Si4703 FM Radio Arduino Uno Schield
7,476
55
12
2 months ago I was made FM radio by TEA5767 chip ( Arduino Uno shield). I was used with TDA2822 sound amplifier chip. Everything it works, but I get information that it is another Si4703 FM board who had RDS. So I don't waste mine time and create another Si4703 FM radio.
Step 1: Parts
To build this Si4703 FM radio you will need :
1) Si4703 board Ebay
2) 2x Rotary encoder Ebay
3) Oled I2C 128x64 Ebay
4) 2x 22k 0805 resistor
5) 2x 1K5 0805 resistor
6) 2x 4R7 0805 resistor
7) 2x 0.1uF 0805 ceramic capacitor
8) 0R 1206 jumper ( resistor)
9) copper board
10) TDA2822 DIP8 amp chip Ebay
11) 3.5mm audio jack socket Ebay
12) 3x 470uF electrolytic capacitor
13) 2x 10uF electrolytic capacitor
14 ) 1x 40pins header pins
Step 2: Wiring Diagram
Step 3: PCB Board
Design printed circuit board (PCB), I was used ,,Sprint-Layout" software.
Exported to Gerber files.
Step 4: Arduino Code
Si4703_Radio_rssi_manual.ino - manual tuning
I was used libraries:
Si4703_Breakout.h link
U8glib.h GitHub
Step 5: 3D Printed Case for FM Radio
Step 6: Final Result
If you want to add external antenna you will had to cut pcb track between capacitor and ground (see photo).
It show RDS data but signal strength has to be very good. Oled display generator are making noise. So sound quality is not very good. It is made by myself, so I am very happy.
3 People Made This Project!
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
12 Discussions
StefanoB32
6 months ago
Hello, everything works unless the radiotext is not displayed.
do you know any solution?
RimvydasPStefanoB32
Reply 6 months ago
Radio signal strength is good? If radio signal strength is not good RDS will not display.
StefanoB32RimvydasP
Reply 6 months ago
Rds , id and name of trasmitter si ok ! The extended radio text is not present ...tommorrow send you my modyfied sketch ...
StefanoB32
Question 7 months ago on Step 4
Good job, I ask you if you can show all the contents of the RDS.
Currently
only shows the name of the transmitter, but I would also like to see
the text content inside the variable char RT ... if you can help me edit
the sketch ...
RimvydasPStefanoB32
Answer 7 months ago
#define DEBUG 0 //change to DEBUG1 it will show in serial monitor more information. Press ,,R" and you will get more RDS information from radio station. check
void displayRDS (void) PS, PTY, EON, TP, TA
StefanoB32RimvydasP
Reply 7 months ago
hello I have already enabled debugging and I get all the necessary information But there are other info contained in the variable char RT.With the char PS I get the name of the transmitter, in the RT char there are other information that are not shown, the question is where to insert a cycle of reading and printing of the RT, this is a text of 60 characters, here in Italy used..
PS Rai Radio1
RT RAI ITALIAN RADIOTELEVISION NEW SERVICES RDS EON TA
sigifredo
1 year ago
HI
wich of the 2 chips gives u better performance or audio quality???
RimvydasPsigifredo
Reply 1 year ago
Hello,
Si4703 FM you can listen radio with headphones without amplifier. If you are using TEA5767 you will need amplifier because sound level output is weak. Audio quality it is the same.
sigifredoRimvydasP
Reply 1 year ago
thanks for the response, I purchase both of them with other accessories to make my own one on a real exotic hard wood CNC case, the wood is easy to find here in Costa Rica...
What about a reception comparison?
Ambrogio
2 years ago
Good project: I will make it soon.
Could you please post the schematics diagram or the connection diagram ?
Thanks
Ambrogio
JmanNZ
2 years ago
Awesome well done
