Simple Little Fire Pit
1,584
16
8
About: I am a young engineer who enjoys making and restoring whatever I can in my free time. I like the challenge of making new things with the tools I have available.
If you happen to be in the same circumstance as I was where you wanted a fire pit but due to having a small backyard, Townhome, none of the store ones were small enough then this might be what you are looking for.
I wanted a fire pit but didn't want to pay for the expensive store ones and all that I could find were way too big for our tiny backyard. So, I just figured I'd make one. This is a super easy and cheap design that only requires a small amount of tools that most people have.
Tools Needed:
Drill
Drill bit
Wrench
Hardware:
Stand $12 Home Depot Plant Stand
Tray $18 Amazon Serving Tray
3 Bolts with nuts and washers
Heat resistant paint (optional)
Step 1: Hardware
The two main hardware parts consist of a plate like object to hold the fire and a stand to keep it off of the ground and to make it easier to cook s'mores over.
The Plate I got was a stainless steel serving tray form Amazon. I chose this because most fire pits that I see usually rust through the bottom so I was trying to prevent that. You can use any type tray/bowl that you want but I suggest 14in as the minimum diameter. This is to prevent any burning wood from falling out as the fire collapses.
The stand that I got was just a regular old plant stand from Home Depot. It was cheap, metal, and the size I needed. You can get this one or any other one that you choose. Just make sure that there is some way to attach the Plate portion to the stand.
Step 2: Building It
Now to get building. It's pretty simple. Don't worry.
All you really have to do is lay the stand on top of the plate, both upside down, and drill holes so that bolts with washers can lock the two parts together. You need the holes close enough to the bars on the stand so that when you have a bolt thought the holes, a washer won't be able to fall through the gap. You can add another hole to the center of the plate to prevent standing water in the plate if you plan on leaving this outside.
You then just bolt it together and paint it with some heat resistant paint, if you want it painted. I used a BBQ spray paint for this and it has held up pretty well so far.
Step 3: Cutting Wood and Making Fire
The only difference that you will have with this fire pit is that standard logs will not fit on it. To make my wood for this I cut standard logs in half lengthwise and then split them to give me smaller pieces just perfectly sized for this fire pit.
All that is left is to take it outside and enjoy the warm fire and all the wonderful things you can cook on it.
Because of its small size it is best for up to 4, maybe 6 people around it.
Enjoy.
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    8 Discussions
    PogueMahone1775
    1 year ago
    Nice, EZ DIY with really common tools! I'm wondering if the fire will change the temper of the pan and result in rusting later on (I'm not a metallurgist)?
    Thanks. I imagine the high temps will eventually cause it to rust. The hope was that the stainless steel and paint would make it last longer than the store bought ones. If not, at least it was much cheaper then the store bought ones. I could just quickly make another one.
    mrsmerwin
    1 year ago
    How long have you been using it? I have had one of the store bought ones and one of them only lasted about 2 years.
    I made this last summer and it's still holding up with no rust but I keep it inside when it's not in use. That's what's nice about it, it's small enough to store inside and light enough to easily be transported.
    My son has been begging permission to dig a fire pit in the back yard. I think I prefer this idea.
    I had originally considered a wok but didn't like having handles on. But a wok would definitely work.
