Sided Childrens Apron
1,152
19
This apron can be worn on 2 sides!
Supplies:
Step 1: Pattern Pdf
Print the pattern and paste it together
Cut one site in a boy fabric and one site in a girl fabric.
Cut two pieces of the hart and two for the pocket.
Step 2: The Hart Pocket
Place a layer of fiberfill between the two layers of the heart.
And sew the two pieces together.
Step 3: Girl Side Pocket
Sew the pocket on the apron, but leave the top open
Step 4: Boy's Pocket
Place the right sides of the pocket pieces together and sew them but leave an opening at the top.
Trim the corners diagonally.
Step 5: Turn the Pocket
Press the seam flat and sew the bag around narrow on the side
Step 6: Sew the Pocket on the Apron
Leave the top open
Step 7: Straps
Press the straps in half with the right side of the fabric together. and stitch them shut, let one short side open for turning the straps.
Cut corners diagonally and turn the straps right side of the fabric to the outside.
Press the straps flat and sew them narrow on the side through.
Do this also with the loop.
Step 8: Put It All Together
Lay the apron pieces right sides of the fabric together with the straps between them.
Stitch the apron pieces together but leave the top open.
Step 9: Curves
Cut small triangles away from the curve and turn the apron with the right side of the fabric to the outside.
Fold at the top the seam allowance inside and press all seams flat.
Step 10: Finish
Put the neck strap with the d-ring between the apron and stitch the apron narrow on the side.
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    2 Discussions
    goldilockets
    3 years ago
    You gotta be a Super-Grinch to say anything bad about this project!Too cute!-goldilockets6696
    gG
    seamster
    3 years ago
    This is excellent! Thank you for sharing this, and for including the pattern.
    Welcome to instructables! :)
