Setup 8bitDo Nes30 Pro Bluetooth Controller in Retropie on Raspberry Pi Zero W and Pi 3
About: I'm a YouTube Maker and Creator who loves to find ways outside of the box to create and use things. My primary mission is to teach what I have learnt in the simplest way possible to all human kind. Follow me...
In this Instructable, you are going to learn how to connect your 8bitDo NES 30 Pro Bluetooth Controller to your Raspberry Pi installation.
If you really enjoy this article, consider checking out my TechWizTime YouTube Channel.
And for an awesome source of Raspberry Pi Accessories, check out my Raspberry Pi Amazon List.
Let’s get started!
Step 1: What You’ll Need
Step 2: Update Your 8bitDo Controller's Firmware
Go to http://www.8bitdo.com/
Go to the "Support" menu.
Select the NES30 Pro Controller image from the list.
Click on the cog under "Firmware"
Select the latest version of the controller's firmware, the download will start automatically.
Grab your controller and press the "Home" and the "Wireless Sync" buttons at the same time until the controller flashes yellow.
Connect the controller to the PC.
Click on the executable file that you just downloaded.
Click on "USB Update" button.
Look for the "firmware.dat" file you downloaded along with the executable.
Click on "Yes" in the window that is going to appear.
Wait for the firmware to update.
Once it does, you can disconect your controller from the PC.
Step 3: Connect the Controller to RetroPie
Go to "Settings" on your RetroPie installation.
Scroll down to "Bluetooth"
Deactivate the "8BitDo mapping hack"
NOTE: If you have problems with this part of the tutorial, try changing the connection mode on the "Configure Bluetooth Connect Mode" from "Default" to "boot" or "background"
Press the "Sync" button on your 8bitDo controller.
Select "Register and Connect to Bluetooth Device"
NOTE: If you don't want to repeat this process everytime you turn on your Raspberry Pi, you can make the controller auto-sync with Retropie by setting up a new dev rule, to do that scroll down to "Set up udev rule for Joypad" and then select your 8bitDo controller.
Step 4: Configure Your Controller’s Imput
Hold the Home button until the RetroPie menu appears.
Select “Configure Imput”
Hit “Yes" Press "A" on your 8bitDo controller.
Press the buttons that match the ones you are being asked.
NOTE: You may have a bit of a problem with the sticks, keep trying until they map correctly or try to configure them later
Congratulations, you’ve just connected your 8BitDo NES30 Pro controller to RetroPie, successfully mapped your imput and that’s it for this Instructable.
If you enjoy this Instructable, consider checking out my TechWizTime YouTube Channel.
And for a good source of Raspberry Pi products, check out my Raspberry Pi Amazon List.
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
