Shed Shelves From OSB / Aspenite
19,866
231
6
About: geek and DYI fan
I had some 5mm thick sterling boards (aspenite, OSB) lying around and was wondering what to do with them. So I came with the idea to build nice looking shelves for our shed.
Aspenite is not very robust and considering it's only 5mm thick you know this wouldn't make stable shelves easily.
So I built triangle support. I'll show you in this instructable.
Supplies:
Step 1: Back Board
First, you need a back to support the shelves. The best way in my opinion is to cut droves in the back board and attach the shelves and their supports using burrs.
So I came up with a board like shown on the picture.
(Note: it's possible to first create the board and cut the droves, but it's better actually to first build the shelves and then dig the droves accordingly to where their burrs come.)
Step 2: A Shelve
I built four shelves like the one on the picture. You see it has mortises that will go into the back board.
It also has tenons where the 3 triangle support burrs will go.
Step 3: The Triangle Support
Here's what I put under each shelves - three of these triangle supports, which now will make it stable.
Each support has a mortise that goes in the backboard and a mortise that goes into the shelve. Obviously all must match.
On the second picture you can see a completed shelve.
Step 4: The Whole Thing
And here is the whole thing assembled. While the droves and burrs do most of the work you still need to use some glue to attach the parts together. I even used small nails put from the back board to strengthen the construction further.
At the end the backboard is attached to the beams in the shed using metal plates. If your shed has wooden walls you can use simply some screws.
I have other projects like this on shedbuilder.info
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    6 Discussions
    grannyjones
    5 years ago on Introduction
    Oh, I get it, droves and burrs are what Americans call mortises and tenons.
    How much weight can the shelf bear? Kg? Pounds? Either is OK. I can do math.
    dyiguygrannyjones
    Reply 5 years ago on Introduction
    Not calculated I'm afraid, but I have already placed plenty of boxes with paint over them and all is fine. For sure each shelve should hold 10-20 kg without problems.
