Simple PVC Birdhouse
19,380
253
47
About: Hi, I'm Jen! In my free time I'm a crafter, food lover, and cake decorator. I also can't stop taking photographs! I have a genuine love and appreciation for all things creative and handmade.
I have 33 trees on my property and tons of wild birds. Most of them live in the very tops of the trees where I can't see them come and go very well. I like to keep birdhouses in the trees closest to the house so I can watch and enjoy the birds.
If you have the tools already living in your workshop/garage one birdhouse will cost a little under $7.
Step 1: Tools & Materials
If you are new to working with PVC and want more in-depth information I highly recommend enrolling in the PVC Class taught by audreyobscura!
You will need the following tools and materials to make a PVC birdhouse. (If you have access to a CNC machine this would be SO much easier. You could cut precise wooden circles with cutouts for the front and back of the birdhouse. A different saw would also make this much faster, however, I am a gal with limited access to tools!!)
Tools & Materials
  • Handsaw
  • Electric Drill
  • 1 1/4 inch drill bit (depending on the bird you are looking to attract. Check here for hole sizes.)
  • 1/8 inch drill bit
  • 1/4 inch drill bit
  • 5/64 inch drill bit (or a size slightly smaller than your eye screws)
  • Clamp
  • Pencil
  • Rubber Mallet
  • Quick Square
  • 4 inch PVC pipe - at least 8 inches in length
  • 2 - 4-inch wooden rounds
  • 2 - 1-inch eye screws
  • 24 inches thin paracord
  • Glue (I used Weldbond but the PVC Class or the Glue Class might recommend that something else would work better.)
  • 220 grit sandpaper
  • 100 grit sandpaper
  • Metal File
  • Outdoor Spray Paint (check that it works on plastic) - 2 colors of your choice
  • Wooden Dowel - 1/4 inch
Step 2: Cut & Sand PVC
1. Measure and mark an 8 inch long section of PVC. Mine came in two foot lengths so I ended up making three birdhouses (they make great gifts!). Draw a diagonal line at an angle of your choice starting at the 8 inch mark. Mine was approximately 60 degrees.
2. Clamp the PVC to a work table and using a handsaw cut along the angle. As always, tools can be dangerous. Please use caution.
3. Using a metal file, smooth down the cut edge removing any bits.
4. Sand the entire surface with the 100 grit sandpaper. This will remove the words/lettering on the PVC and prepare it for painting. Be sure to rough up the entire surface including the inside of the cut angle.
Step 3: Drill Wooden Rounds
Each of the wooden rounds will need holes drilled. The front piece will need the main hole for the bird to fit through and the back piece will need a few vent holes.
I purchased these wooden rounds at Michael's for $.99 each. They are beveled and about 3/4 inch thick. I wish they weren't that thick but they worked for this application. If you can find thinner ones use those! This was overkill.
1. Using an electric drill fitted with a 1 1/4 inch drill bit, drill a hole in one of the rounds positioning it toward one side (not in the middle).
2. Change the drill bit to 1/4 inch and drill a hole half way through the wood. Position it right under the larger hole This will be for the perch later. (You can see in the image that I failed to drill this before painting...big mistake! don't forget this step before painting! The paint just chips off around the hole and will have to be repainted.)
3. On the other wooden round, mark where three vent holes should go, I lined them up along the top edge in a row. Change the drill bit to 1/8 inch and drill the holes.
***To avoid chipping the wood you can place a piece of tape on the wood before drilling and drill through the tape. The wood I used was really soft, but if you used something harder it probably wouldn't require taping and wouldn't chip so bad. I did one each way and the one I didn't tape chipped really bad (I had to fill it with wood putty). Boo.
Step 4: Paint Pieces & Cut Dowel
Choose two paint colors that you like. One for the PVC and one for the front and back pieces.
1. In a well ventilated area on a covered work surface, or spray booth, spray paint the PVC. Don't forget the back edge! Let dry according to paint can directions.
2. Spray the wooden rounds. Let dry thoroughly.
3. Cut a 2 1/2 inch piece of dowel and paint desired color(s).
Step 5: Sand, Fit, & Glue Pieces
If you have a CNC machine the sanding part of this step won't be necessary. The wooden rounds I purchased weren't actually 4 inches so they had to be sanded to fit inside the PVC.
1. Using 220 grit sandpaper sand down the edges until the rounds fit in either side of the body of the birdhouse. Dry fit them to assure a good fit.
2. Run a bead of glue (I used Weldbond) around the flat edge of the birdhouse.
3. Inset the back side piece of wood to secure in place.
4. Using a quick square measure to find where the front of the wooden round will sit and mark with a pencil. This will tell you where to run the bead of glue.
5. Run a bead of glue. My pieces fit really tight so I used a mallet to gently pound the wooden face into place.
6. Squeeze a dab of glue into the hole on the face and secure the dowel for the perch.
Step 6: Drill, Hang, & Enjoy!
More drilling coming up!
1. Fit your drill with a 5/64 inch drill bit (or what matches your eye screws) and drill two holes on the top of the birdhouse. One toward the front and one toward the back. It might be tempting to just put one hole in the center, however, the birdhouse won't hang evenly once a bird decided to nest in it.
2. Twist in the eye screws until they are secure. I matched up the front eye screw with the wood to secure it further.
3. If your paracord isn't already cut, cut a 24 inch piece and burn the edge with a lighter to prevent fraying.
4. Thread it through the eye screws and tie a knot to join the ends.
5. Hang in a tree and enjoy!
  • Gardening Contest
    Gardening Contest
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
47 Discussions
gstrainsr
Tip 7 months ago
You made a couple mistakes with your bird house. 1) you never paint the inside the bird house, when the bird house gets hot, the fumes can harm the birds inside the house. Being I am a retired plumber go to one of your lumber box stores and in the plumbing department ask for a 4" knock out plug, this pops right in to the back of the bird house ( do not glue the 4" plug). This is made for 4" pvc pipe, and with a little effort you can take out the old bird nest at the end of the year clean your bird house out, and have it ready next year. I have made several hundred of this bird houses, gave some away and the rest well let say my 2 acres looks like a easter egg farm. one other thing you will find most birds rather not have a pirch. That will keep most of the birds away. The best paint to paint for pvc is Krylon Fusion spray paint. but other than that your bird houses look great. You will need drain holes in the bottom and in the back of the bird house (4) 1/4" holes for ventilation.
Biodynamic
Question 1 year ago
Have you had any birds move in? I was thinking about having classes at my school create these houses to hang around campus. I'd hate to spend the money if birds don't take up residency! This design is so simple and beautiful.
Cairnz
1 year ago
This is a darling bird house and I would love it as I'm desperate for some bird houses. I'm also getting no help from my dear guys who are both well capable of building bird houses. I do have a major concern over this pvc house and others I've seen made of clay pots, old tea pots, etc. Bird houses are recommended to be made of 3/4" to 1" wood which is supposed to provide some insulation from summer heat. I fear that pvc will not provide any protection from heat and will instead basically bake either the eggs or the baby birds. Would it be possible for either you or anyone else to check the temperature inside this birdhouse when it's hanging outside to see how warm it gets inside? I would truly love to build some of these with a few modifications if they won't get too hot inside.
AlbertN10Cairnz
Reply 1 year ago
great point! i live in central California (near Fresno) and in the past 30 days its hit 100 degrees or higher .... any living thing would COOK inside pvc at this temp
thundrepance
1 year ago
these are F A N T A S T I C! they remind me of some cool, bright solid-color, plastic planters i had in the '70s! i'll bet they really attract birds :^D
thundrepancethundrepance
Reply 1 year ago
p.s: i voted for "box" & "outside" {these are winners in both categories, i.m.o.}, & "favorited", as well. ;^)
Aaaecm
1 year ago
They look so Mid-Century Modern! I love them. I will be making a whole slew of these. Thank you so much for posting.
beautysmistress
1 year ago
very cute... I plan to build a few single family ones and perhaps a 4 plex.
great idea to have a removable plug to clean them each winter.. if your birds leave town that is. Thanks for posting
nedicman
1 year ago
I try plastic material for bird house, bad choice. Not a single time the birds nestle down. Use wood material ONLY, best one is with crust / coat . Not to use colouring agent.
Daisytikityke
1 year ago
I have read that the bottom of the birdhouse should have a few drain holes. It would be easy to drill a few holes along the bottom.
Also, a perch isn't necessary and gives predators a place to hang onto.
Very cute houses and simple clear instructions. Nice work
Flylowe
1 year ago
If you mske a Bluebird house, forget adding the perch. They fly right in.
Also .. You can buy pvc caps to use on the back side that will allow you to clean out the nest if necessary
jproehl99Flylowe
Reply 1 year ago
You can also get plugs that insert inside the PVC pipe end, if you trim off the flange it could be used as the front entrance and PVC glued (assuming PVC glue isn't toxic to birds as well - so check that) or set screwed in place. This in addition to the end cap would eliminate the more biodegradable wood components.
poocolonel
1 year ago
You did very well. They are beautiful.
271828183141592654
1 year ago
I suggest to watch from afar. Birds tend to abandon their nestlings when they notice that they are being observed. Great idea for bird house making though. Thanks.
WhollyOdd
1 year ago
My thought would be to have a clear plastic (and yes removable) back so you can see in. That way you know you aren't disturbing anybody at clean up time, and kids can learn what goes on in the nest.
BobH160WhollyOdd
Reply 1 year ago
Buying a very small CCTV camera would be better as you wouldn't have to disturb the birds when they have chicks as this could make them abandon them. They can be purchased relatively cheaply now and Youtube or here will tell you how to use them.
WesleyPBobH160
Reply 1 year ago
I also was told that the hatchlings would be abandoned should they be touched or disturbed by human contact. I have since learned that this is a myth. Just watch yourself as the mother bird may flock you by instinctively protecting her young.
john043
1 year ago
Oh, and regarding squirrels gnawing though the paracord ( likely if they are in the area) Sure a length of small chain would work, but even cheaper, I just use bailing wire, or a bent coat hanger; so far it's been an effective deterrent for mine.
