Simple, Affordable, High Quality Solar Eclipse Viewer From a Cereal Box
16,531
36
29
With the solar eclipse coming in less than two weeks the demand for viewing aids soared. Unfortunately many glasses on the market do not provide protection recommended by NASA (Welding glass shade #12-14). And good quality viewer will cost you a fortune.
This is a tutorial to help you to turn an empty cardboard box into a solar eclipse viewer. Because there are so many different sizes of boxes, welding glass pieces and face shapes, this intractable doesn't have precise templates.
Step 1: You Will Need
There is still time for you to order welding glass of the recommended shade. Shade #12 lets more light in and you will see a little bit more details, shade #14 is the safest choice. Welding glass comes in different sizes, in this tutorial we used PROSAFE welding glass DIN12, 2 inches wide by 4 1/4 inches long.
You will also need an empty cereal container at least 2 inches wide, basic tools like scissors, ruler, pencil and double sticky tape and foam (if you don't have it, use adhesive of your choice). Double sticky foam was used to level surface around the glass.
Step 2: Cut Your Box
First you will need to cut top part of container to fit the curves of your face. Because everyone's face is unique in it's beauty we did not put a template here. Start with cutting a semi-circle (about 4 inch wide by 1 inch deep for younger generation and 5 inch by 2 inch for bigger specimen). Try your cardboard visor on and adjust to fit snug, you may also want to cut an incision for the nose.
When you are happy with your fit, position your glass in the center of the bottom of your box and trace the outline with pencil. Measure 1/4 inch inward from each line and draw the cutting lines. Using scissors or craft knife cut an opening.
Step 3: Adhere Glass to the Box
Apply 1/8" or 1/4 " wide double sticky tape around the edges of the glass on both sides. Position your glass over the opening, remove protective tape and press glass firmly to the box. Press around the edges to make sure there is no air bubbles. If you don't have tape, use adhesive of your choice.
Double sticky foam was used to even out the surface of the box around the glass, you can use a shim made out of cardboard.
Step 4: Create Cardboard Cover
Cut a piece of cardboard same length as the length of your box and 2-3 inches longer than it's hight. You want to overlap the wide sides like you see on the picture. Score the folding lines and trace an opening of the same size as you cut in the bottom of the box. Dry fit to make sure all measurements were done right.
Remove the protective tape from your double sticky tape on the glass and foam. Carefully press the cardboard to the tape. Press around the edges making sure there is no air bubbles.
Fold the flaps down and adhere them to the box with double sticky tape. Tape over the edges and entire box with Gorilla tape to increase durability.
Step 5: Finishing Touches
Carefully test your viewer first not looking directly at the sun. It should block most or all light. If your have leaks, add a little bit more tape in the places where you can see sunlight. You can decorate your box with felt, vinyl, etc. Apply a strip of foam around the edges to soften the edges and eliminate light leaks. And, while you are at it, make one for your camera!
  • Tape Contest
    Tape Contest
  • Gardening Contest
    Gardening Contest
  • Trash to Treasure
    Trash to Treasure
29 Discussions
rsgrillo
1 year ago
Just get a spare welding helmet from someone who welds or Harbor Freight, welding supplies anywhere, etc.
staticrsgrillo
Reply 1 year ago
One can't know what filter is installed in a borrowed welding helmet. One may think there protected when they ma not be. The same can true with grabbing a new helmet off the shelf. Because my helmet was never returned by the person that borrowed it I went to purchase a new one. I pulled out the filters to see if they where marked, none where. when there's doubt what filter is in a helmet purchase a new filter that's cleaclearly labeled on the packaging and the packaging is intact. Tape or otherwise adhere the pertain portion of the label to the filter so there's no question the next time viewing the Sun is on the schedule.
aCuriousCreator
1 year ago
This is cool. Shame we have to wait untill 2090 in the UK to get anther full eclipse! great post
1safetyguy
1 year ago
Looks pretty good. However, some additional tips:
1) Buy your welding glass from a welder supply company such as: Airgas, Praxair, etc. Many towns and cities have them. Or, even some home supply and hardware stores have them. I wouldn't trust my eyesight or my kids/grand kids to some of the stuff online.
2) Just take a piece of cardboard and poke a hole in it with anything, even a pencil. Hold the cardboard facing the ground (asphalt, concrete driveway/side walk) and watch the eclipse happen "on the ground". This is totally SAFE, cheap and works well too. We did it for a solar eclipse back in the 80s or 90s and were surprised how well you could view the eclipse. Simple and Safe!
Remember: You only have two eyes and you can't grow another!
IrynaC1safetyguy
Reply 1 year ago
Thank you for the great tips!
The glass absolutely has to be purchased from reputable welder supply company.
oboist1
1 year ago
Just ordered 2"x4 1/4" #12 Welder's Glass from eBay for $2.50 with "Free and Fast" Delivery. Mine will arrive on on or before Friday, 8/18. Check your delivery date by typing your zip code into the seller's delivery section.
lukee1986oboist1
Reply 1 year ago
these r $1 and u do no making
http://www.ebay.com.au/itm/Solar-Eclipse-Glasses-2017-Edition-CE-and-ISO-Viewing-Solar-Glasses-Toy-/282572810166?var=&hash=item41caa6e7b6:m:mn4nDwdssWdcqjNYYPi3dNg
Cayoticaoboist1
Reply 1 year ago
what company please l can't find anything less than 10 that will promis delivery before eclipse day
oboist1Cayotica
Reply 1 year ago
Search eBay using: Glass welding filter plate shade 12
After you get your search results:
click ebay's SORT button then
click "price+shipping:lowest first"
barrenweldsupply is the company on eBay selling 2"x4 1/4 #12 welder's glass for $2.50. VERY IMPORTANT: CHECK YOUR DELIVERY DATE ! Type your zip code into the seller's delivery section for an estimated delivery date.
Cayoticaoboist1
Reply 1 year ago
tks very much, l am not very good with Ebay try as much as l could l never got close to your results until l followed your Instructable. Great horse for future searches.
IrynaCCayotica
Reply 1 year ago
Metalwork Supply Company offers 2 day delivery. Their price for glass is same.
https://www.mscdirect.com/
IrynaCoboist1
Reply 1 year ago
"Check your delivery date by typing your zip code into the seller's delivery section" This is very important!
IrynaC
1 year ago
Amazon recalls eclipse glasses!
charlessenf-gm
1 year ago
I saw some viewing glasses at LOWES fro #3 or so - cardboard with dark lens. Similar to what they sell for 3d viewing of movies, albeit with a much denser/darker lens.
