Slow Cooker Terrine
850
18
Making Terrine looks daunting, but with a Slow Cooker it is really quite easy and cheap to do.
For not a lot of money or time, you can create a stunning centrepiece for your next party or just a quiet Sunday afternoon and your friends won’t believe you made it yourself!
You Need:
Slow Cooker
Loaf Pan
Clingwrap
Foil
Brick or heavy weight that fits your Loaf Pan
Ingredients
500g Pork Mince
2 x Chicken Thighs
2 x slices of Pork Belly or Neck
Bacon Slices
Pistachio Nuts
Salt
Pepper
Thyme (could be Dried)
Fresh Sage Leaves
Step 1:
Dice the Chicken and Pork into small cubes
Step 2:
Add the Chicken, Pork, Salt and Pepper (to taste, but I use a lot), Pistachio Nuts and Thyme to the Pork Mince.
Mix this thoroughly with your hands
Step 3:
Line the Loaf Pan with Cling-wrap
Step 4:
Arrange the fresh Sage Leaves in the bottom of the pan, try to make a pattern or at least be neat, this will be seen when you serve the Terrine.
Step 5:
Line the Loaf Pan with the Bacon, making sure the pieces overlap and come up the sides of the pan and beyond
Step 6:
Now fill the Loaf Pan with the Pork and Chicken mixture, make sure to press it in firmly to eliminate air pockets
Slightly overfill the pan
Step 7:
Top the mixture with Bacon and fold the ends of the lining bacon over the top
Now fold the cling-wrap over the top and cover the pan with foil, this will prevent any steam from getting in
Step 8:
Place the Loaf Pan in the Slow cooker, turn on to low and carefully pour in boiling water till it is ¾ the way up the sides of the pan
Place the lid on top of the slow cooker.
Now go and do something else for 6 hours
Step 9:
After 6 hours turn the slow cooker off and carefully remove the Loaf Pan from the Slow Cooker.
Careful it will be HOT, I use silicone gloves.
Wrap the brick in foil and place on top of the Terrine, I find a small block of wood helpful if the brick is a little big for the pan. This will keep pressure on the mixture as it cools.
Put the pan on a tray in case of spillage and put the whole thing in the fridge to cool overnight
Step 10:
When you are ready to serve, remove the pan from the fridge, and lift off the weight.
Step 11:
Unwrap the foil and cling-wrap and use the cling-wrap to loosen the Terrine from the pan
Step 12:
Turn the pan over onto a board and carefully lift the pan off then unwrap and remove the cling-wrap
Step 13:
Serve with toast slices and pickle
Slow Cooker Challenge
Runner Up in the
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    2 Discussions
    JettaKnight
    11 months ago
    That looks really tasty! Are pistachio nuts a common ingredient in terrine? Also, I'll say what you call bacon is what we Americans call "Canadian Bacon". It's not smoked, right?
    UrbanGrillerJettaKnight
    Reply 11 months ago
    This is a 'French Style' Terrine, Pistachio nuts are common, for the colour they bring, but sometimes Almond is used, it is just a little crunch in the texture. The bacon is not smoked in this case to keep the flavour mild, if you were using something stronger like Venison, a smoked Bacon or Spec would traditionally be used.
