Single Sided Really Bare Bones Board Arduino in EAGLE.
28,654
66
20
About: Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
Paul Badger of Modern Device Company designed the "Really Bare Bones Board" (http://moderndevice.com/RBBB_revB.shtml) and placed the design in the public domain. (Thanks Paul!)
I've converted the design to the EAGLE CAD package, and in the process I noticed that you can pretty much make it into a single-sides board as well, probably not to hard to make using hobbyist materials.
Design files here: https://docs.google.com/leaf?id=0B6dMB5dovDUZNTEzODE4NmEtMDZjNy00YWQwLTg5OGEtNzNiYmJhZmJjODI4&hl=en
Supplies:
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    20 Discussions
    baciuu
    Question 1 year ago
    hi, at ftdi input is only 2 yires conected to AtMega, why is not all 4 contacts (vcc,gnd tx an rx)?
    westfwbaciuu
    Answer 1 year ago
    There are three pins from the FTDI (+5, GND, and RTS?) connected via PCB traces on the bottom layer of the board, and two (RxD, TxD) that you need to connect with jumper wires because of the limitations of the 1-layer board. The 6th signal (CTS?) is not used...
    hishamfaraj
    6 years ago on Introduction
    Hello First off Thanks a lot on this link its amazing!!. I need your help though.
    I have downloaded the files and the eagle cad all is working perfectly. I need to know how to print the schematic on a Photo paper so I can later on use it on PCB board .
    No1Daemon
    7 years ago on Introduction
    Hi
    How do I find the physical board size in Eagle?
    Or can you tell me the physical outside dimensions please.
    I am looking to get some made.
    westfwNo1Daemon
    In the board editor, you can use the "info" command on the lines in the board outline. The SSRBBB is slightly less than 18x78mm
    Mdob
    9 years ago on Introduction
    Um instead of using the AtMega 168 can you just substitute the 328 without any changes to the design? And can you substitute the resonator with this crystal?
    Thanks in advance :)
    westfwMdob
    Yes, the 328 will drop in with no modifications. If you want to use a crystal, you'll need to also find room for the two 22pF caps that go with the crystal (these are built in to the resonator.) A couple of tiny SMT caps would go on fine, but it would be difficult to find room for more TH components.
    Mdobwestfw
    Ok thanks for the quick reply i was just trying to save some $$$ by using a cheap crystal. Thanks for your help. If i wanted to could I just solder the 22pF caps onto the leads of the crystal? Thanks for your help again :)
    FrozenFireMdob
    A crystal, while more accurate, is not used on the RBBB for cost reasons. Resonators are usually a *lot* cheaper. Unless you go to your local Radio Scam.
    westfwFrozenFire
    While it is conventional wisdom that resonators are cheaper, I seem to find this to be not very true, at least in small to moderate quantities. Both 16MHz resonators and "typical" crystals are about $0.30 from Mouser, for instance. I like resonators because they're smaller and included the needed caps in the same package, making PCB layout and assembly easier.
    please update the link to the files. I have been looking for this as I will be using my makerbot to mill pcbs and really want to make this.
    buchacho
    Can someone update the link to the files perhaps to somewhere safer than geocities?  Thaks!
    This deserves a whole lot of love! Is the pin spacing 0.1 inch on the board meaning you can use in a breadboard? The 7805 option, the two 100n caps for noise reduction, single sided......this is pure win on every level!
    Bongmaster
    10 years ago on Introduction
    nice :) will have to give this a try and see if it can be done with the sharpie method XD (i have no way to tone transfer)
    trialex
    Very much kudos. Single sided designs can be hard! I'll definitely be using this next time I need an arduino without in-built 232/USB - at the moment I'm making a full size board and just not populating the comms parts.
