Shower in the Jungle
11,442
238
7
About: Lifestyle blogger in the city
We're officially obsessed with indoor gardening and plants in general. I decided that we needed plants in every single room of our house and wanted to shower in a jungle, so I built our own 'raining' plant hanger. It took less than an hour to build and was easy to hang from the ceiling. Make one for your shower using our guide below!
Supplies:
Step 1: Step 1: Gather Materials
(1) 1x1x8 board
Chicken wire cut to 1'x2'
(1) Roll fiberglass screen
Staple gun and staples
Wire cutters
Needle nose plyers
Wood Screws
Drill
Plants
Small gauge chains
Metal hooks
Soil
Step 2: Step 2: Cut Wood
Go to your local hardware store (we went to Lowes) and pick up your supplies. If you don't have a saw, ask the wood department to cut your board into 2 pieces: (2) 2' sections and (2) 1' sections
Step 3: Step 3:
Layout your boards in the shape of a rectangle and pre-drill the holes so you wood won't split when you screw them together. Screw all 4 boards together.
Step 4: Step 4: Chicken Wire
Cut your chicken wire with the wire cutters to fit the rectangle and then staple around the edges so it's tightly secured. Cut off the excess chicken wire around the edges.
Step 5: Step 5: Fiberglass Mesh/ Screen Door Mesh
Fold over your fiber glass mesh 4x so it's thick. This will keep your soil from falling out. You can fold it more or less depending on how thick your mesh is. Staple it around the edges, right over top of the chicken wire layer, so it's tightly secured.
Step 6: Step 6: Hook It Up...Literally
Add your hooks to the corners of your planter. Our hooks had clamps, which made it easier to hang. Then screw your 4 regular ceiling hooks into the ceiling, after you have measured the right distance.
Step 7: Step 7: Plants
Take your plants and separate them by gently breaking apart the soil and dividing them by the root. I picked plants that required very low lights/ plants that like to be damp or moist. The reason for this was the room that houses the shower is small and doesn't have much light.
Step 8: Step 8: Measuring the Holes
Measure out where you want each plant to go on the black mesh (this is where you will make holes for the plants). We made holes 2 inches apart using a ruler. You can use a knife to make each hole.
Step 9: Step 9: Rooting
Gently feed the roots through each hole and add a layer a soil that completely covers them.
Step 10: Step 10: Hang Planter
Moisten the soil so you can see the roots and layer with more soil. You can continue to add more soil wherever needed. Hang your planter above the shower and get ready to enjoy a jungle feel!
Indoor Gardening Contest 2015
First Prize in the
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    7 Discussions
    ehaight6
    3 years ago
    So cool! This is on my list of 'must do's'. Thanks for the great idea!
    mechanic_koli
    3 years ago
    very nice,
    sure deserve vote.
    ashleyjlong
    3 years ago
    Great project! Do you have to water the soil on top once in a while, or does the moisture/ steam from the shower keep things hydrated for you?
    That is a really interesting way to set up a hanging plant. I never thought hang a pothos upside down.
