$9 Solar, Wind and Hydro Turbine (on Your Faucet) Powered USB Charger
63,005
1,007
39
About: Hi, I'm Tamas (Thomas), a 19 years old Hungarian guy. My hobby started more than 10 years ago. I learn electronics, physics, programming, IoT and I'm sharing my projects with you, hope you like it!
In our world the rechargeabale gadgets have a very important role, but their batteries have a very low capacity, so they discharge fast. In this instructable I gonna show you how to build a USB device charger, that is powered by a solar panel or a wind/hydro turbine. It contains a rechargeable power bank, that can charge up your phone everywhere. This instructable is divided to parts... If you don't want to make the full project, just go to another part. Part 1 is the rechergeable power bank, that uses two AA rechargeable batteries. The Part 2 is a solar USB charger, that can charge the power bank too, and third part is hydro/wind turbine battery charger, that can be connected to a faucet, and genarates electricity. This turbine also can be connected to your bicycle, and works as a wind turbine. The instructable was made for the 15th MILSET Expo-Sciences International contest and for the Make Energy contest on this site, so if you liked vote on me. You can use this gadget at home or in a place, where is not wallplug charger. The idea is easy, but you will need some experience in electronics, and in DIY projects to make this gadget. So let's begin, I hope you like it...
Supplies:
Step 1: Tools and Materials
Tools:
1. soldering iron and solder
2. glue gun
3. desoldering pump (optional)
4. electrical tape (optional)
5. rotary tool or driller
Materials:
PART 1: Rechargeable Power Bank
• old casette box, or a simple plastic box
• 2 AA size Ni-MH rechargeable batteries (at least 2000mAh)
• battery box, or you need to connect somehow the batteries in series, like me with the electrical tape
• 9 volt battery clips, I love them, because they can be used as connectors, but you can use others
• if you can buy, get a 5v USB step up charger, but if you can't get these circuit components: TL496 IC, 46uH inductor, 10uF capacitor, a 5.1v zener diode and a female USB jack, (with these compononents you can make a 5v step up circuit)
• 7805-5v voltage regulator for charging the NiMH battery
• 47uF apacitor, and a germanium diode
• 2 switches, and 2 super bright LED-s
• male USB jack (if you want to charge the power bank from your wallplug phone charger)
• PCB board
• 2 switches
I didn't use a NiMH charger circuit, just calculated the charging time (hour=capacity/current). With my 170mA solar panel this is 11 hours, so I can not leave the batteries in charger for more than 12 hours, because they will overcharge.
PART 2: USB and battery charger Solar device
5.5v solar panel, or better (you will need at least 5.5 volts)
• old CD
• 7805-5v voltage regulator for charging the phone
• switch
• female USB jack
• wires
• 9 volt battery clip (with this you can charge the NiMH batteries
PCB board
PART 3: Hydro/Wind turbine charger
In this part you'll need to make a Joule Thief for small generator. If you want to read more about the Joule Thief, click here.
• NPN transistor (2N2222, 2N3904 BC547 equivalent)
• ferrite core (from an old CFL bulb)
• #24 AWG wire
• small motor (you can find in a RC helicopter)
• 50 ohm resistor
• PCB board
• PVC tube (the diameter needs to be so big, with you can connect to your faucet)
• plastic sheet (white or transparent)
• metallic grey paint (optoinal, but on your faucet will look much better)
• germanium diode
This generator can't charge directy your phone, but generates 100mA and more than 3 volts, that is more than enough to charge NiMH or NiCd batteries or the rechargeable power bank from the PART 1. And if the power bank is charged you can charge your phone, tablet, or GPS. Before we begin the building I need to tell you, that a simple American family uses 600 liters of water per day. This means about 1.5 hours flowing water from your faucet, and if you use this hydro turbine you can give for your battery 0.13 volts per every 1.5 hours. So a NiMH 2000mAh battery can not be charged so fast, but after 1 day you can charge your phone for about 30-25% with a 5v booster. I think this would be a great household item, because it is small, and 100mA from a small motor like this is very good, so... start building.
Step 2: PART 1: Rechargeable Power Bank
    The first step is to make the box of the project. I've used a dremel tool to cut every holes. You must to cut a hole for the female usb jack, for the 9v battery connector, and 2 smaller holes for the switches and 2 more small holes for the 2 LEDs. I love transparant design, so I usually use a transparent project box. It looks great the circuit inside, and if happens a somethimg inside I can see what is the problem.
    Step 3: PART 1: Soldering and Glue
    The circuit is designed by me, but works good. I've put a switch after the germanium diode, and to the 5v output I've soldered 2 LEDs in paralell with a switch. To the 5v output is soldered the USB jack. The TL496 is a 9v up stepper IC, that's output is regulated by a 10uF cap, and with a 5v1 zener diode. This gives 5.35 volts, that is enough for a mobile phone.The safest way is, if you buy a 5v step up circuit. On the last image is a male USB connected to a 9v battry clip... This is a charger for the power bank, that's not green energy, but useful for fast charging from a comuter or from wallplug. The input to charge the batteries (9v clip) is reversed, see on 4th photo. The 9v clip's negative connection is soldered to the positive and the positive to the negative. There you can see a 7805 voltage regulator, and a 47uF capacitor with a germanium diode. Theirs role is to ensure the proper charging. you can give him a voltage up to 30 volt AC/DC. If your circuit is done get a glue gun and fix everything, but test it before. Bring your personality in the design, that makes your gadget especial. Think different!
    Step 4: PART 1: the End and Potential Problems
    If the circuit won't work read this article. Check every connections, and the legs of the IC . If the voltage is small try with another capacitor or the last way is the 5v up stepper from the ebay. If works plug your phone in, and test how many percent can charge. You can incease the percents with batteries that have higher capacity. If you've liked read the PART 2. If you have an Apple device visit this webpage. Here is written how to make a circuit with some resistors, that can charge an iPad, iPod or iPhone.
    Step 5: PART 2: Solar Charger
    For the box I have used a transparent CD case. In this part the dremel has a very important role. Remove everything from the CD case, make it smooth. You must cut a hole for the solar panel. Glue there the solar panel, and clean it. After this cut two other holes for the USB jack, and for the switch. You can see these holes on the second photo. It is an easy and a nice design. Saves the circuit and the other materials, but is slim and small, you can hold almost everywhere (on your jacket, satchel, bag, besides the window, where the Sun is shining, etc.).
    Step 6: PART 2: Soldering
    The circuit is very simple, uses only a switch and a 7805 voltage regualator. The psitive wire of the solar panel is soldered to the center of the switch. To the rigt side solder the positive 9v clip, and to the left side the positive input of the 5v regugator. If the switch is in center the circuit is turned off, if is in the right you activate the the regualtor and if is in the left side the current flows to the 9v clip. Trough the 9v clip you can charge up the power bank. Before glue test it, and if works fix everything .
    Step 7: PART 2: Testing
    You can't see on the images, but my phone is charging. The 9v clip can be used as a supporter too. You can charge even tablets, but it needs at least 5 hours. My room's windows looks southwards, so I can charge my phone anytime with green energy (of course when Sun is shining). I use my phone only for callings and for browsing sometimes, so the battery discharges slowly, but when is "dead" I can charge up with this gadget. Please do not misunderstand, don't want to be boastful, I'm trying to tell you somehow, that green energy is cool.
    Step 8: PART 3: Hydro/Wind Turbine on Your Faucet
    You may see many DIY solar and power bank chargers, but this hydro turbine is very particular, because you can't buy this in shops, this is a new invention. The base of the gadget is the Joule Thief circuit, that, is builded from a few components. On the circuit you can see, that the power source is the M (motor, with a propeller on it) and the usually used 1k is switched to a 50 ohm resistor. The role of the blocking diode is that don't allows that the current flows backwards. In the link at the materials is described detalied the Joule Thief. If the circuit has worked on the breadboard solder everything together.
    Step 9: PART 3: Soldering...
    You must create the board as small as you can, or will looks bad. I think nobody wants a piece junk on his faucet. The perfect solution is, if you make it with SMD components and with a printed circuit board, but I choosed the cheaper way. To the output legs solder long wires and connect to the power bank or to a rechargeable battery. The circuit isn't difficult, but you need to use glue gun to make it waterproof. Now that i write this instructable have an idea: I don''t will show you the design just after a few week. Be creative! Send an image in your comment about your gadget. Sorry for my potential English failures. If you liked it please vote on me in the Make Energy contest, and the uptade with the design will coming soon:). If you have an idea for upgrading please comment!
    MAKE ENERGY: A US-Mexico Innovation Challenge
    Fourth Prize in the
      • Gardening Contest
        Gardening Contest
      • Arduino Contest 2019
      • Party Challenge
        Party Challenge
      39 Discussions
      RowanS1
      2 years ago
      im wondering if a tap faucet can generate enough power to run a led light?
      I like the scope of this project, but it does have quite a few limitations. The big one is the wind/ hydro. I personally find that very difficult to do on a small scale if not impossible to do.
      Does it work? Yes. Does it work enough to use for anything useful, no.
      Actually decades ago there were tap driven "water motors" that were used in places that municipal water but had not yet been wired for electricity, they were used for all kinds of "useful" things:
      http://www.lowtechmagazine.com/2013/09/power-from-the-tap-water-motors.html
      Imetomi
      Reply 4 years ago
      Ok, that was a useful comment.
      pascha
      Reply 4 years ago on Introduction
      Like I said, I was going for the highest possible production. 4,000 / 365 = 11 hours per day. I used his panel size of 1.2 Watts.
      Also, kW (kilo-Watt) is a measure of power, and kWh (kilo-Watt hour) is a measure of energy.
      Imetomi
      Reply 4 years ago
      Any other problems, sir?
      Imetomi
      Reply 4 years ago
      In the link is another panel I've used a solar panel that I bought from a local store.
      Imetomi
      Reply 4 years ago
      Yes is waterproof and nothing happens with hot water. The water from a faucet wouldn't be more than 70°C.
      Imetomi
      Reply 4 years ago
      Get a multimeter gauge the voltage on your battery charger. On my smart charger this is 4.17v. The charging voltage needs to be higher. This 4.17v will drop to 1.2v when you vonnect the battery. Or the phone charger has 5v to charge a 3.7v battery.
      Imetomi
      I use a 1.2 watt solar panel, and I think that these devices will reproduce the building cost, if you use wallplug charger rarely.
      paschaImetomi
      Not exactly. A 1.2 Watt solar panel in full sun will generate 4.8 kWh per 4,000 hours, which is more than you can reasonably expect to have this device in the sun in a year, but it would represent the maximum power production. The average cost for a kWh is around 10 cents, so savings is more like 50 cents per year rather than $50.
      This is not to say that this charger isn't a good idea or useful in places without available plug power, but it's not going to replace your wall charger without a much larger solar panel.
      My wall charger is 9 Watts DC output at 5 Volts, so if I was going to build it, I would use at minimum a 10 Watt panel.
      Imetomi
      Reply 4 years ago
      We don't waste water, use the small turbine when you really use your faucet (example washing...)
      tafelice
      Where do you order your electronic parts? Online? Where is that in USA. If you do not order in USA anyone else can you recommend a reliable and economical place for parts.
      Also, I have been trying for years to get a foothold into electronics. Can you or anyone recommend a very easy project series even a dummy can do first time?
      Thanks for the instructable and where can we vote for you. Put in a link.
      ImetomiImetomi
      Reply 4 years ago
      You can order here if you live in the USA. If you want to start electronics see my other instructables or any beginner project and get a book that explain the basic of electronics. (Radioshack book, I don't know the original title. You can vote on me next to the title. There's a little gold Vote button. Thanks!
      Starsword7
      Great Instructable!
      I wonder if this would all fit in an altoids tin . . .
      GalenA1
      4 years ago
      Awesome! I'll have to try this. I spotted some grammar errors up there so be sure to check that out. Where did you get all of your components? Did you buy them or scavenge them? Thanks!
