Simple Blinking LED Circuit
224,062
215
52
A very simple circuit that you can build to blink or flash LEDs. The circuit is built using transistors, resistors, capacitors, and LEDs. Of course you will need a breadboard, wire jumpers, and a power source. The parts list includes:
  1. PNP Transistor, P/N 2907A, qty: 2
  2. Resistor, value 470 Ohms, qty: 2
  3. Resistor, value 100k Ohms, qty: 2
  4. Capacitor, 10 uF, qty: 2
  5. LED, Qty: 2
  6. Breadboard
  7. Jumper wires
Let's get started:
Supplies:
Step 1: Add the Transistors
Add the two PNP transistors and the jumper wires from the power BUS to the emitter of each transistor. Because of the way I inserted the two transistors the emitter is on the left side of both transistors.
Step 2: Add the Capacitors
Connect the two capacitors to the circuit. Connect the positive lead of the first capacitor to the collector of transistor 2. Next connect the negative lead of the same capacitor to the base of transistor 1.
Repeat the above process for the second capacitor. Connect the positive lead of the second capacitor to the collector of transistor 1. Connect the negative lead of the same capacitor to the base of transistor 2.
Step 3: Add the 100K Resistors
Next connect the 100k resistors to the transistors. One lead of the resistor connects to the Base of the transistor, the other lead connects to ground. Do this for both transistors.
Step 4: Add the LEDs
Finally add the two 470 Ohm resistors along with the two LEDs. I added a picture of a transistor to identify the Emitter, Base, and Collector.
Connect one wire of the first resistor to the collector of transistor 1. The the other resistor wire then connects to the positive wire of the first LED. The negative wire of the LED is then connected to ground.
Follow the same steps for the other resistor and LED. Connect one wire of the second resistor to the collector of transistor 2. The the other resistor wire then connects to the positive wire of the second LED. The negative wire of the LED is then connected to ground.
Step 5: Supply Power and Watch the LEDs Blink
The last step is to supply power and watch the LEDs blink. I use a 9 volt battery and it worked fine.
For fun you can try other capacitor values to change the rate at which the LEDs blink.
12 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
52 Discussions
matelot2likeeachother
Answer 2 months ago
any capacitor with a voltage larger than the supply. The large voltage capacitor you use the large the capacitor will be phisically. Anything above 10 times the used voltage will fail, electrolitic capacitors don't work too well at 10% of their voltage rating.
keys-da
2 years ago
This is a really useful circuit. Do you know what modifications I would need to make to get it to work using an npn transistor? Thank you.
matelot2keys-da
Reply 2 months ago
google astable multivibrator. you will get lots of similar circuits, most of them with npn's
BreaV
Question 1 year ago on Introduction
Could you add more LEDs? Per say 8-12? How would this change this circuit in terms of power supply and other components?
SergeyS85
1 year ago
Thanks a lot for the nice guide!
And here is our circuit we've built today with my 7 yo daughter (she helped me a lot); we used different capacitors to make LEDs blink faster.
pilimotta
Question 1 year ago on Step 5
Thanks a lot for your time sharing that cool project. ¿Could you suggest another type of transistor that one can use insted?
BunnyGee
Hi. My first ever post on this forum, having just joined because I saw your Instructable.
I want to make a simple flashing on and off LED sign but using 187 LEDS (an 11x17 LED pattern).
The LEDs would be mixed white LEDs and blue LEDs.
Would it be easier for me to attach the sequence of LEDs to a simple off/on switching connector (and if so, how would I make such a connector, do you know, please)?
Thanks for bringing me here with your Instructable.
george1121
1 year ago
If I wanted to make the circuit without using a breadboard, where would I connect "ground"? thansk
george1121george1121
Reply 1 year ago
This is what I got on internet search--so, the "ground" is the negative terminal of the battery?
"In most circuits these days, "ground/reference" is the most negative terminal of the power supply, so voltages elsewhere are positive relative to "ground".
RobertF264
1 year ago
hmm, my post vanished after deleting, hope this doesn't duplicate. Is there a way to make this setup without a breadboard and maybe streamline the wiring? I am looking into wiring up some LED lights to my bike and I wanted to use a hub to power them. Looks like the hub produces 6v 3w and the lights require 4.4 w for 15ft of continuous light length. I wont be using that much length so I was kind of lost on what the calculations would be and was going to wing it with the power match up considering the total produced is a bit less than whats needed. Anyway, it would be nice to get these lights lit up enough to help me stand out because I have a recumbent trike that sits roughly 26" from road to top of seat off the ground and I would like to be way more visible. I like tinkering but I was hoping you guys might be able to steer me (no pun intended) in the right direction. I understand the laws of thermodynamics (I think..) which states you cannot make more energy than the energy it takes to produce said energy (or something to that effect). Like taking a solar powered car and adding wind turbines on them. You would far sooner drain the battery trying to reach a speed high enough to reclaim anything substantial with the turbines. Thats at least the way I understand it, but back to the question at hand. Is something like this possible? Any help with this would be appreciated.
Mishainabox
2 years ago
If I wanted to add 2 more LED's where would I place them?
aravindk39
2 years ago
Using audrino is easy
RichardO82
2 years ago
Does anyone know if i replace the leds with a buzzer will it work? Im trying to get a buzzer to buzz on and off instead of a constant buzzzzz.
tgray1shiny301
Reply 2 years ago
We call them BLFNARs (pronounced "Blif-nars"), which is Blinky Lights For No Apparent Reason. A vital part of any electronics project!
CsabaB9tgray1
Reply 2 years ago
Mwhahaha this answer made my day! Quite agreed!
Eh Lie Us!tgray1
Reply 2 years ago
Sir/Madam, that is a fantastic answer.
