Small Greenhouse for Plantations on Euro Pallets
9,287
188
21
About: Software engineer and aquaponic lover
Winter is coming and in order to get some lettuces during the winter I created this greenhouse for my plantation boxes.
I hope you will enjoy this instructables this is the first of mine. Please provide feedback :)
I did some measures to observe the difference of temperature inside and outside the greenhouse (third picture) and as you can see it seems pretty good.
Note: the measure were done with the greenhouse totally closed.
Supplies:
Step 1: Required Material
(todo)
  • 2x wood 80cm
  • 2x wood 111.5cm
  • 4x angles (alloy)
  • 1x box - screws 4.0x30mm
  • 1x plastic tube (10 - 15 meters)
  • 1x plastic film
Here are the links to the products I bought:
pipes for lanes
pipes for arcs
plastic film
wood
Step 2: Prepare 4 Stuck of Wood
You need to get 4 pieces of wood.
  • 2x 80cm
  • 2x 111.5cm
Step 3: Fix the Wood Parts Together With Angles
Simply rely the four parts together with 4 angles and screws.
In order to obtain something flat I recommend to do it on the floor (not vertically) that way you are sure (assuming your floor is flat.)
Step 4: Perfore 6 Holes in the Wood
In order to introduce the tubes we need to perfore 6 holes.
1 on each corner and 2 in the middle of the longest parts of wood.
Step 5: Cut 3 Arcs
Cut 3 arcs of the same length in the plastic tube.
I used some tubes quite flexible take care when you buy yours that they are enough flexible
Step 6: Place the Tubes Into the Holes
Step 7: Fix Theses Arcs
With a screw fix the arcs simply by perforing the wood and then the tube will be like attracted to the exterior of the wood.
Step 8: Perfore the Top of Each Arc
Then you need to perfore the top of each arc that way we can attach the rest of the structure and we get sure it is not going to move.
Step 9: Prepare 3 Tubes
You can cut 3 tubes of the same length.
All of them have to measure 117cm.
Step 10: Perfore Extremities of the Tubes
Perfore each extremity of each of the tree tubes.
Step 11: Fix the Top Tube
Use the small holes we did earlier to fix all of it.
Step 12: Fix the Two Other Tubes
Exactly like previous step
Step 13: Plastify
This part is the most difficult. In order to get good looking results you need to go slowly and carefully.
Step 14: Optional 1: Make It Adjustable
If you put these 2 peaces you can quite easily make it really convenient.
I prefere this variant because you can really simply open the greenhouse without efforts.
Step 15: Optional 2: Cut Some Windows in the House
If like me in this situation you want to simply have some windows to put your hands on you can easily cut some "doors" into the plastic.
I don't know how it will support winter but I guess it's not optimal.
(Open to suggestions)
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    21 Discussions
    BeverlyR17
    1 year ago
    Great idea well done
    Doing
    1 year ago
    Great idea! I really like all the good, clear, pictures. Thank you.
    Cheiron
    1 year ago
    Great Instructable! I have a question though. Is the plastic pipe regular PVC? One suggestion as well, you might consider using UV resistant zip ties (usually black). Regular zip ties last about 1 year in direct sunlight.
    svermeilleCheiron
    Reply 1 year ago
    Hi again I added the links to the plastic pipes description
    svermeilleCheiron
    Reply 1 year ago
    Hi Cheiron thank you :)
    I used two types of plastic pipe basically. One is formable (keep the form I give him). And for the lines one I used long plastic tubes.
    All of these are used in electric systems.
    I will add the link to my local shop products so that you can find some more informations about the products. ( I hope they are also in english :/ )
    seamster
    1 year ago
    Great first instructable! This looks like a perfect little greenhouse. Well done :)
    svermeilleseamster
    Reply 1 year ago
    Thank you seamster :) I have to say I am really happy of it too hehe. Let see if lettuce grow up faster now !
    ericCycles
    1 year ago
    A strong wind will eventually rip the plastic right through those staples.
    I would recommend sandwiching the plastic with extra wood strips so its held uniformly along its length.
    svermeilleericCycles
    Reply 1 year ago
    Hi ericCycles
    true it could. For this reason the peace of plastic is comming inside the house. That way the wind could not pass between the wood and the plastic. But sure it I have problems regarding it I will adapt this system to use your solution and update this instructables ;) Thank you for your suggest
    KarinE3
    1 year ago
    This is exactly what I have been looking for! Thank you for the great up close photos. This will be my first Instructable project I make.
    svermeilleKarinE3
    Reply 1 year ago
    Hello KarinE3,
    thank you glad I can help :) if you have any questions feel free to ask
    Cueball21
    1 year ago
    Great idea and perfectly presented! Thank you!
    I've done something very similar but without the box. I live in an area without harsh winters; so I bend plastic like that you show and place the ends over steel re-bar driven into the ground. This makes a good Winter shelter for potted plans and can easily be formed around plants in the ground to protect them.
    Place the rebar stakes in straight lines opposite each other. I usually place them to form an area 4 feet wide and as long as I need it to be. I use 18" rebar with about 6-8" left above ground level. I connect straight pieces of plastic pipe with zip ties, just as you show, then place 4 mil plastic sheet over the frame being careful to cut it leaving enough length at both ends to be able to wrap and close them. I also cut the plastic to have an extra 2 feet of width - 1' for each side -leaving enough to weight down with sand snakes - tube cloth or tubes formed with the plastic filled with sand and tied off at ends - around the perimeter but logs, stones or bricks - anything heavy enough to hold it in place - on top of the excess width of plastic to keep wind from getting under and blowing the plastic away. I've also used shorter sand snakes placed on top along the ribs when winds get very high.
    The first one I made I tried to tie the plastic sheet using zip ties but that led to tears where the plastic is pierced. In my area it is common for Winter days to go from freezing to quite warm throughout the season. Leaving the ends only folded and weighted makes it easy to ventilate the enclosed area. Loosing and raising one side makes it easy to water and replace the cover.
    svermeilleCueball21
    Reply 1 year ago
    Hi Cueball21 thank you for your experience sharing and your support :) we have quite hard winter here so I think I will have to move the snow away when there are but it should be okay I'm optimist :)
    JoeV24
    1 year ago
    It would be handy to know the latitude of the person posting this green house. I live at 46.126 degrees N latitude.
    svermeilleJoeV24
    Reply 1 year ago
    Hello JoeV24. Here are the coordinate of my village
    47.223564, 7.109696
    Nice greenhouse. Have you measured the difference in temperature between inside and outside of the greenhouse?
