Simple RFID Blocking Wallet
67,234
246
105
This instructable is for how to make a very simple yet effective RFID-blocking pouch using materials you already have at home.
In the last few years, there has been a rise in crime involving people going around with RFID readers and stealing people's credit card information without the victims even realizing it. Having an RFID-blocking wallet is the simplest and most effective measure to prevent this from happening to you.
RFID (Radio Frequency ID) is a technology that allows a reader to get an identification from a passive device by reading the device-specific response to a band of radio frequencies. Just by being near the reader, a device with an RFID tag or chip can be read wirelessly and instantly. The advantage of this is convenience. For example, you can now pay the bus fare by tapping a pre-loaded card on an RFID reader when you step on the bus. Many credit cards now have the ability to pay by tapping on an RFID reader -- no swiping or inserting necessary. The disadvantage of this is how conveniently easy it is for thieves to get your credit card information (or more). And worse, they can do it right in front of you and you won't even realize it!
Luckily, you can protect yourself in minutes by making yourself a simple RFID-Blocking Wallet!
(NOTE: I have tested this using my RFID bus pass on the bus, and verified that the RFID reader was not able to read the card while it was inside this pouch. It worked exactly as intended.)
Step 1: Materials
All you need is:
  • Duct Tape
  • Clear Packing Tape
  • Aluminum Foil
  • Scissors
(The important part is the Aluminum Foil -- its purpose is to create a sort of Faraday Cage around the finished pouch, which blocks / attenuates any electromagnetic signals (i.e. RF signals) coming from outside the pouch.)
Step 2: Duct Tape
Lay down duct tape so that the strips overlap slightly and create a sheet. Make this larger than you will need the finished pouch to be.
Step 3: Aluminum Foil
Lay the aluminum foil [carefully] onto your duct tape sheet. The aluminum foil should lay flat for best results.
Step 4: Packing Tape
The final layer of the material is the clear packing tape. This protects the aluminum foil and prevents the metal from touching the chips on credit cards.
Lay the clear packing tape onto the aluminum foil side. Like you did the duct tape, overlap the strips slightly. Cover the entire area that has duct tape on the opposite side.
Step 5: Cut to Size
Trim away the edges to create a rectangle. Then, using a credit-card-sized card, cut the material so that it will be just larger than a credit card when folded in half.
Step 6: Tape Edges
Finally, to close the pouch, duct tape the edges and trim the excess away.
Step 7: Done!
You're done! Put your credit/debit cards in here, and if you'd like put it in your wallet. Now your cards are safe from thieves who use RFID scanners to steal credit card info.
(Although the one I made worked, please make sure to try out your own pouch before trusting your cards in it!)
I hope you found this instructable useful! If you have any other ideas or modifications from this, please post them in the comments, I'd love to hear them!
5 People Made This Project!
  • Pie Contest
    Pie Contest
  • Paper Contest
    Paper Contest
  • Weaving Challenge
    Weaving Challenge
105 Discussions
mikey51
8 months ago
I recently bought that copper mat for BBQ grills and was wondering if that type of woven copper sheet would also work?
kgklinkelmikey51
Reply 8 months ago
Theoretically woven copper should work, since the weaves are smaller than the wavelength, but I can't say for sure. Make one and try it out, because now I'm curious!
Captain Nemo1kgklinkel
Reply 8 weeks ago
I use a woven copper fabric manufactured especially for this application. It can be purchased online.
SunilN19mikey51
Reply 2 months ago
Sss , very good thouight , It does . Cheers mate.
syfrmikey51
Reply 3 months ago
If the openings are less than 1/10th the wavelength of the offending RF, yes, it should work fine.
Captain Nemo1
Tip 8 weeks ago on Introduction
A nice inexpensive job...
I've made similar faraday card wallets using copper cloth, cell phone holders, and passport holders. I have ocassionaly experienced 'leakage' with the cell phone when the shielding doesn't wrap around the seams or have a flap. Just to be on the safe side, I now do the same with all my Faraday cages.
Cheers
Disasterific
Question 2 months ago
Do you happen to know what happens if the foil touches the chip on your card
jeggeling1978Disasterific
Answer 2 months ago
I Assume you mean the chip on your card....not car.
There is no need to worry as all cards are known as passive RFID devices.
there is no power in a card so there is nothing to short.
TonK5jeggeling1978
Reply 2 months ago
There is one exception and that is when a static charge i.e from your hand gets transferred to the chip contacts, this may cause malfunction of the chip. So, putting a large metal object next to the chip without isolation may not be such a good idea.
if i remeber right, my bank told me not to touch the contacts....
eugeneo8
Question 2 months ago on Step 3
  • Aluminum Foil - what side must be on the outside - the dull or shinny side
JohnH973eugeneo8
Answer 2 months ago
It depends on whic direction the RFID reader is pointing...
eugeneo8JohnH973
Reply 2 months ago
When I want to make this wallet and put the foil down it has a shinny and a dull side. When I fold the foil must which side must be inside the wallet
SunilN19
2 months ago on Introduction
So simple , yet very good idea mate . Good on you . Cheers buddy ..... :)
ecoot1012
2 months ago
I used Metalized mylar and tested it by putting a radio inside the bag. No radio station got through. I lined my wallet with the mylar.
JohnH973Disasterific
Reply 2 months ago
I think the 'foil' chip packets are metallised Mylar, though I'm not absolutely sure..
Ntamm3
2 months ago
Very nice idea.
BTW that's my library card - CO!
4
Valvelifter
3 months ago
I routinely disable contactless payment on all new credit and debit cards by drilling a 3mm hole through the embedded antenna wire which you can see by shining a strong light through the card.
