Shapes Puzzle for Kids
530
This is a puzzle for kids.
this puzzle contains slotted structures.
This puzzle has slotted structure of circle, rectangle, and hexagon.
The colours used in this puzzle is red glossy and yellow glossy.
The physical material is plastic.
Supplies:
Step 1:
I have started building this puzzle with the help of fusion 360 which is
provided by autodesk.
First of all i have entered in the model work space of fusion 360.
Then I have drawn a rectangle .
I have set the dimensions in centimeters.
Step 2:
In this step i am in the model work space of fusion 360.
Then I have extruded the rectangle drawn in
previous step.
Step 3:
In this step I am in the model work space of fusion 360.
Then i have selected the upper surface of rectangle
to draw sketches of circle, rectangle and hexagon.
Then i have opted the stop sketch icon.
Step 4:
Then i have divided the drawn body along circle.
Then i have divided the drawn body along rectangle.
Then i have divided the drawn body along hexagon.
Now I have four bodies.
Then I have changed all four bodies to components.
Step 5:
In this step I am using the model work space of fusion 360.
Then I have moved the components vertically upwards.
Then i have applied sliding joint between the cylinder component
and the sketched circle.
Then i have applied sliding joint between the cuboidal component and
the sketched rectangle.
Then I have applied sliding joint between extruded hexagonal component and
the sketched hexagon.
Step 6:
In this step i have entered in the render work space of fusion 360.
Then I have changed the physical material from steel to
plastic.
Step 7:
In this step i am in the render work space of fusion 360.
In this step I have changed the appearance of shape puzzle.
I have applied red glossy color to the main body .
Then I have applied the yellow glossy color to the component
cylinder.
cuboid.
hexagonal extruded structure.
Step 8:
In this step I have entered in the animation work space of fusion 360.
Then I have exploded the three components one
by one.
Step 9:
In this step I have entered in the render work space of fusion 360.
In this step I have given different views of shapes puzzle for kids.
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Arduino Contest 2019
