Simple DIY Mailbox
2,293
14
About: I make furniture, and videos of me making furniture.
Obligatory finished product first (with a little photoshopping color change for fun)
You can also watch a full video here
Supplies:
Step 1: I'm Using Maple
I started off with an S4S piece of maple. .75" thick and about 70" long and 8.5" wide
Step 2: Cross Cutting
I started by cross-cutting out two pieces to about 22.5" - these will become the front and the back.
Step 3: ...ok Well Now I'm Cutting
Technically in the last step I was just measuring :)
Step 4: Ripping
Next I ripped all my pieces to their finished widths. The only trick here was the top. I had to cut it out of 3 pieces in order to leave myself with a slot for the mail to stick through.
Step 5:
Next I glued my top together. Then I took one my little rip to ensure that the top piece and bottom piece (one solid piece) were the exact same width.
Step 6: Joinery
next, I started working on joinery. It's all rabets. In the drawing here you can see I've cut one along the top, bottom, and back edges of the front and back panels. and along just the back edges of the top and bottom panels.
Step 7: Priliminary Rabet Cuts
Here are the initial rabet cuts. Then I just kept going until all of the material was removed.
Step 8: Sand Them Clean and Mark a Line
After I sanded all of the ridges left from the blade flat, I marked a 15* line (purely decorative) on the back panel.
Step 9: Make It Fancy
Then I cut it on the saw
Step 10: Make It Extra Fancy
I painted the inside of the back panel green to match my front door.
Step 11: Glue It Up
Next I glued the front, back, top, and bottom panels together
Step 12: Put a Cap on It
Then I cut and glued in this little cap piece for the end where mail doesn't go in. I'm sure there's a technical name out there that only mailmen/women (postal employees?) know of...but I'm too lazy to figure it out. the "non-business" end :-)
Step 13: French Cleat
I attached it to the wall with a french cleat. I also used a few spacer blocks so that the whole thing sits out from the wall equally.
Step 14: Sand
...sand it. I went up to 180 grit
Step 15: Finish
I used a few coats of Arm R Seal wipe on
Step 16: Done
That's it...thanks for reading. Again, you can see the full video with more detail here
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    tomatoskins
    1 year ago
    I like the simple modern design! That little bit of color makes it look even better!
