
4. Close the page
5. Right Click in your boot image again and select "Eject Volume"
6. Pop the card back into your Raspberry Pi
Step 3: Editing the Config File From the Pi's Terminal
  1. Open the Pi's Terminal (via SSH , Monitor etc)
  2. We need to access a folder named boot which is hidden so type:
cd /boot
3. If you would like to see the files inside the boot folder list them by typing :
ls
4. We need to access a file named config.txt to be able to edit this file type:
sudo nano config.txt
Step 4: Editing the Config File From the Pi's Terminal (continued)
When the config.txt file opens look for the comment saying #Uncomment to force a specific HDMI Mode
1. Right bellow that line should copy and paste or type the following- we will force the resolution of our screen out
hdmi_group=2
hdmi_mode =1
hdmi_mode=87
2. Save the file by pressing --> Control+X then Y and finally Enter
3. Type
cd
4. Finally check if it worked by rebooting your pi with:
sudo reboot
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    10 Discussions
    EveMcWinston
    6 months ago
    Awesome!
    Thank you for your help!
    maryoush
    1 year ago
    Thanks man, that really helped me to sort it out!
    X-wired
    1 year ago
    Thanks, that worked well.
    lcraig09
    1 year ago
    Hi is the second way from step 3? Or should you do the first two before doing step 3 and 4.
    HeinzB6
    1 year ago
    Thanks a lot.
    -- Heinz
    WushNemesisC
    Reply 2 years ago
    my config file is protected, and the system won't let me edit it. How can I change the file's properties so that I can edit it?
    NemesisCWush
    Reply 2 years ago
    Hey Wush !
    Did you use the sudo command to access the file? Sudo just tells the pi you are the super user that has access to any file.
    sudo nano config.txt?
    WushNemesisC
    Reply 2 years ago
    thanks Nemesis, I'm very new to this, that worked. Thanks
