Small DIY Bench Power Supply
10,377
99
29
About: Always loved electronics. I like to reuse parts or componets and I Love to be part of the Instructable community.
Here is a small video showing my latest project. It is a small bench power supply that can adjust with precision current or voltage.
It is the first time I use an aluminium enclosure, so I decided to engrave the labels and symbols. I use 10 turn wirewound potentiometers to be able to adjust the voltage or current with precision. I power it with a laptop charger, like the my Mini Adjustable power supply . This adjustable power supply is larger than the "Mini" I made, but it is a lot easier to use and has a few other advantages.  I will be posting an Instructable with detailed instructions of how I've made it.
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    29 Discussions
    FreeW
    3 years ago
    I just would like to make a note that
    Volt, Amp Metter is useless. I bought 5 of those and find out that when you adjust voltage lest say to 1 volt and increase voltage to 15 it show 13-14 volts so it go off by 1-2 volt. I would guess if you go to 30 volt the error would be even bigger.
    kratochviljan
    3 years ago
    Hi, it seems to me that your power supply didn't hold output voltage when load is connected (output enabled). E.g. when you set output voltage to 10V without any load (or with OE switched to OFF) voltage drop significantly when you connect the load (or turn OE switch to ON). I thing this should be the basic feature of any LAB power supply - to hold output voltage.
    vimajks
    4 years ago
    Hi i still say Newton your the best lots and lots of love for your help and projects.
    vim from the united kingdom
    vimajks
    4 years ago on Introduction
    Hey...... Newton thanks a million.
    Wow..... well good ill give it a go.
    cheers
    vim
    vimajks
    Hi newton
    wow that would be loved by many.
    please let me know ones instructions are
    posted.
    cheers
    VirtualB
    Very nice looking PSU. Any update to the creation of the instructable. I am working on one that will be Li-Ion battery powered with charger built in. Can't wait to see under the hood. Your work is so professional looking....
    newtonn2VirtualB
    Reply 4 years ago on Introduction
    Thank you very much. I'm working on the instructable right now, I hope to have it done in a few days.
    Hi below you said that you use a attiny85 to control the led's. How did you provide a correct vcc to the attiny85 when the input to tge lab supply is say 12 volts ?
    I am trying something similar to you. I also want the output switch to be a latch button so I can default to output off on power up.
    Thanks
    Hi there. Sorry for late reply.
    I used a voltage regulator to bring the power down to 5v. I'm working right now on the instructable, so hopefully it will be done in a few days.
    This is amazing. I can't wait for this instructable to be done. Thank you for your time and willingness to share!
    jhodso
    4 years ago
    Thanks for responding:)
    Sorry, I was kinda a jerk.
    I understand that you are busy I know that it takes a while to make a instructable.
    jhodso
    4 years ago
    He may have bailed because last comment on here was on June 16th, 2014. He probably has a new interest and is too busy. :(
    newtonn2jhodso
    Hi Jhodso,
    I sent you a private message some time ago, did you received it? I'm sorry it is taking me so long. I'm very busy at the moment, but I will finish the instructable for sure, but when.... I don't know really.
    newtonn2m_a_x
    Reply 5 years ago on Introduction
    Thank you very much, I'll post an instructable with all the info and photos.
    m_a_xnewtonn2
    OK, i wait; hopefully before the LM2596 becomes obsolete :))
    Just joking, the project is good for any module, now i am looking at XL4005 modules with a 5A rated current
    vimajks
    I know am a pest newton, but my parts have arrived please... please lets have the Unique build piccy, plans step by step guide.
    we hounour newton.
    respect
    vim
