Simple Round Table
19,461
339
23
About: I like to design and build random things.
This project was built with a round top from a broken table and two 2x4’s. The top in this project is 30 inches in diameter. However, the designed can be scaled up or down based on your top diameter and/or desired table height. See drawing and video for build instructions.
Drawing: https://drive.google.com/file/d/0B21TbB8gGNQbeG96QVdsNGNKZHc/edit?usp=sharing
Step 1: Tools/Materials
Tools:
  • Saw
  • Drill and bits
  • Pocket-hole jig (optional)
  • Sander
  • Tape measure
Materials:
  • Round table top (30” diameter used for this project)
  • Two 8 foot long 2x4s
  • Screws or Nails
  • Glue
  • Paint
Step 2: Table Top
Find, buy or make a table top. This top was taken from a 1970’s round table. It took a little bit of sanding to remove the blemishes.
Step 3: Upper/Lower Attachment
Cut the lower attachment pieces to 14.5” long. Chamfer the width dimension to a 60 degree angle. Chamfer the thickness dimension to 15 degrees. Cut the upper attachment pieces to 7” long. Chamfer the width dimension to a 60 degree angle. Chamfer the thickness dimension to 15 degrees – see pictures.
Step 4: Upper/Lower Attachment Assemblies
Attach the lower and upper attachment sections together as shown. I used a pocket-hole jig to drill the connection holes. Think ahead at this point to make sure the holes are on the bottom (floor) and under the table top. Add glue to the joint before screwing together.
Step 5:
Once complete, you should have two attachment assemblies
Step 6: Legs
Cut the legs to 31” long. Chamfer the thickness dimension on both ends to 15 degrees – see picture.
Step 7: Ready to Assembly Legs to Attachment Assemblies
Step 8: Attach Legs to Upper Attachment Assy
Add legs to the upper attachment assembly. I tried using the pocket-hole jig for these connections but the connection didn’t feel secure enough. I scrapped that idea and used deck screws from the sides. If you implement this method, use a countersink bit so you can fill the hole later.
Step 9: Attach Lower Attachment Assy
Attach lower attachment assembly to the upper attachment / leg assembly. Again, I used deck screws and glue.
Step 10: Sand
Use wood filler to cover the screw holes and any gaps in the wood. Sand to remove wood filler and clean up the joint lines.
Step 11: Paint
Paint or stain the legs and top to your desired color. I used white for the legs and green for the top.
Step 12: Add Guide Hole for Legs
Drill a small hole at the intersection of the upper attachment assembly. This will be the center location for the round top.
Step 13: Drill Alignment Hole in Top
Find center of round top. Measure the diameter. Use a string or tape measure set to the radius and draw a light arc. Move the string to another point on the edge of the table and draw another arc. The intersection of these two arcs is the center. Try a third arc to verify. Drill a hole at the intersection.
Step 14: Attach Top to Leg Assembly
Use a nail or rod to line up the hole in the leg assembly to the hole in the round top. This will keep the top centered on the leg assembly. Drill pilot holes through the upper attachment assembly. Use wood screws to attach the leg assembly to the top. Make sure the screws don’t protrude through the top.
Step 15: Final Product!
  • Tape Contest
    Tape Contest
  • Gardening Contest
    Gardening Contest
  • Trash to Treasure
    Trash to Treasure
23 Discussions
DavidH299
3 years ago
I really like this project, and would like to adapt it for a very large dining table (72" diameter). If you have any tips for adapting this design up that large, I would appreciate them. I wonder if a 36" diameter design could just be doubled?
mtairymdDavidH299
Reply 3 years ago
Thank you. I don't have the cad files anymore but I assume you could scale it - check the math first. I am a little concerned with stability using 2x4s on a 72" diameter. I think I would switch to 4x4s to be safe.
krsmes
4 years ago
Sight variation but your directions are exactly what I was looking for. Thank you. (I also raised the bottom an inch to prevent wobble)
mtairymd
4 years ago on Introduction
All - I said in the introduction that the design could be scaled up or down based on the table diameter and height. This might be a trigonometry / geometry challenge for some. Actually, I was lazy and modeled the design in CAD. Let me know if you can't figure out the dimensions for your design. I can provide an updated drawing based on your specs (diameter/height) - limited time only :)
bergsmtairymd
Reply 4 years ago
I was looking to make children sized stools. This design seems very solid and cheap to make. What would the dimensions need to be for the upper and lower attachments assemblies assuming I wanted a height of 1' and a relatively small top. say 10" to 12" Dia.
dmackenzie6mtairymd
Reply 4 years ago on Introduction
mtairymd....great job. I love the design.....do you think it would work for a bar height table (42")? Would it be stable enough? If so, I would like to take you up on your offer to work out the angles using your CAD program?
krop86dmackenzie6
I'd be interested in a 42" version too! It would be super helpful. Great idea and design!
mtairymdkrop86
First, the table is very stable. However, if I had to do it again, I would make the change "Make_This" suggested below - extend legs slightly beyond the bottom plane.
I had to work with the 30" diameter top since it was "free". My goal was to have the legs inside the diameter of the table (less than 30"). If you have the same preference, I don't think 42" in height and a 30" diameter will work.
I just did a little research on common sizes:
To seat 4 people: 36" - 44" diameter
To seat 6 people: 44" - 54" diameter
Do you have a preference on diameter? Also, please verify the exact height needed.
krop86mtairymd
Thank you! I made two bar height Adirondack chairs and I've been looking for plans to build a small table for drinks/snacks. 44" diameter might be too big but thank you for doing that!
Also, where did you get your pocket hole jig from? I have a kreg jig but I didn't know there were others on the market.
dmackenzie6
Hi, thanks for your quick reply. I would think a 36 inch diameter top 42 inches high would work well you can assume the thickness of the top might be any inch or three quarters thick. If you can work up the dimensions for me that would be awesome thanks so much
Edward Jones
mtairymd: Great project and design. I've been trying to find some poolside tables for my cool deck, unsuccessfully. This looks like it would fit the bill perfectly. I would also like to take you up on your offer for size reduction in your CAD.
emjones@cableone.net
Edward Jones
tofugami
4 years ago
Nice. I like the functionality and your lime green top is a great color.
