Sharpen Your Drill Bits
688,791
411
179
About: I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my first ...
Sharp drill bits are fun to use. They work so well. Dull bits are dangerous. They can break. One broke for me once and went through my thumbnail and out the other side of my thumb.
Step 1: A Dull Bit and a Sharp Bit
The bit on the left is a little dull. Notice the glint of light on the cutting edge between the two flutes. Compare that with the crisp edge on the freshly sharpened bit on the right.
Step 2: My Favorite Sharpening Tool
People who know what they are doing can sharpen bits by hand. In theory, hold the bit with the shank angled off to the left at about 59 degrees. As the bit contacts the grinding wheel, simultaneously move the shank farther left and downward while twisting it clockwise. I have tried, but I have never been able to make it work for me.
I bought this bit sharpening tool almost 30 years ago for less than $20. The same tool is still available at Amazon and other places, and it is still less than $20.
A Drill Doctor is a very nice tool, but it costs four or five times the cost of this tool. I do not sharpen bits often enough to justify the cost of a Drill Doctor.
Step 3: Set to 59 Degrees
This sharpening guide can accept drill bits with several different profiles. My bits have a 59 degree profile on the cutting edge. Set the tool to 59 degrees and tighten the thumbnut.
Step 4: Catch the Edge
The tool has a small tip and the edges of the bit's flutes rest against it. You may have to raise or lower the tip so it fits against the flute edges properly.
Step 5: How Much Overhang
As a starting point make the overhang (space between the yellow lines) equal to the radius of the bit (space between the green lines). See the next step for why it matters.
Step 6: Width and Angle of the Cutting Edge
Notice the angle of the red line. If there is too much overhang in the previous step, the red line will approximate the cutting edge at the tip of the bit. It is too wide and the bit profile will be too flat. The bit will skate on a metal surface and the hole will be hard to start. You can reduce the bit's overhang quite a bit, but be careful. If you reduce it too much, the tip you adjusted in step 4 may come into contact with the grinding wheel and you will damage your sharpening guide.
Step 7: Ideal Cutting Edge Angle
The ideal is to have the shortest cutting edge possible. This would be a cutting edge that runs between the low points in the valleys of the fluting. See the yellow line. This bit is close to ideal and will cut steel very well.
Step 8: Clamp the Bit in the Tool
When you have the overhang set, turn down the screw that clamps the bit in the tool's trough.
Step 9: Set the Tool for Bit Length
Set the sharpening guide for the length of the bit you want to sharpen. Keep the end of the bit in the moveable trough, not hanging in the air. Loosen the metal colored nut. Adjust the black nut. Tighten the metal colored nut.
Step 10: Align for Height
The end of the bit should be squarely aligned with the grinding wheel. I use a radial arm saw for my grinding. The tip of the bit should be even with the center of the motor shaft.
Step 11: Clamp the Tool to the Table
You want the bit to kiss the grinding wheel while sharpening it. If the bit is too close to the grinding wheel; sharpening will be difficult, the bit will become too hot, and you will remove a lot more material than necessary.
Keep the base of the sharpening guide square to the surface of the grinding stone (green lines), but turn the upper portion of the guide so the tip of the drill bit is just a little to the left of the center (angle between long green line and the yellow line). Slide the guide forward so the bit lightly touches the grinding wheel's surface. Clamp the guide to the table.
Step 12: Get Ready to Grind the Bit
Swing the tip of the bit to the right. Start the motor.
Step 13: Grind
Swing the rear of the sharpening guide to the right (red arrow) so the tip of the bit moves into the wheel. The yellow shower of sparks is added in a photo editing program, but the actual grinding happens when the bit is in about this position.
Step 14: Rotate the Bit One-half Turn
Continue swinging the guide until the tip of the bit is beyond the cutting wheel. You need to rotate the bit one-half turn and repeat the process in order to sharpen the other half of the bit.
It is safer to turn the motor off and wait for the wheel to stop. Loosen the hold down on the bit and turn the bit one half turn. Make sure the flute rests on the guide's tip. Repeat the process from the last two steps.
Shut the motor off. Remove the bit. Check width of the center cutting edge on the bit. Adjust the overhang and repeat the grinding process if it is not satisfactory.
Step 15: The Finished Bit
This is how your bit should appear. Notice there are no longer any worn, rounded cutting edges casting glints of light. Everything is sharp and crisp. The length and angle of the cutting edge at the tip of the drill bit are good, too.
Step 16: Small Sizes
A sharpening guide like this one works well for bits 1/8 inch and above. It does not work with smaller bits than 1/8 inch.
Make a special wooden block to serve as a guide for a handstone when sharpening small bits. The angle of the lines in red is 77 degrees. Make the block about 4 inches long.
Step 17: Compound Angles
This is the edge of the block. The angle between the red lines is 59 degrees.
Step 18: A Guide Line
Notice the "V" in the top surface of the block. It runs the length of the block and makes a place for the small bits to be cradled. The angle between the red lines is also 59 degrees. This serves as a guide line to align with the leading edge of each half of the bit. A visual alignment is satisfactory.
Step 19: Placing the Bit Against the Block
Place a bit into the "V" groove on the back face of the block. Place the block into a vise so the end of the bit rests on top of and against the jaws and so that it just barely extends above the angled surface of the block. Turn the bit so the leading edge of the first half follows the guide line. Use a "C" clamp to hold the bit in place. Put some oil on a small handstone, like those used for sharpening fishhooks. Stroke along the angled surface of the block so the bit is being sharpened at the same time. When the stone is no longer cutting on the bit, turn it half of a turn and sharpen the other side. Inspect the bit with a magnifying glass, if necessary.
    • Epilog X Contest
      Epilog X Contest
    • Warm and Fuzzy Contest
    • Paper Contest
      Paper Contest
    179 Discussions
    RCman50
    4 months ago
    I just bought one of these Craftsman Drill Sharpening Jigs this wknd @ a flea market NOS in the old box for 8$. Should be a welcomed edition to my shop from what I hear from friends who have used them. I'll be referring back to this article just to reread it but it has original instructions.
    Great job friend thank you for sharing
    CBKing
    Question 6 months ago on Introduction
    I also own this drill sharpening tool (from SEARS ROEBUCK). The box identifires it as "CRAFTSMAN DRILL GRINDING ATTACHMENT, No. 9-6677." The instructions and illustrations for using the tool are printed on the inside of the box lid. I can scan to PDF and forward if you have any need for this information.
    1 answer
    Phil BCBKing
    Answer 6 months ago
    Thank you for the offer. I think that is the same sharoening guide I have. I think I have the instructions, yet. I have also finally been able to sharpen most of the bits I use by hand acceptably well.
    CBKing
    Question 7 months ago on Introduction
    I have a Stanley Yankee Push Drill, No 41Y (Discontinued...) Its drill bits rotate both clockwise (on push) and counter clockwise (on release). The flutes on the bits are straight, not twisted. Replacement bits are not available. How should these bits be sharpened?
    Phil BCBKing
    Answer 6 months ago
    My father did electrical work when I was in grade school. I was often his helper, and we used those. After I was married almost 50 years ago, I bought one of those. That was before I felt I could afford an electric drill.
    I would suggest you sharpen them by hand, but very lightly. Point the front end of the bit at the wheel. Swing the back end of the bit to the left between 5 and 10 degrees and lower the bsck end of the bit about the same. Grind away no more than absilutely necessary. Rotate the bit 180 degrees and repeat. Try to keep the peak of the bit centered on the flutes as much as possible.
    Thank you for your question and for the memory.
    CBKingPhil B
    Reply 6 months ago
    Thanks, I will try this!
    theoldguy
    1 year ago
    Freehand sharpening. Hold the shortest thickness at the point vertical. angle the drill up and down WITHOUT turning it.
    The skill is in the angle of the drill to the vertical. If you go all the way to horizontal you have no clearance. And remember the two main things. 1 keep the shortest part of the web at the tip vertical and 2. Don't turn the drill at all when grinding just change the vertical angle.
    WilliamD237
    1 year ago
    2 questions :
    1. How do I find the correct angle of my drill bits?
    2. Whereas you use a radial saw, I have access to a bench grinder with a small wheel, how do I get my hight alignment?
    Thanks in advance.
    Phil BWilliamD237
    Reply 1 year ago
    Most probably the angle on your bits is 59 degrees. That is pretty standard unless you have a very specialized bit.
    Although it is not generally recommended practice, you can sharpen bits on the side of the grinding wheel rather than on the circumference of the wheel. Can you temporarily mount your bench grinder on a riser of some kind?
    Mahku
    1 year ago
    I was struggling with the General drill bit sharpening guide and then found your article. I think it will help. Thanks.
    Phil BMahku
    Reply 1 year ago
    Welcome to Instructsbles. I learned some minor things from my own use, particularly what is in step 11. Check the results you are getting as you go and make minor adjustments. Unfortunately, it is easy to grind away part of the tip against which the flute rests. I began with the directions included with the device and made common sense tweaks. From my side, the purpose of this Instructable was to record those so I did not need to reinvent the wheel after a long period of no use. Since posting this, I finally learned to sharpen drills by hand. It is not nearly as difficult as I thought. A couple of videos at YouTube were very helpful.
    manistylinson
    1 year ago
    Where can i buy that sharpening tool ? I searched on Amazon but i didn't find it ,can you send me the link? Please?
    Phil Bmanistylinson
    Reply 1 year ago
    Amazon does have it as a General 825 drill sharpener. Search for that. It is about $25 plus shipping, etc.
    MikeC286
    2 years ago
    This is a great guide and I managed to get a reasonable edge on my first bit! However I am puzzled by the setup with the drill slightly to the left and then sharpen it from the other side... Ie from right towards the left. As the bit kisses the wheel when setup to the left, how can it be turned back to the right to start sharpening when it will pass through the wheel? If you need to move it the why set it to the left in the firdt place? Also after the first pass how is it returned to the right? Or is grinding done in both directions?
    Thanks again
    Mike
    Phil BMikeC286
    Reply 2 years ago
    You can sharpen by swinging the fixture both ways. What I found was it is tricky to know how close to set the fixture (and the front end of the bit) to the wheel. Swinging the axis on the fixture a little to the left and then moving the fixture up to the wheel so the bit touches the wheel grinds just the right amount off of the end of the bit without grinding either too little or too much. It is just a little thing I discovered for getting the right starting point. I think if you try it y will see why I do it that way.
    cpennell1Phil B
    Reply 2 years ago
    great tutorial! I have the same Craftsman sharpening tool, inherited from my grandfather and I am excited to salvage some wrecked and worn bits. thanks!
    Phil Bcpennell1
    Reply 2 years ago
    Thank yu for looking. Feel free to make adjustments so you get the best results.
