Simple Sturdy Low Cost Furniture
23,813
505
21
This Instructable will show how to build simple, low cost, sturdy, wood furniture that can look good and last for a long time. I recommend reading through the entire Instructable before you begin. I am not a professional wood worker and some of my methods/materials may highlight this fact. I have added a lot of notes on the pictures, if you don't completely understand part of the text, refer to the notes in the attached pictures. This Instructable will show how to build two simple end tables/ bed side tables that are about 25" tall, but these methods can be adapted to make any size desired(pictures are attached of stools, and tables made with the same techniques.). Safety is always important, so I recommend using a minimum of safety glasses/ goggles for this Instructable, a dust mask is a good idea as well. I also used ear plugs to avoid a headache. If you like this Instructable, I would really appreciate a vote in either or both of the contests that it's entered into. The vote button is in the top right corner of the page. Thank you for looking at this Instructable, and if you do end up building it, please post pictures in the comments, I'd love to see what you make.
Required Tools:
Clamps => 14.5" long
Drill
Sander
Sand paper
Block Sander(Optional)
Pocket Hole Jig
Pocket Hole Drill Bit
Small Drill Bit (for pilot holes, slightly smaller diameter than screws that will be used.)
Tape Measure
Phillips Head bit
Pencil
Jigsaw/Table saw/Hand saw/Circular saw (optional)
Required Materials:
Two 2"x2"x8' (AD 1.5"x1.5"x8') boards (I use Select Pine from The Home Depot)
One 1"x4"x8' (AD 0.75"x3.5"x8') board
One 1"x8"x8' (AD 0.75"x7.25"x8') board
Wood glue
Screws (I used 1 1/4" decking screws)
**Update**
The 3D model file for the table I made in this Instructable is attached. It is a Google SketchUp file.
Supplies:
Step 1: Gather and Cut Materials
I used select pine boards from the home depot for these tables. The total cost of the wood was right around 50 dollars (USD) to build two tables. If you purchase your boards from Lowes or The Home Depot, you can have them cut to length for little or no cost. For each table you will need Four 2"x2"x24" boards for the legs, two 1"x4"x14" boards for the front and back faces, two 1"x4"x10" boards for the left and right faces, and two 1"x8"x18.5" boards for the table top. If you prefer, you can replace the two 1"x8"x18.5" boards with a single piece of plywood 0.75"x14.5"x18.5". If you use the two 1"x8"x18.5"(actual dimensions: 0.75"x7.25"x18.5") boards for the top of the table, you will need to glue and clamp them to create one board with dimensions 0.75"x14.5"x18.5" and leave it to dry overnight.
Step 2: Drill Pocket Holes and Sand
Using the pocket hole jig and the pocket hole drill bit, drill 3 pocket holes on one side, at each end of each of the 1"x4"x14" boards and at each end of the 1"x4"x10" boards. Then drill two pocket holes on each of the 1"x4"x10" boards perpendicular to the existing holes and the grain of the wood and drill three holes on each of the 1"x4"x14" boards perpendicular to the existing holes and the grain of the wood. (I didn't take pictures, but a diagram is attached and the pictures in later steps can be used as reference.) Note: Do not overheat your drill bits, it will cause them to become dull more easily, especially if you use an aluminum pocket hole jig like I did. If your drill bit gets dull you'll end up tearing the wood like I did and it makes it more difficult to drill the pocket holes.
Sand the table top, sides, and legs and remove all sharp edges.
Step 3: Assembly (sides and Legs)
Attach one 1"x4"x10" to one 2"x2"x24" board. To do this, line up the end of the 1"x4"x10" board with the center of the end of the 2"x2"x24" board. Use a small drill bit pushed into the pocket holes to mark spots to drill pilot holes. Once the holes are marked, remove the 1"x4"x10" board and drill pilot holes for the screws that will go into the pocket holes. Then put glue on the end of the 1"x4"x10" board and screw it into the 2"x2"x24" board. Repeat this process to attach another 2"x2"x24" board to the other end of the 1"x4"x10" board and set this piece aside. Repeat the same steps to create a second identical piece of two 2"x2"x24" boards attached to a 1"x4"x10" board. Then attach the 1"x4"x14" board 90 degrees relative to the 1"x4"x10" boards. Ensure that the pocket holes drilled perpendicular to the grain of the board are all facing the same direction (towards the top, they will be used to attach the table top.) Be sure to use glue on all joints, it will significantly strengthen the table.
Step 4: Prepare and Attach the Table Top.
With the base fully assembled, sand the top surface of the base to ensure that all surfaces that will mate to the table top are flush. Then place the tabletop face down on your work surface and place the base upside down on top of it. Use the tape measure to perfectly center the base on the table top working on one side at a time. When the side is centered, trace the sides that are aligned properly onto the tabletop. You should end up with 4 right angles on the bottom of the table top. I recommend making a key mark so that you can re-align the base with the top after gluing. Once the base is centered on the top, use the small drill bit to mark the spots that pilot holes will be drilled into the top, once all 10 pilot holes are marked, remove the base from the top, and drill the pilot holes. Remember to drill them at a slight angle to match the angle of the respective pocket hole. Apply glue to the top surface of the base and spread it completely. Set the base back onto the table top, ensuring that the key marks are lined up. Screw the base and top together ensuring not to over tighten the screws or they can come through the table top or crack the table top. If you do pierce the table top with any of the screws, back the screw out until it is no longer protruding from the surface and apply a drop of wood glue. When the wood glue dries you will be able to sand it flat. Once the top is screwed to the base, it is a good idea to clamp them and leave them to dry over night.
Note1: The base will probably slide around slightly while placing it back onto the top before it is screwed in, so be sure to line it up before screwing it together.
Note2: A key mark is a good idea because it is highly likely that the opposing pocket holes are not perfectly aligned, and if you attempt to attach the base to the top after drilling the pilot holes and you rotate it 180 degrees the pilot holes and pocket holes will likely be slightly misaligned.
  • Gardening Contest
    Gardening Contest
  • Woodworking Contest
    Woodworking Contest
21 Discussions
patdoherty
4 years ago on Introduction
I have never had an issue using drywall screws or deck screws in wood. HOWEVER in pocket hole joinery you really get a much more solid joint and less chance of splitting with pocket hole screws because of the shape of the head. Pocket hole screws have more of a truss head where as deck screws and drywall screws have a flat head. The truss head does a much better job of pulling the two pieces together. Also with a table this small it probably doesn't matter but I generally lever glue table tops on and I usually use buttons to attach them, to allow for expansion and contraction of the top. That also depends on where you live though, I live in chicago where there is a lot of wood movement. In more temperate states it doesn't matter as much.
patdohertypatdoherty
Reply 4 years ago on Introduction
Although from the pictures your joints look very tight so I'm sure the deck screws are good enough.
kooter
Nice job on the furniture! Instructor told me "woodworking is something you only get better at, each new project allow you to improve on your technique, etc".
What was the reason for not using generic pocket hole screws "available at Home Depot" ? Gets rid of the need for pilot holes.
We have 2 end tables and a coffee table all with pocket hole joinery, have had them for years and they are probably 20 - 30 years old (new to us). No evidence of warping, checking, cracking, etc. We live adjacent to Lake Superior, wide temperature and humidity variations.
BrianE2kooter
My main reason for using the decking screws that I used is because I already had them and when I looked for pocket hole screws in the past I could never find them, but that was probably just me not looking hard enough.
zinkpig
I would really recommend avoiding drywall screws for furniture. They are wider thread and not really designed to grab on to denser material. They are also very brittle unlike typical wood screws which fail by bending. A footstool using drywall screws is an accident waiting to happen.
BrianE2zinkpig
I have to disagree with you, they are designed to grab onto wood, because 2x4s for housing framing are made of wood, and the drywall screws go through the drywall directly into the wooden 2x4. They may be more brittle, but with the number I used in this Instructable I would almost guarantee that the wooden legs would crack and break before the screws break, and finally this Instructable isn't necessarily for a footstool(not that footstools are load bearing anyway), it's for an end table, and as I showed in another comment, when built correctly, they can clearly easily hold far more than necessary. I understand your concern for safety, but if it was a really problem IKEA wouldn't exist, I guarantee that when built correctly these tables will be significantly stronger than an equivalent IKEA piece. Finally, it turns out that the screws I was using are decking screws anyway, haha.
lunakidBrianE2
"Finally, it turns out that the screws I was using are decking screws anyway, haha."
(Well then his arguments for *drywall* screws remain totally unaffected by your experience and reasoning of *decking* screws, are they... ;) )
Very nice piece of work, regardless!
What software did you create that lovely image in "Step 1" with, please?
BrianE2lunakid
The software i used is called Google SketchUp(the free version is called SketchUp Make), I believe the software is actually made by a company called Trimble, and I have an add on for it called Maxwell Render. I actually intended to attach the SketchUp file to the Instructable, so thank you for reminding me.
phillipnolanBrianE2
Nice instructible and well stated reply. The nannies are generally uninformed fearmongers. Keep up the good work.
RenMandFxzinkpig
You can get drywall screws in both coarse and fine thread.
Drywall screws tend to fail due to shearing forces (force applied perpendicular to orientation of screw) or from twisting (this most often being when trying to remove the screw deeply set in hard wood and it snaps head off leaving most of shank in the wood)
Given the ubiquity of their use in the construction trades, I wouldn't be worried.
rybitskizinkpig
Reply 4 years ago
I work in the theatre industry and that is what we use for constricting sets. yes they are relatively brittle compared to wood screws but they are also cheaper and widely available. if you've ever seen an opera or a Broadway show in recent years chances are it was held together by drywall screws.
winmichaels
If you don't finish both sides exactly the same you will have more wood movement and cracks and bowing.secure what is called figure 8 conectors to the wood top to the frame which will allow the wood to move.
winmichaels
SWiiiTCH
4 years ago
you can also burn, stain, and seal it for a different look
jdege
I would expect the top to warp or crack, as the seasons change, if you screw it solidly to the frame, like that. Wood expands and contracts as the humidity changes, and you need to allow for that in your design.
BrianE2jdege
That's good to know, i'll keep an eye out for it. I did avoid painting the underside of everything i have built to allow the wood to breathe. The stools pictured above do have solid pine seats and were built over a year ago and do not yet show any signs of warping or cracking. I do live in Colorado though, so there is rarely any significant amount of humidity here which could be why.
jdegeBrianE2
When I built my workbench, I fastened the top to the base by routing a groove around the inside of the base, and using screwed-in clips:
https://www.instructables.com/id/Building-a-real-wo...
I'm in Minnesota, where we have very dry winters and fairly humid summers. I see as much as half-an-inch difference in the width of the top over the seasons.
BrianE2tomatoskins
The size of wood that is used for the sides will significantly effect the strength, if you used 1"x2" boards it might be wobbly, but with the 1"x4" boards it is quite sturdy. I regularly use them as step stools. If you don't use wood glue, they will likely not be nearly as strong though.
