Shoe Storage Made From Cardboard Pipe
23,468
648
34
About: Hey guys! We are Van Squad! Professional company based in London, United Kingdom. We do removals and man and van (which is the equivalent of a moving company) here and we try to be the best at it too. On ...
We tried to experiment on this one and made our very own shoe storage made from cardboard pipe. These pipe are actually concrete forms. They come in sizes up to about 3ft (1m) in diameter and are quite tough. However, if you have wet shoes, let them dry for a couple of hours before putting them on this shoe storage. As all of our ideas so far, this one can be upgraded with using different paint and finishing and whatever you may find useful.
Step 1: Buy the Tubes
In the professional world these are known as cardboard tubes for concrete (cement) footings and come in variety of diameters ranging from 16.5 cm (6.5 inches) to over 1 meter (40 inches). We bought them from a local shop since the UK version of Home Depot Wickes didn't have any available.
Step 2: Cutting
The tubes come cut in 1.2 metres lenghts. With some basic math we get four 30 cm pipes out of it. These pipes will be the actual storage where you put your shoes. Check out this shoe size chart to get an idea how big your shoe compartments should be. Cut the pipe using a saw.
Step 3: Paint It (Optional)
We used some old varnish lying around. You can experiment with this part.
There were a couple of questions regarding this step and whether or not it's better to paint before or after the gluing part, we find that it is better to first paint and then glue everything together. This way you will have more control over the spreading of the paint over the edges and the sides of the tubes.
Step 4: Gluing
We used PVA glue to hold everything together. Silicone glue should also do a good job. Since this is a sort of modern design, you can create different shapes, you can decide how tall should the structure be and so.
Step 5: The End Result
Probably the best DIY shoe storage option out there. Our team recommends!
Crafting 101
Runner Up in the
Crafting 101
  • Jewelry Challenge
    Jewelry Challenge
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
34 Discussions
tomatoskins
4 years ago on Introduction
Would you suggest painting before you glue everything together? Or was it easier to paint the whole thing all at once?
VanSquadtomatoskins
Reply 4 years ago on Introduction
We suggest painting everything before you get to the gluing part. Although it will be more time consuming, you will be able to paint everything with better attention to details like the sides and edges.
bd5
This type of instructable is one of my favorite. Good job! Everything about it! It's simple, it looks good, it's inexpensive, it's very practical and fun! A suggestion, to make the tubes stiffer, you could get a good quality wood glue (like Titebond), put some in a pan/container. Mix as little water as possible, how little?--> Just enough to where the glue/water soaks up completely without leaving any traces on the surface. The tubes will be much stronger. Great instructable!
cammosutrabd5
Reply 2 years ago
Unless I misunderstand something , your titebond "improvement" is not waterproof. And that is the weakness of these: if they get wet. I have worked with those tubes on concrete pours. No offense, but you apparently have not. If you don't think they are tough enough already, I
have to ask: what in Hell are you planning to do with them?
cammosutraFuzzy Lollipop
Reply 2 years ago
Getting a clean cut is THE trick. You will probably want to leave the factory edge out and bury the cut edge no matter how well you do it. It can be cut on a line with a razor knife, but not easily: be patient and don't use force. And a cut is only as good as your line. A skillsaw or sawsall will cut it, but you will have to clean up the edges somehow. With concrete forms, a perfect edge is of zero concern. For finish work, I would use a skillsaw or table saw and figure out a guide or a jig. If you figure out how to duplicate a factory edge, please let me know. I don't think they make pipe cutters that big, but that would sure do it.
cammosutra
2 years ago
cammosutra
a few seconds ago
Yeah, I WOULD paint the cuts. For the record - - these things
are called sonotubes. No clue why, so don't ask me. But if you show up
at a Home Despot, or Less Of What Eagle Sold (LOWES), or wherever, they
are in the section with the concrete stuff and that is what they are
called. The trick, in my experience, is getting a perfectly
perpendicular cut, and they are to big for most chop saws. The are used
for forming concrete columns and are usually just left there: if you
strip them, they will come off in a spiral or in chunks. They suck up
moisture and go to Hell, if they get wet! I would paint or re coat for
this use. Cool stuff. Have fun!
cammosutracammosutra
Reply 2 years ago
I should add a PS. A BIG PS. This is heavy duty cardboard with center
full of air. It is flammable! A sonotube can catch fire and burn in this
sort of application. Don't put it near something that can set it on
fire or vice versa.
T0BY
2 years ago
I want one!
Giulia Art
3 years ago on Introduction
Congrats on making finalist! How was your sleep until now?Are you waiting for the big announcement? What prize would you like to receive? :D
mxx
Great idea! Regarding the problem with wet shoes, of course you could also give the inside a thorough coat of varnish, which should make them watertight enough.
VanSquadgrogers8
Hey, sorry for the late response. The ones used in this instructable are 26 cm (or 10.2 inches). This diameter is suitable for lighter shoes, sandals, sneakers etc. We recommend bigger diameter for the heavy winter shoes.
Ecchigrogers8
I was wondering the same! :) This part seems to be missing from the instructions :(
LinSue
Wondering if oatmeal boxes are strong enough to use, I have quite a few saved. Great idea!
I recently moved house and need a place for my shoes. Guess there's no point in ordering anything from Ikea now when I have this idea :D
RCMann54
Shoes? OMG this would be great to hang on a wall and use for all my yarn!
