Shrunken Head
2,339
27
7
About: I'm just a poor high school student who loves video games, pasta, and sleeping in.
Ernie, the Knight Bus driver, has a sweet talking shrunken head, to keep him company on his many driving adventures. I made the shrunken head from Harry Potter for one of my fellow Pottheads who just got his license, but I never gave it to him because I loved the look of a severed head hanging from my ceiling for Halloween :).
"Take 'er away Ern,"
"Yah, take it away Ernie, this is going to be a bumpy ride,AHAHAHAHAHA,"
Disclaimer: I would not recommend putting this in your windshield, because it will obstruct your view. Don't be stupid, it's a lovely decoration, but I don't want to be responsible for any car crashes.
Step 1: Materials
  • expanding foam
  • paper clay
  • wood glue
  • Mod Podge
  • yarn
  • acrylic paint
  • beads (or aluminum foil, i'll explain later)
  • wire brush
  • Elmer's glue
Step 2: ....................10
Most of y'all probably don't have a head replica of your head (it didn't turn out) to carve up, but a pile of expanding foam will probably work the same. I carved it into with a serrated knife, until it was about the size of a bludger.
Step 3: ....................9
I then paper mached it.
Note: The paper mache is made out of 3 parts glue, 2 parts water, and 1 part flour. Instead of newspaper I used paper towels, because it is smoother. However it does take longer to dry.
I let it dry on a cup pic 4
Step 4: ....................8
I coated the paper mache in wood glue because the clay I used to sculpt everything, sticks magically to it.
Step 5: ....................7
Now that the glue is a dry as the books that you so desperately cling to (lol Trelawny), it's time to give this head a little bit of shape. I used a paper clay called Delight because it is lightweight and doesn't shrink which means no cracking.
I started out by just putting blobs where there was more fluff on his face (cheeks, nose crest, upper forehead), then I took a blob, rolled it into a circle, and made it into a nose. The shrunken head (I think his name is Dre Head), had almost no bridge on his nose, so I didn't have to worry about building that up very much.
Dre Head has some big lips, that are in no way symmetrical. I just rolled out some clay and stuck it to his face in a mouth-y shape.
Step 6: ....................6
For the eyes I rolled out a tiny ball of clay, and put a slit where they eyelids meet, after that I gently stuck it to the head with a tooth pick.
Note: Dre Head's eyes are slightly farther away from his nose than a normal head's eye's would be
Step 7: ....................5
I brushed over everything with a coarse brush and some water, so that it was smoother, then I built the forehead up a little more clay( I ran out of paper clay, so I had to use a different kind )
Step 8: ....................4
Dre Head has some sweet dreadlocks. At first I couldn't figure out how should attempt them, but then I just grabbed a ball of yarn and started experimenting
I first cut lengths of yarn ranging between 6-16 inches. Each dreadlocks has 4 pieces of yarn in it. I tied the yarn together, then took a wire brush and aggressively beat the crap out of it, until it was frayed (the more you fray it, the better it will look). I taped the dreads onto a surface so they could dangle down.
Step 9: ....................3
I made a mixture of glue, black acrylic paint, and water, and applied it to the yarn, making sure to rough up the frays, and stick everything together.
Step 10: ....................3 1/2
To paint it, I started out by applying a troll booger color all over the head, then went in and tinted the lips, eyes, and where the shadows naturally fall. After that I added some highlights, on the nose and browbone
Step 11: ....................2
I literally shoved a skewer though Dre Head's temple, then pushed a string through that , I later added another string in the back of his head, so it looked kind of like a tee-pee of string.
I glued the dreads on with hot glue, starting with the smaller ones, and ending with the larger ones.
Step 12: ....................1 3/4
I made some beads out of aluminum foil, that I twisted up then shaped into circles. I painted them green and yellow and stuck them in his hair.
Step 13: ....................YES!
"Mind your head! HA HA HA HA HA"
    • Weaving Challenge
      Weaving Challenge
    • Paper Contest
      Paper Contest
    • Organization Contest
    7 Discussions
    shashankvkt8
    2 years ago
    its amaziiiiiiiinnnnnggggggggg!!!!!!!!!!!!!!!
    asmi1991
    2 years ago
    brilliant work, voting for you :)
    jessyratfink
    2 years ago
    Dang! You're an incredible artist when it comes to 3D. It's perfect!
    XaviOrin
    2 years ago
    Amazing work! I'm totally going to have to make this for my wife!
    rainingfictionXaviOrin
    Reply 2 years ago
    Thank you :)
    When you finish, please do the whole I Made It thing, I want to see :)
