Sliding Easel Card
About: I will be sharing with you helpful videos about cardmaking, papercrafting, painting, some occasional journaling and more.
In today's tutorial I'm going to show you how to make a sliding easel card.
Step 1: Trace
Start with two A6 pieces of white cardstock.
Take a ruler and pencil.
Take one of the two rectangles, which will be the front of the card, measure 2 cm all around and trace a frame.
Step 2: Cut
Then using a craft knife trim leaving the top connected.
Step 3: Layer & Cut
Matt the front of the card with patterned paper.
Add double-sided tape on the 2 cm frame only. This way you can cut the aperture easily and keep the sliding flap white.
Turn around, fold the flap and use your craft knife to trim the paper.
Step 4: Fold
Score the sliding flap in half, fold and burnish.
Step 5: Create the Flap
Cut a strip of white cardstock the same width as the flap and glue them together creating the sliding mechanism.
Step 6: Foam Tape
Add foam tape on the back, but make sure you leave the top side free.
Affix it to the other piece of white cardstock.
Step 7: Jar
Die-cut 2 jars out of holographic card and cut out the centre of the jar.
Before die-cutting I added adhesive sheet on the back to make the next step easier.
Stick it to a piece of acetate paper and fussy cut it.
Die-cut the jar cap.
Step 8: Candies
Die-cut a few candies.
As the jar will be transparent I decided to layer the candies to be double sided.
Step 9: Closing the Jar
Add foam tape on the back of the jar, position the candies in the centre and affix the 2 sides together.
Adhere the cap and embellish.
Step 10: Assemble
Add a sentiment and add double sided tape on the back matching the positioning of the sentiment.
Adhere the topper on the sliding flap of the card. Add a few candies on the bottom side.
Step 11: Finish
Finish by adding a small circle to the top of the flap making it easier to pull.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
