Smart Mouse Trap
For this project, this is an improved version of -Gary's Arduino Mouse Trap (https://www.instructables.com/id/Arduino-Mouse-Trap/) . Once a mouse is caught, an email will be sent to your email address that can be seen on your phone or your computer. Another advantage of this mousetrap is that this is a no-kill trap and the mouse can easily be released by the user once caught. The reason for this design was to be able to catch a mouse and be notified when it's caught rather than having to check on it every so often.
Step 1: Components Required
  • Breadboard
  • Adafruit Feather HUZZAH ESP 8266 (connected to wifi) https://www.adafruit.com/product/3213
  • 1 10K ohm resistor
  • 1 330 ohm resistor
  • Jumper wires
  • 1 Servo motor [3V-6V DC]
  • 1 IR photo transmitter
  • 1 IR emitter
  • Case and door for trap
  • Bait (once trap is set up)
  • Micro USB cable or lithium battery (to power Feather)
The total cost of the trap is about 25$ but several parts could be salvaged from other builds such as resistors, IR emitters, jumper wires, and the case/door for the trap. Also, make sure IR photo transmitter and emitter are at the same wavelength.
Step 2: Fritzing Schematic and Codes
Please make sure to follow the notes on the circuit diagram. Also, when using the mousetrap code in Arduino when you are entering your email and password for your gmail account, make sure to use base 64 encoding with the following link. https://www.base64encode.org/
Further reference for the gmail coding can be referred to here:
https://www.instructables.com/id/ESP8266-GMail-Sen...
The Gsender code is what allows the huzzah to send email through gmail. This code was chosen because gmail would be able to be accessed by the user (other sender codes can be used as well).
Step 3: How to Assemble
To make sure that the circuit worked, I tested the components and the pinouts with an Arduino UNO and modified the code accordingly. After making sure it all worked, then switch the IR emitter and phototransistor to hook up to the cage/box. There are several ways to do this such as little mounting kits. But for sake of ease, I simply slid the box on top of the two. Furthermore, the cage is simply modified chicken wire and the door is a piece of plastic taped to the servo to which the servo is hot glued to the cage. If desired, you can move the servo and adjust the angle of opening and closing accordingly along with the door you use. This design would encage a mouse. However, the door would definitely need to be strengthened in order to hold in a mouse, such as with a thicker piece of plastic or even metal.
Step 4: In Action
In the video, the trap is set to close and shown is simply the door opening and closing.
Have fun building and catching the mice!
    • Tape Contest
      Tape Contest
    • Organization Contest
    • Pocket Sized Contest
    6 Discussions
    ilpug
    4 months ago
    This is a good electronics proof of concept but I feel that its too complicated. I would adapt the classic mason jar live trap design and add a pressure or motion sensor, and run a wire from the sensor to an LED in an easily visible location. This simplifies the trap, leaves the actual catching to a tried and true method, and allows a good balance of remote sensing and simplicity (also removing the insecure IOT interface). Also would add that the mouse is going right through any wires accessible inside or near that cage.
    chazwilliams16ilpug
    Reply 4 months ago
    I definitely see where you are coming from and think that's a good idea. The way this trap is set up is for demonstration. Once I use it to catch mice, I will move the trap away from all of the electronic components.
    AussieAlf
    4 months ago on Step 4
    A trapped mouse would crap and pee. I'd be moving the cage to one side. Hate to be the one picking that out of your breadboard.
    chazwilliams16AussieAlf
    Reply 4 months ago
    Of course, I just set it up this way since I didn't have any mounts for the IR emitter and phototransistor on me at the time. More for demonstration than anything else.
    tytower
    4 months ago
    Perhaps you could email the mouses partner and family and let them know where it is?
    tytower
    4 months ago
    All good until it rains or gets humid.
