Solar Powered WiFi Weather Station V1.0
220,445
1,325
271
About: I am an Electrical Engineer. I love to harvest Solar Energy and make things by recycling old stuff. I believe, IF YOU TRY YOU MIGHT, IF YOU DON'T YOU WON'T. www.opengreenenergy.com
In this Instructable, I am going to show you how to build a Solar powered WiFi Weather Station with a Wemos board.The Wemos D1 Mini Pro have small form-factor and wide range of plug-and-play shields make it an ideal solution for quickly getting started with programming the ESP8266 SoC. It is an inexpensive way to build Internet Of things ( IoT ) and is Arduino compatible.
You can also look my new version-2.0 Weather Station.
You can find all of my projects on : https://www.opengreenenergy.com/
The new Weather Station have following features:
1. The Weather Station can measure :Temperature, Humidity , Barometric Pressure , Altitude
2. You can monitor the above weather parameters from your Smartphone or from the web ( ThingSpeak.com )
3. The whole circuit along with power supply is put inside a 3D printed enclosure.
4. The range of the device is enhanced by using an 3dBi external antenna .It is around 100 meter.
Step 1: Parts and Tools Required
1. Wemos D1 Mini Pro (Amazon / Banggood )
2. TP 4056 Charging Board ( Amazon / Aliexpress )
3. Diode ( Aliexpress )
4. BME 280 sensor ( Aliexpress )
5. Solar Panel ( Banggood )
6. Perforated Board ( Banggood )
7. Screw Terminals ( Banggood )
8. PCB standoffs ( Banggood )
9. Li Ion Battery ( Banggood )
10. AA Battery Holder ( Amazon )
11. 22 AWG wire ( Amazon / Banggood )
12. Super Glue ( Amazon )
13. Duct Tape ( Amazon )
14. 3D printing filament -PLA ( GearBest )
Tools Used :
1.3D Printer ( Anet A8/ Creality CR-10 Mini )
2. Soldering Iron ( Amazon )
3. Glue Gun ( Amazon )
4. Wire Cutter / Stripper ( Amazon )
Step 2: Power Supply
My plan is to deploy the Weather station at a remote place ( my farm house).To run the Weather Station continuously, there must be a continuous power supply otherwise the system will not work .The best way to provide continuous power to the circuit is by using a battery.But after some days the battery juice will run out, and it is really difficult job to go there and charge it. So a solar charging circuit was proposed to user free energy from the sun to charge the batteries and to power the Wemos board.I have used a 14450 Li Ion battery instead of a 18650 battery because of its smaller size.The size is same as of an AA battery.
The battery is charged from a Solar panel through a TP4056 charging module. The TP4056 module comes with battery protection chip or without the protection chip.I will recommend to buy a module which have battery protection chip included.
About the TP4056 Battery Charger
The TP4056 module is perfect for charging single cell 3.7V 1 Ah or higher LiPo cells. Based around the TP4056 charger IC and DW01 battery protection IC this module will offer 1000 mA charge current then cut off when charging is finished. Furthermore when the battery voltage drops below 2.4V the protection IC will cut off the load to protect the cell from under voltage.It also protects against over voltage and reverse polarity connection.
Step 3: Measuring the Weather Data
In the earlier days weather parameters like ambient temperature,humidity and barometric pressure were measured with separate analog instruments: thermometer, hygrometer and barometer.But today the market is flooded with cheap and efficient digital sensors that can be used to measure a variety of environmental parameters.The best examples are sensors like DHT11, DHT 22, BMP180, BMP280 etc.
In this project we will use a BMP 280 sensor.
BMP 280 :
BMP280 is a sophisticated sensor that very accurately measures barometric pressure and temperature with reasonable accuracy. The BME280 is the next-generation of sensors from Bosch, and is the upgrade to the BMP085/BMP180/BMP183 - with a low altitude noise of 0.25m and the same fast conversion time.
The advantage of this sensor is that it can use either I2C or SPI for communication with microcontroller. For simple easy wiring, I will suggest to by I2C version board.
Step 4: Using an External Antenna ( 3dBi )
The Wemos D1 mini Pro board have a inbuilt ceramic antenna along with provision for connecting an external antenna to improve the range.Before using the external antenna, you have to reroute the antenna signal from the built-in ceramic antenna, to the external socket.This can be done by rotating the small surface mount (0603) Zero Ohm resistor (sometimes called a link).
You can watch this video made by Alex Eamesto rotate the zero ohm resistor.
Then snap the antenna SMA connector in to the Wemos Pro mini antenna slot.
Step 5: Solder the Headers
Wemos modules come with variety of headers but you have to solder it according your requirement.
For this project,
1. Solder the two male headers to the Wemos D1 pro mini board.
2. Solder a 4 pin male header to the BMP 280 module.
After soldering the headers the module will look as shown in the above picture.
Step 6: Adding Headers and Terminals
Next step is soldering the headers to the perforated board.
1. First place the Wemos board over the perforated board and mark the foot print.Then solder the two row of female headers over the marked position.
2. Then solder a 4 pin female headers as shown in the picture.
3. Solder a screw terminals for battery connection.
Step 7: Mount the Charging Board :
Stick a small piece of double sided tap on the back side of the charging module and then paste it on the perforated board as shown in the picture.During mounting care should be taken to align the board in such a way that the soldering holes will match with the perforated board holes.
Adding terminal for Solar Panel
Solder a screw terminal just near the micro USB port of the charging board.
You can solder this terminal in the earlier step also.
Step 8: Wiring Diagram
First I cut small pieces of different colours wires and strip out the insulation at both ends.
Then I solder the wires according to the Schematic diagram as shown in the above picture.
Wemos -> BME 280
3.3 V - -> Vin
GND --> GND
D1 --> SCL
D2 --> SDA
TP4056 Connection
Solar Panel terminal -> + and - near the micro USB port
Battery Terminal -> B+ and B-
5V and GND of Wemos -> Out+ and Out-
Note :The diode connected to the solar panel ( shown in the schematic ) is not required as the TP4056 module have in built diode at the input.
Step 9: Designing the Enclosure
This was the most time consuming step for me.I have spent around 4 hours to design the enclosure. I used Autodesk Fusion 360 to design it. The enclosure have two parts : Main Body and Front Cover
The main body is basically designed to fit all the components. It can accommodate the following components
1. 50x70mm circuit board
2. AA battery holder
3. 85.5 x 58.5 x 3 mm Solar Panel
4. 3dBi external antenna
Download the .stl files from Thingiverse
Step 10: 3D Printing
After completion of design, it is time to 3D print the enclosure.In Fusion 360 you can click on make and slice the model by using a slicer software.I have used cura to slice the model.
I used an Anet A8 3D printer and 1.75 mm green PLA to print out all the body parts. It took me about 11 hours to print the main body and around 4 hours to print the front cover.
I will highly recommend to use another printer for you that is Creality CR - 10. Now a mini version of the CR-10 is also available.The Creality printers are one of my favorite 3D Printer.
As I am new to 3D designing, my design was not optimistic.But I am sure, this enclosure can made by using lesser material ( less print time ). I will try to improve the design later.
My settings are:
Print Speed : 40 mm/s
Layer Height : 0.2
Fill Density : 15%
Extruder Temperature : 195 degC
Bed Temp : 55 degCr
Step 11: Installing the Solar Panel and Battery
Solder a 22 AWG red wire to the positive terminal and black wire to the negative terminal of the Solar panel.
Insert the two wires in to the holes in the roof of the main enclosure body.
Use super glue to fix the Solar Panel and press it some time for proper bonding.
Seal the holes from the inside by using hot glue.
Then insert the battery holder in to the slot at the bottom of the enclosure.
Step 12: Installing the Antenna
Unscrew the nuts and washers in the SMA connector.
Insert the SMA connector in to the holes provided in the enclosure.See the image above.
Then tighten the nut along with the washers.
Now install the antenna by properly aligning with the SMA connector.
Step 13: Installing the Circuit Board
Mount the standoffs at 4 corners of the circuit board.
Apply super glue at the 4 slots in the enclosure. Refer the above picture.
Then align the standoff with the 4 slots and place it.leave some to dry it out.
Step 14: Close the Front Cover
After printing the front cover, it may be not perfectly fit to the main enclosure body.If it is the case, just sand it at the sides by using a sand paper.
Slide the front cover in to the slots in the main body.
To secure it, use duct tape at the bottom.
Step 15: Programming
To use Wemos D1 with the Arduino library, you'll have to use the Arduino IDE with ESP8266 board support. If you haven't already done that yet, you can easily install ESP8266 Board support to your Arduino IDE by following this tutorial by Sparkfun.
Following settings are preferable :
PU Frequency:
80MHz 160MHz
Flash Size: 4M (3M SPIFFS) – 3M File system size 4M (1M SPIFFS) – 1M File system size
Upload Speed: 921600 bps
Arduino Code for Blynk App :
Sleep Mode :
The ESP8266 is a pretty power hungry device. If you want your project to run off a battery for more than a few hours, you have two options:
1. Get a huge battery
2.Cleverly put the Thing to sleep.
The best choice is the second option.Before using the deepsleep feature, Wemos D0 pin must be connected to the Reset pin.
Credit : This was suggested by one of the Instructables user " tim Rowledge ".
More Power Saving Option :
The Wemos D1 Mini has a small LED that lights when the board is powered.It consume lot of power.So just pull that LED off the board with a pair of pliers. It will drastically drop the sleep current down .
Now the device can run for long time with a single Li Ion battery.
#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space<br>#include < ESP8266WiFi.h>
#include  <BlynkSimpleEsp8266.h ></p><p>
#include "Seeed_BME280.h"
#include < Wire.h>
BME280 bme280;
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "3df5f636c7dc464a457a32e382c4796xx";// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "SSID";
char pass[] = "PASS WORD";
void setup()
  Serial.begin(9600);
  Blynk.begin(auth, ssid, pass);
  Serial.begin(9600);
  if(!bme280.init()){
  Serial.println("Device error!");
void loop()
  Blynk.run();
  //get and print temperatures
  float temp = bme280.getTemperature();
  Serial.print("Temp: ");
  Serial.print(temp);
  Serial.println("C");//The unit for  Celsius because original arduino don't support speical symbols
  Blynk.virtualWrite(0, temp); // virtual pin 0
  Blynk.virtualWrite(4, temp); // virtual pin 4
  //get and print atmospheric pressure data
  float pressure = bme280.getPressure(); // pressure in Pa
  float p = pressure/100.0 ; // pressure in hPa
  Serial.print("Pressure: ");
  Serial.print(p);
  Serial.println("hPa");
  Blynk.virtualWrite(1, p); // virtual pin 1
  //get and print altitude data
  float altitude = bme280.calcAltitude(pressure);
  Serial.print("Altitude: ");
  Serial.print(altitude);
  Serial.println("m");
  Blynk.virtualWrite(2, altitude); // virtual pin 2  //get and print humidity data
  float humidity = bme280.getHumidity();
  Serial.print("Humidity: ");
  Serial.print(humidity);
  Serial.println("%");
  Blynk.virtualWrite(3, humidity); // virtual pin 3
  ESP.deepSleep(5 * 60 * 1000000); // deepSleep time is defined in microseconds.
Step 16: Install Blynk App and Library
Blynk is an app that allows full control over Arduino, Rasberry, Intel Edision and many more hardware.It is compatible for both Android and IPhone.Right now the Blynk app is available with free of cost.
You can download the app from the following link
1. For Android
2. For Iphone
After downloading the app, installed it on your smartphone.
Then you have to import the library on to your Arduino IDE.
Download the Library
When you run the app for the first time, you need to sign in – so enter an email address and password. Click the “+” at the top-right of the display to create a new project.Then name it.
Select the target hardware " ESP8266 "Then click “E-mail” to send that auth token to yourself – you will need it in the code
Step 17: Make the Dash Board
The Dashboard is consists of different widgets.To add widgets follow the steps below :
Click “Create” to enter the main Dashboard screen.
Next, press “+” again to get the “Widget Box”
Then drag 4 Gauges.
Click on the graphs,it will pop up a settings menu as shown above.
You have to change the name "Temperature",Select the Virtual Pin V1, then change the range from 0 -50.Similarly do for other parameters.
Finally drag a graph and repeat the same procedure as in gauge settings.The final dashboard picture is shown in the above picture.
You can change the color also by clicking the circle icon on the right side of the Name.
Step 18: Uploading Sensor Data to ThingSpeak
First create an account on ThingSpeak.
Then create a new Channel on your ThingSpeak account.
Find How to Create a New Channel
Fill Field 1 as Temperature ,Field 2 as Humidity and Field 3 as pressure.
In your ThingSpeak account select “Channel” and then “My Channel”.
Click on your channel name.
Click on “API Keys” tab and copy the “Write API Key”
Open the Solar_Weather_Station_ThingSpeak code .Then write your SSID and Password.
Replace the “WRITE API ”with the copied “Write API Key”.
Required Library : BME280
Credit : This code is not written by me .I got it from the link given in a YouTube video by plukas.
Step 19: Final Test
Place the device on sunlight, the red led on TP 4056 charger module will lit up.
1. Blynk App Monitoring:
Open the blynk project.If everything is Ok,you will notice the gauge will live and the graph stat to plot the temperature data.
2. ThingSpeak Monitoring :
First open your Thingspeak Chanel.
Then go to “Private View” tab or “Public View” tab to see the Data Charts.
Thanks for reading my Instructable.
If you like my project, don't forget to share it.
Microcontroller Contest 2017
First Prize in the
12 People Made This Project!
  • Paper Contest
    Paper Contest
  • Organization Contest
  • Sweet Treats Challenge
271 Discussions
Sandbird
6 weeks ago
I dont get...i've got exactly the same parts (just a tiny difference with the mAh of the battery), and my battery is fully charged (i get 3.8v on the meter), but the wemos wont do anything when it's powered by the battery. Just blinks once and then nothing. It's as if it doesnt have enough power to function properly. When i power it up from a usb 5v shield everything works fine.
Measuring the voltage with battery, at the 5v pin i get 3.5v and when i reset the wemos the BME pin reads 3.2v. (I got a cheap multimeter...maybe that's why)
I got 2 of these batteries (https://www.aliexpress.com/item/New-2PCS-3-7V-NCR-...
Could it be the mAhs ?
I dont know...i cant think of a solution :/
SandbirdMichaelB247
Reply 2 days ago
hmm, mine says 4B2X..crap i guess i got a fake one. I have to find a 500ma one i guess uh?
Needlerp
1 year ago
I love your project and would like to expand on it, adding in a few sensors: rain, wind speed, wind direction, UV, battery voltage. However I'm a total novice when it comes to electronics and am hoping the community can help. I've attached my draft layout, and would really welcome any feedback on what I've got wrong!! Specific questions are as follows:
1. The rain sensor and wind speed will be interrupts based on reed switches. Is it Ok to connect the reed switch directly between GND and a digital pin, or do I need resistors in there somewhere?
2. I've multiplexed the Analog pin to read the wind direction potentiometer, UV sensor and battery monitor. Again, am I resistors missing here?
3. I've proposed a PNP transistor controlled via D2 to turn on/off the voltage monitor, with a 1k resistor - do I need it and if so is 1k sufficient?
4. I've put a momentary switch between D5 and GND which will be used to boot the D1 Mini into WIFI AP config mode to set SSID, add WeatherUnderground API etc.
As you can see from the questions, I know that I don't know much about the resistors, but I'm sure that there are other basic errors that I don't know about!
Thanks in advance for your support.
farmerkeithNeedlerp
Reply 1 year ago
Its quite ambitious. I suggest you go one step at a time.
Re your questions:
1. no resistors needed, provided you activate the pull-up resistors built in to the ESP8266 (rain on D8 and Wind speed on D7)
2. I think you need to study your multiplexer for the analog voltage input more carefully. Its a bit hard to understand from the picture you provided, but I think you intend to use D2 (for Vcc), D6 (for wind direction) and D7 (for UV level). D6 and D7 will be set Low when not measuring and High when measuring. D2 (for Vcc) will be the reverse, that is Low when measuring and High when not measuring. The emitter of the PNP transistor is connected to Vcc, the base goes to D2 via a 1K resistor, and the collector goes to A0 via a diode.
You need to provide a resistive voltage divider for these measurements, because the analog input can only measure between 0 and 1 Volt. The divider could be (say) 23K and 10K so that 3.3V at the junction of the 3 diodes will translate to 1.0V at pin A0. The values you should use depend on the resistance of your UV sensor, and the pot you are using for wind direction. There are good articles on resistive voltage dividers on the internet.
Also depending on the diodes you use, the voltage drop in the diodes will affect the values you get, which will need to be compensated if you want accurate results.
3. The size of the resistor from D2 to the base of the PNP transistor should be less than the resistance of the above voltage divider, and the minimum current gain of the PNP transistor you are using.
4. No resistor needed as long as you set the internal pull-up. I don;t understand how you will use this input, so I can't comment on the function you intend.
Other comments:
I see your picture has the battery charge controller without undervoltage cut-off.. I think the undervoltage cut-off is a very desirable function to get, to protect your battery from over dischage, which can ruin it.
Good luck and enjoy the journey.
Dear Farmerkeith, could you tell me why the definition of voltage does not work for me? I connected the pin 5V through the resistance of 100k to A0. The connected cord in the USB, the port monitor shows Voltage - 5.1 volts. And in the Blynk program shows a zero. Zero Blynk shows when the cord is disconnected USB. When I used the sketch for Thingspeak, the power voltage I saw on the site in the field. And in Blynk for some reason does not work.
Hi ГеннадийБ2 I think your problem is probably in the software. You do not say what software you have loaded. Have you tried using the software that is included in the Version 2.0 Instructable for this project? It includes code for measuring voltage, unlike the V1.0 software which does not have the voltage measurement in it. The V2.0 software should work with the hardware of the V1.0 design and the additional connection you have described.
Keith
farmerkeithNeedlerp
Reply 1 year ago
To Needlerp, one point of correction relating to my earlier reply.
The A0 anlog input of the WeMos D1 Mini Pro has a resistive voltage divider connecting it to the ADC input of the ESP8266 microcontroller.
There is a 220K resistor from A0 to the ADC pin, and a 100K resistor from the ADC pin to Ground. This means that the 1 volt range, and 1 mv lsb sensitivity of the ESP8266 ADC, is transformed into a 3.2 volt range, and 3.2 mv lsb sensitivity.
You also need to take into account the resultant 320K input impedance of the WeMos A0 pin when designing your input voltage circuits.
If you have specific questions I will be happy to help you more.
dhnsilvaNeedlerp
Reply 1 year ago
Hi Needlerp!
I would like to put this project on WU!
Can you share your code to my understand of this process?
Thanks!
_rp_
3 days ago
How long do all these parts survive, exposed to the elements like that?
LarryF24
Question 11 days ago
How do I change from C to F temperature ?
Open Green Energy
24 days ago
My Version 2.0 Weather Station is published...
https://www.instructables.com/id/Solar-Powered-WiF...
Few works is still pending but I published it as the on going PCB challenge ideadline s aapproaching.
Special thanks to Keith and all the community members who have given valuable feedback on the comments and QA section.
tj_314
Question 7 weeks ago
Hi, guys! So, I've ordered the parts and got a 6-pin bme280.
The pinout is:
VCC
GND
SCL
SDA
CSB
SD0
So, how do I wire it up? My guess is that GND, SCL and SDA stay the same (that means pins GND, D1 and D2 on wemos). I think VIN is the same as VCC, so that should be 3.3V. but what do I do with the other two pins? Does this affect the code?
Thanks guys
1 answer
farmerkeithtj_314
Answer 7 weeks ago
Hi tj_314, You are correct about the VCC, GND, SCL and SDA pins, they are the same on the 6-pin and 4-pin devices. For the other 2 pins, connect CSB to VCC, and SD0 (which is actually SDD) to GND. The software is not affected.
For more complete details on this and other matters about the BME280, please see my Instructable on the subject at https://www.instructables.com/id/Library-for-BMP28...
This Instructable includes a connection diagram for the module and a link to a scanner that can tell you whether you have a BMP280 or a BME280 device.
JanP158
Question 2 months ago
Hi everbody, there are two pieces of code -
Solar_Powered_Weather_Station.ino and
Solar_Weather_Station_ThinkSpeak.ino
I am a bit confused. Which one should I use? Or connect them together somehow?
Please help.
thanks
1 answer
GaryK125JanP158
Answer 2 months ago
It depends on where you plan to send your data. The first uploads the data to a cellphone or tablet using Blynk. The second uses Thingspeak to upload to a web page.
EberhardG
Question 3 months ago
hi all
i would messure the nicd (a0 ...100k resistor)....but i cant modify the code....sorry i´m not a programmer....is any here who can the mesureing implement for blynk
where i can get the *ino
thanx
eberhard
