Setup Kodi OSMC & LibreELEC VPN on Raspberry Pi 3 With Private Internet Access Using OpenVPN Exodus
About: I'm a YouTube Maker and Creator who loves to find ways outside of the box to create and use things. My primary mission is to teach what I have learnt in the simplest way possible to all human kind. Follow me...
In this Instructable, you are going to learn how to setup your VPN within Kodi with OSMC or LibreELEC on your Raspberry Pi.
If you really enjoy this article, consider checking out my TechWizTime YouTube Channel.
And for an awesome source of Raspberry Pi Accessories, check out my Raspberry Pi Amazon List.
Let’s get started!
Supplies:
Step 1: What You’ll Need
Step 2: Get Your IP Address
OSMC: Scroll down to “Settings”
Get into “System info” Scroll down to “Network”
Write down your IP Address because we’ll need it later.
LibreELEC: Scroll up to the little cog whell.
Get into “System Information”
Write down the IP Address because we’ll need it later.
Step 3: Download and Install the Zomboided Repository Files
Open up Putty.
Log in with the IP Address you just got.
Type the username and password. (Username: osmc, Password: osmc for OSMC) (Username: root, Password: libreelec for LibreELEC)
Type in “wget https://github.com/Zomboided/repository.zomboided...
After it downloaded get back to your Raspberry Pi to install the repository following the steps for your Operating System
LibreELEC: Scroll down to “Add-ons”
Scroll down to “My Add-ons”
Hit the two dots (..) and go to “Install from zip file”
NOTE: This option will be disabled by default and you’ll get a screen telling it to you, to enable it click on “Settings”, hit “Unknown sources” and then click “Yes”. After you enable it, go back and hit “Install from zip file”
Enter the “Home” folder.
Scroll all the way down to the bottom and select the “zip” file we just downloaded.
After it finishes installing, you’ll be taken back to the screen we were at before hitting “Install from zip file”
Scroll up and select “Install from repository”
Go down to “Zomboided Add-on Repository”
Select “Services”
Select “VPN Manager for OpenVPN”
Choose install.
Go back to the main screen.
Scroll down to “Addon Browser”
Select “Install from zip file”
Go to the “Home” folder.
You’ll be taken back to the screen we were at before hitting “Install from zip file” while the file installs.
Select “Services”
Choose install. Go back to the main screen.
Step 4: Start Up the VPN Manager Wizard
LibreELEC: Go down to “Add-ons” and select “VPN Manager for OpenVPN”
Choose “Add-on settings”
Click on “Wizard”
Choose your VPN Provided, in this tutorial we’ll use Private Internet Access (PIA).
Put your VPN’s username and passowrd.
Hit “OK” Select the location you want to connect your VPN to.
Wait for it to finish and when it does, you’ll be connected to your VPN.
You can check your connection by going to “Add-on settings” and then going to “Display VPN Status”
OSMC: Go down to “Programs” and select “VPN Manager for OpenVPN”
NOTE: You’ll get an error after choosing your VPN Provider, this is because OSMC doesn’t has OpenVPN installed. To install it simply go to Putty again, connect using your Raspberry Pi’s IP Address and “osmc” as username and password; type “sudo apt-get install openvpn” and wait for it to finish, once it does, you can go back to your Raspberry Pi, once you do click “OK” twice.
Go down to “VPN Connections”
Select “First VPN connection”
Congratulations, you’ve just set up your VPN in LibreELEC/OSMC via OpenVPN on your Raspberry Pi and that’s it for this tutorial.
If you enjoy this Instructable, consider checking out my TechWizTime YouTube Channel.
And for a good source of Raspberry Pi products, check out my Raspberry Pi Amazon List.
If you don't have a VPN, protect your privacy with Private Internet Access
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
