Soft Box for Less Than $5
1,904
32
About: making makes me feel enlightened .And tinkering is my Passion
Getting started for Professional Photography make yourself one of the bare minimums of the skill,to avoid those shadows.
Step 1: Material Needed
  • Led strip(2.25m)
  • Lots of tape
  • Aluminium foil
  • Glue
  • Scale
  • Cutter
  • Soldering iron
  • Power supply(12v ;2amp)
  • Foam board or Cardboard
  • Butter paper
  • Rubbing alcohol
  • Some solid base(for cutting)
Step 2: Cut the Box
Cut the base for the Soft box from the foam board or cardboard as per availability.Use the templates give to cut the base.
Step 3: Paste the Led Strips
Leave a gap of half a cm from each side and star pasting the strips without leaving the gap,You will need 15 pieces of 15 cm long led strip.
Step 4: Wiring It Up
To wire it up connect all the strips in series,or for all the noobs out there just follow the snake pattern and connect all +ve to +ve and -ve to -ve terminal,solder a longer wire at the end for connecting with the power supply
Step 5: Finishing It All Up
Just connect all the walls using tape,stick aluminium foil to the walls and finally add the butter paper to the top.And now our soft box is ready.
Step 6: Some Before and After Pictures
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
