Solar Snow Melter Concept
9,692
26
5
About: Hi, my name is Rich, and I'm a certified Instructables addict!!! :)
Hello World!! My first contribution after tons of lurking...
This is an idea I had come up with when I lived in snow country. Alas, I ended up moving back to the tropics before getting to try it out. So, I'm tossing the idea out there to see if anyone can run with it.
The motivation of the idea came from the fact that every time the walkway or driveway was shoveled, there would end up being piles of snow off to the sides that you couldn't do anything with except wait for it to melt. If you happen to be in an area in which the temperature teeters between freezing and melting, you soon find yourself with mounds of solid ice in your yard...
So the idea came to me to use an old chest freezer and a home-made solar collector as a melting device. The snow would go into the freezer, get melted by the heat generated by the solar panel, then could be piped down the drain, storage tank, or wherever,
I've posted conceptual artwork that I drew with Sketchup. Sorry for the amateurish art, I'm still a newbie with the software...
Supplies:
Step 1: What You'd Need...
A chest freezer - gutted out. Although it may be possible to do this with some other type of container, the insulation of the freezer would definitely help speed the process. You can pull anything not needed out of the freezer, especially if they add weight. Note: Be a responsible citizen and make sure the freon is evacuated from the system by a qualified shop!
A solar water heater. There are several instructables on making one of these, so I won't get into it. Check these out:
https://www.instructables.com/id/Solar-Water-Heater-Part-1-The-Collector/
https://www.instructables.com/id/Do-It-Yourself-Solar-Swimming-Pool-Heater/
Because this device will be used out in freezing weather, using anti-freeze would be a good idea.
A heating element. One could be made the same way as the lines in the collector, or parts may be able to be scavenged from the freezer. Check out if the evaporator or condenser might do the trick.
A protective grate. This could be made of a heavy gauge expanded metal, or rods about the thickness used in large BBQ grills. Sitting right above the heating element, this will bear the weight of the snow and keep the heating element from getting damaged.
Plumbing from the collector to the heating element. You may want to consider hoses that are well insulated to conserve the heat. Not having played with this idea yet, I'm not sure if the convection of the heating liquid would be enough for flow control. Check valves may be considered. This would also be a good place to install a filling point for the heating liquid.
Drain system. A ball valve or garden faucet would work, plus some hoses to run to your drain or storage tank.
Wheels or casters. This will be rolled around in the snow, in the yard, in the driveway, so decent sized wheels would be a good idea.
Additional notes: It would be a good idea to have hinges attaching the panel to the door of the freezer so it can be lowered when not in use, and can have the angle adjusted for the best efficiency. See http://www.freesolarpro.com/weblog/31 on how to properly aim your panel. With the correct angle calculated, you can have props on each side of the panel to hold it at the that angle.
If anyone is able to get one of these built and working, let me know :)
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    5 Discussions
    UthaelK
    4 years ago on Introduction
    If the grate was at the top and the solar collector on the side (or even better at the bottom, but to the side), you'd get a natural water flow. Warm flows up, cold flows down.
    EcoMotive
    6 years ago on Introduction
    Good concept but you would also need a pump to circulate the fluid.
    imbigman
    7 years ago on Introduction
    Intresting Concept. I think a freezer my be to high. Its hard enough to pile the snow let alone shovel it in a freezer. I do like where you are going with this.
