Simplest PWM Motor Control Circuit Using Op Amp
4,464
32
8
Hello People!
This instructable is about how to build the simplest(probably) PWM circuit to control DC Motor speed, LED Strip Brightness, etc.
Specs:
Input Voltage : 5-30v
Current Handling : Depends on the MOSFET(Around 10A for IRFZ44)
Please comment if you tried building it!
Supplies:
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    8 Discussions
    morton6689
    2 months ago
    i could be wrong but shouldn't there be a diode hooked across that motor to protect the MOSFET from back EMF? I realize this is a old post that i came across and doubt ill get a reply but if anyone new to electronics is going to build this i am 98% sure (i am not an expert on this) that you need to hook up a diode across the dc motor. look up snubber diode. when current is stopped the windings in in the motor have built up energy that becomes a voltage spike going backwards through the circuit which can damage (in this case) the MOSFET.
    Usairum Mirzamorton6689
    Reply 4 weeks ago
    it depends upon which load you are using e.g if your load acts like a inductor (stores energy) then yes you need to have a protecting diode
    megapix
    2 years ago
    Clever circuit. I also like the use of the bottle cap as a control knob.
    BeachsideHank
    2 years ago
    What advantages does this circuit posses over the more popular 555 PWM designs?
    Stuff BuilderBeachsideHank
    Reply 2 years ago
    Here are two
    One advantage might be higher operating voltage and other might be that two individual controllers can be designed using a single IC
