Simple Plywood Tricopter.
23,442
271
28
About: I love making things. I have for as long as I can remember liked to make stuff. Now days I have two kids (Thomas and Emma) and most of the things I do are safe for them! I love electronics and Microchips, I ...
Nice tricopter project using 3mm plywood for the frame and a full size servo for the yaw. No fancy pivots or hinges or tiny servos which break!
Using cheap A2212 brushless motor and Hobbypower 30A ESC. 1045 propellers and easy to use KK2.1.5 Flight control board.
Step 1: Design and Cutting Out.
I was really pleased with how this model turned out. i always use the same method for my models but this time i took it a step further by reducing the material used.
When you print out the plans it is very important to make sure the plans have been printed at 100% with no scaling. each arm should be 200mm long.
So basically once you have printed the plans out you will find that the whole model will fit on a piece of 3mm plywood 300mm * 300mm which you need to double up as each bit needs to be cut twice. meaning you only need a piece of plywood 300 by 600mm or 1 foot by 2.
You will need to stick the plans onto the wood using a stick glue and then carefully cut out all the bits. Each time you cut a bit out make sure the slots are the correct size and that corresponding bits fit together.
The design has been carefully considered to use the same bits in different places, so for example the two stationary arm are obviously identical, but so are the top and bottom of the arms and in fact the top and bottom are symmetrical so will fit either way around. When you have finished building this model you will only have 3 small bits spare and all these bit are associated with the servo arm.
Once you have cut out all the bits you then need to drill all holes, and once you have done the holes you can then peel of the paper. (that's the beauty of using stick glue)
Step 2: Gluing the Bits Together.
I spent some time on the design making sure bits would fit together securly. Before you start gluing all the bits together you should test build the arms first just to make sure you will be able to slot all the bits together.
My preference is to use gorilla glue. For a start it works really well and only takes 2 hours to set. But if you are new to Gorilla glue make sure you follow the instructions as you need to wet one surface of the wood and apply the glue to the other. then you must clamp the bits together while the glue sets. ALSO its is very important to keep the glue of your skin so either wear gloves or use an applicator.
you could use a PVA glue but that can take a lot longer to dry and if like me you are impatient then waiting for glue to dry is no fun! This whole model was started on Friday evening and was flying by Sunday lunch.
Step 3: Electrical Fit Out, Motors and ESC's.
The speed this model came together was really impressive. once all the bits were glued then its just a matter of slotting the arms onto the central hub (but don't glue) and the add the yaw motor mount using two M4 * 16mm screws with nylocks.
To mount the motors i have used the motor mount which comes with the kit. To get the holes in the correct place i position the motor mount (without the motor fitted) and holding the mount in place drill the first hole. Then i place a M3 screw in the hole and drill the opposite hole, again i place a M3 screw in that hole and then drill the last two. In this manner you should get all the holes to line up correctly when you fit the motor.
You can see in the picture above how i have fitted the motors and threaded the motor wires through the arms and out of the hole. This makes for a nice clean model and keeps all the wires out of the way. The motor wires are then soldered straight onto the ESC, this gets rid of the 3 wires and connections you would normally have from ESC to the motor. At the power wires to the ESC i have added 4" extra red and black wire and like the motor wires these have been fed through the arm and are all joined together in the area in between the center section.
Whilst i was soldering the motor wires onto the ESC i also choose to add the wiring to the lights. As shown in one of the pictures this was soldered onto the pads on the other side to the main power wires.
Step 4: Yaw Servo.
This design has made use of a full (normal) sized servo. The reason being i tried a small tricopter (HJ-Y3) which used a mini 9 gram servo, and very quickly realised that this was the weak point. Even though the gears were metal it did not stop them stripping at the slightest crash! also the model was made from fibreglass which seems to break very easily.
SO the servo i have used is a Bluebird servo, it happens to be a high speed metal gear servo but i think you could get away with a standard servo. BMS-631MG.
As shown in the picture and explained in the vid the servo is mounted with the horn on the side of the motor and then its just a short link of piano wire to the motor mount above.
I designed the motor mount to only have 20 Degrees movement up and 20 Degrees down, from the testing i have done so far this seem to be plenty. I also believe that limiting the movement of the motor mount helps to protect the servo.
Step 5: KK Flight Controller and Settings.
I have used the KK 2.1.5 flight control board for this project. I really like the simplicity of the board and the fact that you can make changes on the board without having to connect to a computer or use bluetooth to a phone/tablet.
Depending on how you want to fly this model will depend on how you mount the flight control board. If you wish to fly the model as a "Y" with two motor at the front then the board arrow should point in the middle of the two. If however you wish to be awkward (like me) and want to fly configured as a upside down "Y" the the board arrow should face the front motor. IT DOESNT MATTER WHERE THE SERVO ARM IS. As far as the flight controller is considered the servo is just used to change the yaw of the model and no matter where it is it will always cause the model to rotate.
If you are flying the default Tri then the KK will show you the motor number and tell you the motor direction. however i don't think it really matters as long as you get two in one direction and the last one going the opposite way. But for clarity motor one should be clockwise as should be 3. and motor 2 should be counterclockwise. unlike mine! (but is still works)
Once you have connected all the ESC and the servo (in position 4) then you can connect you battery and configure the controller. Motor layout should be Tricopter with servo in 4. Then i checked how the model worked without the propellers, with the throttle up to start the motors move the model around in a circle and confirm the servo is moving in the opposite direction to oppose the action. In my case it wasn't moving in the correct direction meaning the model would have spun out of control. To correct this you need to go into mixer editor and scroll down to channel 4 (the servo) and change the rudder value to -100. While you are at it change the self level setting to always on in the mode page, and finally to get you stared up the P Gain to 75 in the PI editor.
Step 6: Finishing Touches and Improvements.
When i first tried this model i squeezed the battery in between the central sections, this worked ok but i decided to change the design to add a better position. also the battery need to be off-center to counterbalance the weight of the servo.
Also i added holes in the new central bits to allow a tie wrap to be interested to fix the arms into place.
This model is very nice to fly and really fun. i cant wait to fly in a bigger field and she what it can do!
Make it Move Contest
Second Prize in the
    • Cardboard Challenge
      Cardboard Challenge
    • Faux-Real Contest
      Faux-Real Contest
    • Safe and Secure Challenge
    28 Discussions
    Swanith KR
    Question 6 months ago
    How to make a simple plywood quadcopter? And can you give me the PDF of structural plan and details of parts?
    Waste Of Space
    6 months ago
    Hello
    Thanks very much for the DXFs and the PDFs for your tricopter design.
    I think you may have made an error on your DXF regarding the hole size in the motor mount.
    In the DXF it is shown as 1mm dia.
    On your PDF, the size of the left hole is shown as 4mm and the right hole as 3mm
    I also found it necessary to redraw the DXF as the program you used had overdrawn - duplicated - quite a few of the lines and in one instance put in a wrong angle.
    If you would like a copy of my DXF, just ask for it.
    My DXF is suitable for cutting with a laser cutter or a CNC machine, or if you have one, it could even be used for a 3D printer file.
    D-signWaste Of Space
    Reply 6 months ago
    hello, i would like to have the dxf file from you.
    I have build a cnc and like to make the tricopter with it.
    greet René
    mr_fidD-sign
    Reply 6 months ago
    Hello
    I have added the DXF as kindly done by Waste Of Space. you should be able to find it in step 1 above. If you cant download it please send me a privrate masseage with your email address and i will send it to you.
    mr_fidWaste Of Space
    Reply 6 months ago
    glad you managed to make use of my DXF. I am not the best on cad and normally don't even mark up with sizes etc. If you dont mind sending the file back then if its ok i will include it on here?
    Thanks
    Mohammade9
    7 months ago
    Creative! I like it is a tricopter, and I like it is made of plywood.
    and it is grateful you shared the design pdfs and everything :)
    mr_fidMohammade9
    Reply 6 months ago
    Thanks for your kind comments. Most of my model are made from plywood..... i think the next purchase will be a laser cutter!!!!
    mr_fidmariodanna
    Answer 6 months ago
    I use a cheap Hobbyking OrangeRX at about £60 you cant ask for more! having said that the Turnigy TGY-i6 is even cheaper! The beauty of a drone is you don't really need a fancy transmitter.
    freefuel1
    7 months ago on Step 2
    that unprotected battery makes me uncomfortable, allowing it to swing in the breeze like that is asking for trouble as it doesn't take much to breech the containment leading to a fire. consider adding some foam or other protective material to armor it in the event of a crash or other collision.
    sdantonio
    Question 7 months ago on Step 6
    Any possibility we can get the original DXF files or something similar tha I can take to the CNC
    1 answer
    mr_fidsdantonio
    Answer 7 months ago
    sure, i have added it to the instructables along with the pdf's, or just give me your email and i will send it to you
    herrbee
    Hi! We really like this project and want to feature it on our website. If you are interested, kindly drop me a message on my e-mail: hquiao.isi@gmail.com . I'll be looking forward to your response! Thanks.
    1 answer
    mr_fidzeeshan112233
    Answer 7 months ago
    3mm plywood 300mm by 600mm (£3.35)
    standard servo must fit a hole 40mm by 20mm (£14.07 hobbyking)
    3 sets of A2212 motor 30A esc and 1045 propellers. (£8.17 ebay)
    KK2.1.5 FC board.(£15.94 hobbyking)
    battery 11.1V 1800mAh lipo. (£9.62 hobbyking)
    about 300mm of red and black 14AWG silicone wire. (ebay)
    battery connector of your choice (ebay)
    2 * M4 * 16mm screws and locknuts. (my shed)
    velcro stray to hold the battery. (ebay)
    small length of piano wire.
    2 end stops for the wire.
    mr_fidsamiam.pieter01
    Answer 7 months ago
    i have got a few 1800mAh 3 cell lipos which fit nicely in between the frame. You cant fit anything thicker (so the 2100mAh i have got wont fit) however the 2600mAh batteries i have are larger length and width but not as thick so would also fit.
    DPTECHDESIGN
    Question 7 months ago on Introduction
    how dod you connect the remote controller because I need that for my GCSE coursework
    Thanks
