Solar George Foreman Cooker
28,850
107
25
About: CNC Enthusiast, Amateur Astronomer, Photography, Computer hardware and programming, Arduino, Raspberry Pi
Following the success of my 4ft solar cooker, I wanted to go larger. Finding a rigid satellite larger than 4ft can get very expensive, as you won't likely find one for free. I searched Craigslist and eBay, but nothing affordable came along. I had posted a picture of my 4ft dish on Facebook, and a cousin of mine texted me that he had some more satellite dishes in his back yard.
Step 1: What Is It?
I took a trailer over to my cousin's house and picked up 4 cages of satellite dish quarters. Each cage has two quarters of a dish mounted to the cage. The label on the cage is AS-554/TRC-29. This is a military nomenclature. Some google searches found that the TRC-29 is a microwave radio, and the AS-554 is the antenna from the 1950's. These are 'expanded metal' or mesh dishes made of Aluminum. I now had to engineer a way to set it up to be easily moveable to point at the sun.
Step 2: Dream a Little Dream...
Most terrestrial satellite dishes are setup to pivot right around the center of the dish. This means that I would have to have a mount about 5ft tall to support an 8ft dish. There would be a lot of stress on the linkages using this type of setup while still making it mobile or portable. My first ideas were to have a curved cage to keep onlookers at bay while having three legs to support the center mast. Not having a roller bender, I would be unable to build such a mount. I thought about alternatives, and finally settled on a giant lazy Susan style base and only using 3/4 of the dish.
Step 3: Gather Resources.
Again I collected old/bad hard drives. Disassembling them all, I saved the platters for reflective material and the NEO magnets for other projects. This dish would require approximately 400+ platters.
Step 4: Testing the Mount
I purchased a few long pieces of 1.5x1.5 box tubing, some end caps, and some sliding pin locks. I used an arc welder to stick weld together the frame. I designed the four wheels to have pivot points so that in one position, the wheels are aligned in parallel so it will roll as a trailer. In the other position (45 degrees off), it will rotate in place. I assembled three pieces of dish, added a pivot point to each side near the center of balance so it would be easier to position.
Step 5: Get the Most Coverage
I spent some time laying out the best way to have the most coverage with the least amount of gaps. After several iterations, I settled on a design. I then started gluing on the platters with standard white tub caulk. Two dabs, and then flatten the back side with a putty knife to ensure the coverage sticks (the photo is from another dish with finer mesh, but the affect is the same).
Step 6: Get Sunny
I purchased a used George Foreman grill from Goodwill. I managed to attach it to the dish with a couple arms so that it was near the focal point. The first photo is on a rainy day (see the rain drops?), the second photo is from a sunny day. I put a couple burgers and brats on it. Temps held steady at 350 degrees F. The reason it did not get hotter is the curvature of the dish is not as accurate as my previous 4ft solid dish, so the focal area of solar concentration is a lot larger. Short shaky video of the meat smoking!
Step 7: Next Time...
Dream a little bigger... I found a 12ft mesh dish that will require 1100 hard drive platters...
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    25 Discussions
    JohnC430
    2 years ago
    could you use CD's instead of HDD? where are you getting all the old hard drives from?
    alex456
    2 years ago
    Hello. How you calculated the focal length of your concentrator? Do you have any estimates or did you come to this by experiments?
    GregO29alex456
    Reply 2 years ago
    Typically if you have the entire dish assembly with the feed horn (LNB or whatever), that will be the focal point. But in this case I did not. I googled a formula like this one to calculate the focal point, then I added a few platters on the outer edges and some on the center to measure it more accurately.
    Dan Elliott
    2 years ago
    Very cool / hot use of old disks. At my work we used old CDs as scales for a giant bass interactive at a children's museum. I think your Solar Grille would be a great class project for a school science class on a budget.
    Cheers!
    mcousineau1
    2 years ago
    Good project why hard drive disk ? just aluminium tape from homedepot would not do the job in ventilation section. ?
    Oncermcousineau1
    Reply 2 years ago
    I suppose hard drive disks have a good mirrored surface and aluminium tape not so, but I was thinking CD's or would the diffraction patterns play hob with the focus?
    mcousineau1 Oncer
    Reply 2 years ago
    Some have done it with CD like this one https://www.instructables.com/id/Satellite-Dish-Solar-Cooker-1/
    but also with aluminium tape like this one
    https://www.instructables.com/id/How-to-make-a-solar-cooker-from-a-satellite-dish/
    So go foil tape on this big guy https://www.homedepot.ca/en/home/p.foil-tape-2x30.1000167778.html
    Seem's to work with foil tape but your hard drive thing is a good recycling technique... less HD in india...
    GregO29mcousineau1
    Reply 2 years ago
    Thanks, but your first link is my 4ft solid dish with Hard Drive Platters, NOT cd's. CD's will diffract light as well, and do not have as high of reflectance as plated aluminum. Think of the rainbow you see on a CD/DVD, compared to the mirror image you get looking at a Hard Drive Platter.
    GregO29mcousineau1
    Reply 2 years ago
    Thanks for the question. Multiple reasons:
    1) Reflectivity. This is a mesh dish, not solid, so there is not a smooth surface to apply it to. Wrinkles equals diffraction. Flapping tape equals diffraction. Hard drive platters are hard, and retain their mirror like surface, even in wind.
    2) Cost. The drives were free. The HD tape is $7.68 and could cover 5sq ft. This dish is 8ft or just over 50sq ft. Using 3/4s of it, I would need 7-8 rolls of tape making an out of pocket cost of $50-60.
    3) A solid 8ft dish can become a sail. The 'wasted' space by the holes in the center of disks and the gap in between their outer edges provides a bit of wind relief so it does not become too unmanageable in slight winds. Think of advertising banners that you may have seen with the holes punched in them so there is less wind stress.
    askjerry
    2 years ago
    Using hard drive platters... wow... that's impressive. When I saw the first picture I thought you were going to say old CDs... that's pretty inginus my friend!
    ConradC3
    2 years ago
    WOW! 400 Platters X 6 screws each platter and 6 screws in the hard drive enclosure. 400 X 12 = 4,800 screws. Well done Sir!
    GregO29ConradC3
    Reply 2 years ago
    Sometimes I like to binge watch tv while disassembling drives: Netflix and unscrew.
    lfossConradC3
    Reply 2 years ago
    Actually, most modern hard drives (made within the last 20 years or so) have 7 screws holding the case together. There are the 6 around the edge and then a 'hidden' one in the center, usually underneath a sticker.
    Also multi-platter hard drives only have one set of screws holding the entire spindle group to the motor. So taking off these 1-8 screws (varies by manufacturer) could yield 2 - 4 platters.
    Anyway, I wasn't trying to make your point any less valid. Just pointing out a few errors in your math. Either way, that's still a lot of screwing!! Err.. unscrewing?!
    Warleyman
    2 years ago
    How about using old CD's or DVD's - might be easier to get hold of than hard drive platters and more reflective than aluminium tape?
    Aaaecm
    2 years ago
    Sorry, I had another thought. This antenna does not have a well defined focus. Could a second, much smaller parabolic dish be placed at the present focus to reflect the light into a smaller point located between the two mirrors? Position the collecting point so it doesn't throw a shadow on your larger mirror? I bet you could achieve a higher temperature if the solar energy was more concentrated. I'll stop now.
