Simple Battery Spot Welder
15,322
77
5
About: I'm a tinkerer and a DIYer. If it can be made rather than bought then I'll always have a go. A lot of the things I make simply can't be bought anyway!
As part of an electric bike project I needed to weld 70 18650 Li-Ion cells together. I could have just bought a battery welder but where's the fun in that? This is my build. Nothing complicated and it didn't need to last too long.
Step 1: Parts List and Tools Needed
Parts:
Tools:
  • Screwdrivers
  • Drill
  • Soldering iron (60W+)
  • Solder
Step 2: Wiring Diagram
This is the circuit we're going to make.
The timer relay can be set to be closed for 0.15s when the button is pushed. This in turn fires the starter solenoid, which allows current to flow down the electrodes, creating the weld.
We could do without the timer relay and just control the weld by varying the time we press the button for but it gives a lot more control.
Step 3: A Solid Base
We don't want the battery floating around the workbench so we need to construct a solid base for it.
Take some 3/4" MDF board and cut it to be 4" wider than the battery and about 4 times as long to give a good welding area in front of the machine.
Cut some 1" x 2" wood and screw it to the board to form the area where the battery will sit.
Step 4: Mount for the Button
Add some more 1" x 2" on the top of the enclosure we just made and cut a hole in it the same diameter as our firing button.
Step 5: Mount the Button
Mount your button in the hole we just made and feed the wires out of the bottom.
Step 6: Test Your Circuit
Wire everything together as shown in the previous wiring diagram and test fire it, making sure that both the relay and the solenoid fire as expected.
Step 7: Mount the Solenoid
We don't want the solenoid floating around so take some of the 10mm x 2mm steel bar and drill 2 holes in it. This will serve as both the positive contact and a solid mount.
Step 8: Electrodes
Take two of the copper nails and cut the heads off them. These will be inserted in to the choc-block to form the electrodes.
Step 9: Main Wires
Cut down some of the copper cable and mount some choc-block on the end. Insert the copper nails in to the other end and bend the wires until the electrodes are vertical and the wires are horizontal.
Screw one wire to the -ve terminal of the battery and the other to the output of the starter solenoid.
Step 10: Test
Grab a battery you don't care about and test it.
You will need to experiment with how much pressure to apply to the electrodes but with a little practice you will be able to do a consistent weld.
I used this welder to build the battery for my electric bicycle: https://www.instructables.com/id/Convert-a-Full-suspension-MTB-in-to-a-Go-anywhere-/
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    5 Discussions
    jph99
    14 days ago
    Did similar using arduino as timer - not sure about timings, set at 0.15s, but is there a delay due to solenoid action? And are the electrodes critical, just using thick copper wire for mine, maybe there is a better choice and what about shape of ends?
    Cheers JP
    Global montage
    4 weeks ago
    At our blacksmith's workshop it is probably not quite enough, our welder is secured with 32 Apm and we sew 2 x 1.5 mm steel plates together for garden fence posts
    note :The picture shows how our poles look when they are put up in the garden
    https://globalmontage.dk welding company
    https://global.hegn.dk the company we are makeing the garden fence posts to :)
    Mikel99
    3 months ago
    Very nice. I am going to save myself the $100 for sunko unit and build this. Will use an arduino to control the 5v relay instead of the time delay unit. It should come in at well under $50. And, of course, is much much more fun. Beat the system, yeah!
    Ad5000DOnnell
    8 months ago
    I built my own and was just wondering about the relay it turns off after like 1.5s which is too much time and I’ve changed out the jumpers to the shortest time and turned the knob as far as it could go I was just wondering if you or anyone else was having this issue as well?
